[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-470-g64abce150
Thu Feb 3 05:05:15 PST 2022
the project "PostGIS".
       via  64abce15057e9606f3d8399ea22dc31a865a52e6 (commit)
      from  c6241f8c0ab54b4018d4d285a2c44b24608af891 (commit)
revisions in full, below.
commit 64abce15057e9606f3d8399ea22dc31a865a52e6
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 3 13:38:43 2022 +0100
    Add support in run_test.pl for script based upgrade paths
    [ci skip]
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 444ee7207..d89d6944c 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -110,10 +110,6 @@ if ( @ARGV < 1 )
 if ( $OPT_UPGRADE_PATH )
-  if ( ! $OPT_EXTENSIONS )
-    die "--upgrade-path is only supported with --extension"
   $OPT_UPGRADE = 1; # implied
   my @path = split ('--', $OPT_UPGRADE_PATH);
   $OPT_UPGRADE_FROM = $path[0]
@@ -1332,22 +1328,37 @@ sub create_db
 sub create_spatial
-	my ($cmd, $rv);
-	print "Creating database '$DB' \n";
+    my ($cmd, $rv);
+    print "Creating database '$DB' \n";
-  	$rv = create_db();
+    $rv = create_db();
-	# Count database objects before installing anything
-	$OBJ_COUNT_PRE = count_db_objects();
+    # Count database objects before installing anything
+    $OBJ_COUNT_PRE = count_db_objects();
-	if ( $OPT_EXTENSIONS )
-		prepare_spatial_extensions();
-	else
-		prepare_spatial();
+    if ( $OPT_EXTENSIONS )
+        prepare_spatial_extensions();
+    else
+        if ( ! $OPT_UPGRADE_FROM )
+            prepare_spatial();
+            return;
+        if ( $OPT_UPGRADE_FROM !~ /^unpackaged(.*)/ )
+            die "--upgrade-path without --extension is only supported with source unpackaged*";
+        if ( $OPT_UPGRADE_TO != ':auto' )
+            die "--upgrade-path without --extension is only supported with target :auto";
+        prepare_spatial($1);
Summary of changes:
 regress/run_test.pl | 45 ++++++++++++++++++++++++++++-----------------
 1 file changed, 28 insertions(+), 17 deletions(-)
hooks/post-receive
