[postgis-tickets] [PostGIS] #5079: concaveHull test fails with current GEOS main branch
PostGIS trac at osgeo.org
Wed Feb 2 13:44:36 PST 2022
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.3.0
 Component:  postgis  |    Version:  3.2.x
Resolution:  invalid  |   Keywords:
Comment (by strk):
 Is it true that my signature change is incompatible with the underlying C
 signature ?
 I had the dubt, when changing `float8` to `float`, when fixing #5078 -- if
 this is the case I guess we'd want the C function to expect `float`
 (hoping it's not architecture dependent)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5079#comment:4>
