[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-462-g40b4abf29
Wed Feb 2 11:24:20 PST 2022
the project "PostGIS".
       via  40b4abf2957c9cbb20b98148134ccb648bd29631 (commit)
       via  6b8fec2128001f127502b6361d0c9da06a63c3c9 (commit)
      from  8549294e8c8b289e24a141f99e1859f640937a7d (commit)
revisions in full, below.
commit 40b4abf2957c9cbb20b98148134ccb648bd29631
Merge: 6b8fec212 8549294e8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Feb 2 11:24:15 2022 -0800
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 6b8fec2128001f127502b6361d0c9da06a63c3c9
Date:   Wed Feb 2 11:24:05 2022 -0800
    Add in some proof-of-life tests for GEOS 3.11+ concavehull
diff --git a/regress/core/geos311.sql b/regress/core/geos311.sql
new file mode 100644
index 000000000..f2eafd51c
--- /dev/null
+++ b/regress/core/geos311.sql
@@ -0,0 +1,19 @@
+-- ST_ConcaveHull --
+WITH hull AS (
+	SELECT ST_Buffer(ST_MakePoint(0,0),1) AS geom
+SELECT 'concavehull01',
+	abs(ST_Area(geom) - ST_Area(ST_ConcaveHull(geom, 1.0))) < 0.01 AS area_convex
+FROM hull;
+WITH hull AS (
+	SELECT ST_Difference(
+		ST_Buffer(ST_MakePoint(0,0),10),
+		ST_Translate(ST_Buffer(ST_MakePoint(0,0),10), 5, 0)) AS geom
+SELECT 'concavehull02',
+	ST_Area(ST_ConcaveHull(geom, 0.5)) > 0.0 AS area_non_zero,
+	ST_GeometryType(ST_ConcaveHull(geom, 0.5)) AS type,
+	ST_Area(ST_ConcaveHull(geom, 0.5, true)) > 0.0 AS nohole_area_non_zero
+FROM hull;
diff --git a/regress/core/geos311_expected b/regress/core/geos311_expected
index 000000000..b42456e4e
--- /dev/null
+++ b/regress/core/geos311_expected
@@ -0,0 +1,2 @@
+concavehull01|t
+concavehull02|t|ST_Polygon|t
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 2e4342230..62c9dc73f 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -169,8 +169,11 @@ ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31000),1)
 		$(topsrcdir)/regress/core/geos310
 endif
-# Only run the internal concavehull tests for GEOS < 3.11
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" "<" 31100),1)
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31100),1)
+	TESTS += \
+		$(topsrcdir)/regress/core/geos311
+# Only run the old internal concavehull tests for GEOS < 3.11
+else
 	TESTS += \
 		$(topsrcdir)/regress/core/concave_hull
 endif
Summary of changes:
 regress/core/geos311.sql      | 19 +++++++++++++++++++
 regress/core/geos311_expected |  2 ++
 regress/core/tests.mk.in      |  7 +++++--
 3 files changed, 26 insertions(+), 2 deletions(-)
 create mode 100644 regress/core/geos311.sql
 create mode 100644 regress/core/geos311_expected
hooks/post-receive
