[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-468-g9ee878621
Wed Feb 2 15:42:21 PST 2022
the project "PostGIS".
       via  9ee87862195400f8483127cdd6ed7bac8322e247 (commit)
       via  3a0ab4b3380e67b973438a8a958ab2c3536548ff (commit)
      from  e57f8deba8d999ed66d518e73104994bc8c6499b (commit)
revisions in full, below.
commit 9ee87862195400f8483127cdd6ed7bac8322e247
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 2 15:42:17 2022 -0800
    Add line endpoints to doc image generator
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 778bff90e..6e8d6ebf1 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -90,6 +90,38 @@ pointarrayToString(char *output, POINTARRAY *pa)
 	return (ptr - output);
+ * Draws a point in a POINTARRAY to a char* using ImageMagick SVG for styling.
+ * @param output a char reference to write the LWPOINT to
+ * @param lwp a reference to a LWPOINT
+ * @return the numbers of character written to *output
+static size_t
+drawPointSymbol(char *output, POINTARRAY *pa, unsigned int index, int size, char* color)
+	// short-circuit no-op
+	if (size <= 0) return 0;
+	char x[OUT_DOUBLE_BUFFER_SIZE];
+	char y1[OUT_DOUBLE_BUFFER_SIZE];
+	char y2[OUT_DOUBLE_BUFFER_SIZE];
+	char *ptr = output;
+	POINT2D p;
+	getPoint2d_p(pa, index, &p);
+	lwprint_double(p.x, 10, x);
+	lwprint_double(p.y, 10, y1);
+	lwprint_double(p.y + size, 10, y2);
+	ptr += sprintf(ptr, "-fill %s -strokewidth 0 ", color);
+	ptr += sprintf(ptr, "-draw \"circle %s,%s %s,%s", x, y1, x, y2);
+	ptr += sprintf(ptr, "'\" ");
+	return (ptr - output);
  * Serializes a LWPOINT to a char*.  This is a helper function that partially
  * writes the appropriate draw and fill commands used to generate an SVG image
@@ -146,6 +178,9 @@ drawLineString(char *output, LWLINE *lwl, LAYERSTYLE *style)
 	ptr += pointarrayToString(ptr, lwl->points );
+	ptr += drawPointSymbol(ptr, lwl->points, 0, style->lineStartSize, style->lineColor);
+	ptr += drawPointSymbol(ptr, lwl->points, lwl->points->npoints-1, style->lineEndSize, style->lineColor);
@@ -419,6 +454,7 @@ int main( int argc, const char* argv[] )
 		lwgeom_free( lwgeom );
 		LWDEBUGF( 4, "%s", output );
+		//puts(output);
 		checked_system(output);
 		//-- (MD) disable highlighting since it doesn't work well with opacity
diff --git a/doc/html/image_src/st_issimple01.wkt b/doc/html/image_src/st_issimple01.wkt
index 690d1f5ab..96820eb88 100644
--- a/doc/html/image_src/st_issimple01.wkt
+++ b/doc/html/image_src/st_issimple01.wkt
@@ -1 +1 @@
-ArgA;GEOMETRYCOLLECTION ( LINESTRING ( 10 190, 140 130, 70 80, 190 10 ), POINT(10 190), POINT(190 10) )
+ArgA-endpoints;LINESTRING ( 10 190, 140 130, 70 80, 190 10 )
diff --git a/doc/html/image_src/st_issimple02.wkt b/doc/html/image_src/st_issimple02.wkt
index 78a496445..938d9fa24 100644
--- a/doc/html/image_src/st_issimple02.wkt
+++ b/doc/html/image_src/st_issimple02.wkt
@@ -1 +1 @@
-ArgB;GEOMETRYCOLLECTION ( LINESTRING ( 10 190, 130 40, 170 160, 10 10 ), POINT(10 190), POINT(10 10) )
+ArgB-endpoints;LINESTRING ( 10 190, 130 40, 170 160, 10 10 )
diff --git a/doc/html/image_src/st_issimple03.wkt b/doc/html/image_src/st_issimple03.wkt
index e066e1e05..5087b679a 100644
--- a/doc/html/image_src/st_issimple03.wkt
+++ b/doc/html/image_src/st_issimple03.wkt
@@ -1 +1 @@
-ArgA;GEOMETRYCOLLECTION ( LINESTRING ( 90 190, 120 190, 130 140, 190 50, 70 10, 10 70, 10 150, 90 190 ), POINT(90 190) )
