[postgis-tickets] [PostGIS] #5078: 2.5.6dev--3.3.0dev upgrade fails: cannot change name of input parameter "param_geom"
PostGIS trac at osgeo.org
Wed Feb 2 13:50:40 PST 2022
"param_geom"
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Reopening as it looks like the old signature is just NOT compatible with
 the C implemented version of the function, see
 https://trac.osgeo.org/postgis/ticket/5079#comment:5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5078#comment:9>