+ArgA-endpoints;LINESTRING ( 90 190, 120 190, 130 140, 190 50, 70 10, 10 70, 10 150, 90 190 )
diff --git a/doc/html/image_src/st_issimple04.wkt b/doc/html/image_src/st_issimple04.wkt
index 26d5a8998..0c4e055d4 100644
--- a/doc/html/image_src/st_issimple04.wkt
+++ b/doc/html/image_src/st_issimple04.wkt
@@ -1 +1 @@
-ArgB;GEOMETRYCOLLECTION ( LINESTRING ( 90 190, 120 190, 50 60, 130 10, 190 50, 160 90, 10 150, 90 190 ), POINT(90 190) )
+ArgB-endpoints;LINESTRING ( 90 190, 120 190, 50 60, 130 10, 190 50, 160 90, 10 150, 90 190 )
diff --git a/doc/html/image_src/st_issimple05.wkt b/doc/html/image_src/st_issimple05.wkt
index c4a17b232..30458db7b 100644
--- a/doc/html/image_src/st_issimple05.wkt
+++ b/doc/html/image_src/st_issimple05.wkt
@@ -1 +1 @@
-ArgA;GEOMETRYCOLLECTION ( LINESTRING ( 30 190, 60 60, 170 10 ), LINESTRING ( 100 190, 180 150, 160 70 ), MULTIPOINT ( 30 190, 170 10, 100 190, 160 70 ) )
+ArgA-endpoints;MULTILINESTRING (( 30 190, 60 60, 170 10 ), ( 100 190, 180 150, 160 70 ))
diff --git a/doc/html/image_src/st_issimple06.wkt b/doc/html/image_src/st_issimple06.wkt
index 0caf2dab4..8db798269 100644
--- a/doc/html/image_src/st_issimple06.wkt
+++ b/doc/html/image_src/st_issimple06.wkt
@@ -1 +1 @@
-ArgA;GEOMETRYCOLLECTION ( LINESTRING ( 30 190, 60 60, 170 10 ), LINESTRING ( 30 190, 180 150, 160 70 ), MULTIPOINT( 170 10, 30 190, 170 10, 160 70 ) )
+ArgA-endpoints;MULTILINESTRING (( 30 190, 60 60, 170 10 ), ( 30 190, 180 150, 160 70 ))
diff --git a/doc/html/image_src/st_issimple07.wkt b/doc/html/image_src/st_issimple07.wkt
index ea5ae8e44..78f357643 100644
--- a/doc/html/image_src/st_issimple07.wkt
+++ b/doc/html/image_src/st_issimple07.wkt
@@ -1 +1 @@
-ArgB;GEOMETRYCOLLECTION ( LINESTRING ( 30 190, 60 60, 170 10 ), LINESTRING (100 190, 180 150, 80 10), MULTIPOINT( 30 190, 170 10, 100 190, 80 10 ) )
+ArgB-endpoints;MULTILINESTRING (( 30 190, 60 60, 170 10 ), (100 190, 180 150, 80 10))
diff --git a/doc/html/image_src/styles.c b/doc/html/image_src/styles.c
index d22c0ae12..587afb1ed 100644
--- a/doc/html/image_src/styles.c
+++ b/doc/html/image_src/styles.c
@@ -46,6 +46,8 @@ getStyles( const char *filename, LAYERSTYLE **headRef )
 			char *pointColor = "Grey";
 			int lineWidth = 5;
 			char *lineColor = "Grey";
+			int lineStartSize = 0;
+			int lineEndSize = 0;
 			char *polygonFillColor = "Grey";
 			char *polygonStrokeColor = "Grey";
 			int polygonStrokeWidth = 0;
@@ -76,6 +78,21 @@ getStyles( const char *filename, LAYERSTYLE **headRef )
 					else if (strncmp(line, "lineColor", 9) == 0)
 						lineColor = ptr;
+					else if (strncmp(line, "lineWidth", 9) == 0)
+						lineWidth = atoi(ptr);
+						free(ptr);
+					else if (strncmp(line, "lineStartSize", 13) == 0)
+						lineStartSize = atoi(ptr);
+						free(ptr);
+					else if (strncmp(line, "lineEndSize", 11) == 0)
+						lineEndSize = atoi(ptr);
+						free(ptr);
 					else if (strncmp(line, "polygonFillColor", 16) == 0)
 						polygonFillColor = ptr;
 					else if (strncmp(line, "polygonStrokeColor", 18) == 0)
@@ -85,17 +102,15 @@ getStyles( const char *filename, LAYERSTYLE **headRef )
 						polygonStrokeWidth = atoi(ptr);
 						free(ptr);
 				getResults = fgets ( line, sizeof line, pFile );
-			addStyle(headRef, styleName, pointSize, pointColor, lineWidth, lineColor, polygonFillColor, polygonStrokeColor, polygonStrokeWidth);
+			addStyle(headRef, styleName, pointSize, pointColor,
+				lineWidth, lineColor, lineStartSize, lineEndSize,
+				polygonFillColor, polygonStrokeColor, polygonStrokeWidth);
 	fclose( pFile );
@@ -128,6 +143,7 @@ addStyle(
     char* styleName,
     int pointSize, char* pointColor,
     int lineWidth, char* lineColor,
+	int lineStartSize, int lineEndSize,
     char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth)
 	LAYERSTYLE *style = malloc( sizeof(LAYERSTYLE) );
@@ -137,6 +153,8 @@ addStyle(
 	style->pointColor = pointColor;
 	style->lineWidth = lineWidth;
 	style->lineColor = lineColor;
+	style->lineStartSize = lineStartSize;
+	style->lineEndSize = lineEndSize;
 	style->polygonFillColor = polygonFillColor;
 	style->polygonStrokeColor = polygonStrokeColor;
 	style->polygonStrokeWidth = polygonStrokeWidth;
diff --git a/doc/html/image_src/styles.conf b/doc/html/image_src/styles.conf
index e536e8966..e7e7d0875 100644
--- a/doc/html/image_src/styles.conf
+++ b/doc/html/image_src/styles.conf
@@ -51,6 +51,19 @@ polygonFillColor = "#C0D0F080"
 polygonStrokeColor = "#6495ED"
 polygonStrokeWidth = 2
+[Style]
+# Argument A with line endpoints
+styleName = ArgA-endpoints
+pointSize = 5
+pointColor = "#6495ED"
+lineWidth = 4
+lineColor = "#6495ED"
+lineStartSize = 5
+lineEndSize = 5
+polygonFillColor = "#C0D0F080"
+polygonStrokeColor = "#6495ED"
+polygonStrokeWidth = 2
 [Style]
 # Argument B
 styleName = ArgB
@@ -73,6 +86,19 @@ polygonFillColor = "#00ffa040"
 polygonStrokeColor = "#7ACAC4"
 polygonStrokeWidth = 1
+[Style]
+# Argument B with line endpoints
+styleName = ArgB-endpoints
+pointSize = 5
+pointColor = "#7ACAC4"
+lineWidth = 4
+lineColor = "#7ACAC4"
+lineStartSize = 5
+lineEndSize = 5
+polygonFillColor = "#00ffa040"
+polygonStrokeColor = "#7ACAC4"
 [Style]
 # Result
 styleName = Result
diff --git a/doc/html/image_src/styles.h b/doc/html/image_src/styles.h
index 78144e5d8..cf1688d35 100644
--- a/doc/html/image_src/styles.h
+++ b/doc/html/image_src/styles.h
@@ -26,6 +26,9 @@ struct layerStyle
 	int   lineWidth;
 	char *lineColor;
+	int   lineStartSize;
+	int   lineEndSize;
 	char *polygonFillColor;
 	char *polygonStrokeColor;
 	int   polygonStrokeWidth;
@@ -35,7 +38,7 @@ struct layerStyle
 void getStyles( const char *filename, LAYERSTYLE **headRef );
 void freeStyles( LAYERSTYLE **headRef );
-void addStyle( LAYERSTYLE **headRef, char* styleName, int pointSize, char* pointColor, int lineWidth, char* lineColor, char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth );
+void addStyle( LAYERSTYLE **headRef, char* styleName, int pointSize, char* pointColor, int lineWidth, char* lineColor, int lineStartSize, int lineEndSize, char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth );
 int length( LAYERSTYLE *headRef );
 LAYERSTYLE* getStyle( LAYERSTYLE *headRef, char* styleName );
commit 3a0ab4b3380e67b973438a8a958ab2c3536548ff
Date:   Wed Feb 2 15:41:40 2022 -0800
    Improve doc validation image captions
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 805589c53..04bb341cb 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1364,12 +1364,12 @@ VALUES ( 990000,
 		<tgroup cols="1">
 		  <tbody>
 			<row>
-				<entry><para>In these examples
+				<entry><para><emphasis>
                 <emphasis role="bold">(a)</emphasis> and
 				<emphasis role="bold">(c)</emphasis> are simple	<varname>LINESTRING</varname>s.
                 <emphasis role="bold">(b)</emphasis> and <emphasis role="bold">(d)</emphasis> are not simple.
-                <emphasis role="bold">(c)</emphasis> and <emphasis role="bold">(d)</emphasis> are closed Linear Rings.
-                </para></entry>
+                <emphasis role="bold">(c)</emphasis> is a closed Linear Ring.
+                </emphasis></para></entry>
 			</row>
 		  </tbody>
 		</tgroup>
@@ -1432,11 +1432,12 @@ VALUES ( 990000,
 		<tgroup cols="1">
 		  <tbody>
 			<row>
                 <emphasis role="bold">(e)</emphasis> and
 				<emphasis role="bold">(f)</emphasis> are simple
-				<varname>MULTILINESTRING</varname>s, <emphasis role="bold">(g)</emphasis>
-				is not.</para></entry>
+				<varname>MULTILINESTRING</varname>s.
+                <emphasis role="bold">(g)</emphasis> is not simple.
 			</row>
 		  </tbody>
 		</tgroup>
@@ -1510,13 +1511,13 @@ VALUES ( 990000,
 		<tgroup cols="1">
 		  <tbody>
 			<row>
                 <emphasis role="bold">(h)</emphasis> and
 				<emphasis role="bold">(i)</emphasis> are valid <varname>POLYGON</varname>s.
-                <emphasis role="bold">(j-m)</emphasis> are invalid
-				(but <emphasis role="bold">(j)</emphasis>
-				could be represented as a valid <varname>MULTIPOLYGON</varname>).
-				</para></entry>
+                <emphasis role="bold">(j-m)</emphasis> are invalid.
+				<emphasis role="bold">(j)</emphasis>
+				could be represented as a valid <varname>MULTIPOLYGON</varname>.
 			</row>
 		  </tbody>
 		</tgroup>
@@ -1608,10 +1609,10 @@ VALUES ( 990000,
 		<tgroup cols="1">
 		  <tbody>
 			<row>
                 <emphasis role="bold">(n)</emphasis> is a valid <varname>MULTIPOLYGON</varname>.
 				<emphasis role="bold">(o)</emphasis> and <emphasis role="bold">(p)</emphasis> are not valid.
-                </para></entry>
 			</row>
 		  </tbody>
 		</tgroup>
Summary of changes:
 doc/html/image_src/generator.c       | 36 ++++++++++++++++++++++++++++++++++++
 doc/html/image_src/st_issimple01.wkt |  2 +-
 doc/html/image_src/st_issimple02.wkt |  2 +-
 doc/html/image_src/st_issimple03.wkt |  2 +-
 doc/html/image_src/st_issimple04.wkt |  2 +-
 doc/html/image_src/st_issimple05.wkt |  2 +-
 doc/html/image_src/st_issimple06.wkt |  2 +-
 doc/html/image_src/st_issimple07.wkt |  2 +-
 doc/html/image_src/styles.c          | 28 +++++++++++++++++++++++-----
 doc/html/image_src/styles.conf       | 26 ++++++++++++++++++++++++++
 doc/html/image_src/styles.h          |  5 ++++-
 doc/using_postgis_dataman.xml        | 27 ++++++++++++++-------------
 12 files changed, 110 insertions(+), 26 deletions(-)
hooks/post-receive
