[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-471-g58a27e141
Thu Feb 3 09:57:27 PST 2022
the project "PostGIS".
       via  58a27e141d9d681ecb955860a179d32a1a274a38 (commit)
      from  64abce15057e9606f3d8399ea22dc31a865a52e6 (commit)
revisions in full, below.
commit 58a27e141d9d681ecb955860a179d32a1a274a38
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Feb 3 09:57:23 2022 -0800
    Improve doc Validity section
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 04bb341cb..1629f4527 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -874,279 +874,460 @@ SELECT ST_Distance('LINESTRING(-122.33 47.606, 0.0 51.5)'::geometry, 'POINT(-21.
 			</qandaset>
 	</sect2>
 </sect1>
+<sect1 id="OGC_Validity">
+	  <title>Geometry Validation</title>
-  <sect1>
-	<title>Spatial Tables</title>
-	<sect2 id="Create_Spatial_Table">
-	  <title>Creating a Spatial Table</title>
+	  <para>PostGIS is compliant with the Open Geospatial Consortium’s (OGC)
+	  Simple Features Specification.
+      It defines the concepts of geometry being
+      <emphasis>simple</emphasis> and <emphasis>valid</emphasis>.
+      These definitions allow the Simple Features geometry model
+      to represent spatial objects in a consistent and unambiguous way
+      that supports efficient computation.
+        </para>
-		<para>You can create a table to store geometry data using the
-        <ulink url="https://www.postgresql.org/docs/current/sql-createtable.html">CREATE TABLE</ulink>
-        SQL statement with a column of type <varname>geometry</varname>.
-        The following example creates a table with a geometry column storing 2D (XY) LineStrings
-        in the BC-Albers coordinate system (SRID 3005):</para>
+	<sect2 id="Simple_Geometry">
+	  <title>Simple Geometry</title>
-<programlisting>CREATE TABLE roads (
-    id SERIAL PRIMARY KEY,
-    name VARCHAR(64),
-    geom geometry(LINESTRING,3005)
-  );</programlisting>
+	  <para>A <emphasis>simple</emphasis>
+	  geometry is one that has no anomalous geometric points, such as self
+	  intersection or self tangency.
+	  </para>
-		<para>The <varname>geometry</varname> type supports two optional <emphasis role="bold">type modifiers</emphasis>:</para>
+	  <para>A <varname>POINT</varname> is inherently <emphasis>simple</emphasis>
+	  as a 0-dimensional geometry object.</para>
-        <itemizedlist>
-		<listitem>
-        <para>the <emphasis role="bold">spatial type modifier</emphasis>
-        restricts the kind of shapes and dimensions allowed in the column.
-		The value can be any of the supported
-        <link linkend="RefObject">geometry subtypes</link>
-        (e.g. POINT, LINESTRING, POLYGON, MULTIPOINT, MULTILINESTRING, MULTIPOLYGON, GEOMETRYCOLLECTION, etc).
-        The modifier supports coordinate dimensionality restrictions by adding suffixes: Z, M and ZM.
-        For example, a modifier of 'LINESTRINGM' allows only linestrings with three dimensions, and treats the third dimension as a measure.
-		Similarly, 'POINTZM' requires four dimensional (XYZM) data.
-        </para>
-		</listitem>
-		<listitem>
-        <para>the <emphasis role="bold">SRID modifier</emphasis> restricts the
-        <link linkend="spatial_ref_sys">spatial reference system</link> SRID to a particular number.
-        If omitted, the SRID defaults to 0.
-        </para>
-		</listitem>
-		</itemizedlist>
+	  <para><varname>MULTIPOINT</varname>s are <emphasis>simple</emphasis> if
+	  no two coordinates (<varname>POINT</varname>s) are equal (have identical
+	  coordinate values).</para>
-		<para></para>
+	  <para>A <varname>LINESTRING</varname> is <emphasis>simple</emphasis> if
+	  it does not pass through the same point twice, except for the endpoints.
+      If the endpoints of a simple LineString are identical it is called <emphasis>closed</emphasis>
+      and referred to as a Linear Ring.</para>
-        <para>Examples of creating tables with geometry columns:</para>
-		<itemizedlist>
-		<listitem>
-		  <para>Create a table holding any kind of geometry with the default SRID:</para>
-		  <para><programlisting>CREATE TABLE geoms(gid serial PRIMARY KEY, geom geometry );</programlisting></para>
-		</listitem>
-		<listitem>
-		  <para>Create a table with 2D POINT geometry with the default SRID:</para>
-		  <para><programlisting>CREATE TABLE pts(gid serial PRIMARY KEY, geom geometry(POINT) );</programlisting></para>
-		</listitem>
-		<listitem>
-		  <para>Create a table with 3D (XYZ) POINTs and an explicit SRID of 3005:</para>
-		  <para><programlisting>CREATE TABLE pts(gid serial PRIMARY KEY, geom geometry(POINTZ,3005) );</programlisting></para>
-		</listitem>
-		<listitem>
-			<para>Create a table with 4D (XYZM) LINESTRING geometry with the default SRID:</para>
-			<para><programlisting>CREATE TABLE lines(gid serial PRIMARY KEY, geom geometry(LINESTRINGZM) );</programlisting></para>
-		</listitem>
-		<listitem>
-			<para>Create a table with 2D POLYGON geometry with the SRID 4267 (NAD 1927 long lat):</para>
-			<para><programlisting>CREATE TABLE polys(gid serial PRIMARY KEY, geom geometry(POLYGON,4267) );</programlisting></para>
-		</listitem>
-		</itemizedlist>
+	  <informaltable border="0" frame="none">
+		<tgroup cols="1">
+		  <tbody>
+			<row>
+				<entry><para><emphasis>
+                <emphasis role="bold">(a)</emphasis> and
+				<emphasis role="bold">(c)</emphasis> are simple	<varname>LINESTRING</varname>s.
+                <emphasis role="bold">(b)</emphasis> and <emphasis role="bold">(d)</emphasis> are not simple.
+                <emphasis role="bold">(c)</emphasis> is a closed Linear Ring.
+                </emphasis></para></entry>
+			</row>
+		  </tbody>
+		</tgroup>
+		<tgroup cols="2" align="center">
+		  <tbody>
+			<row>
+			  <entry><para><informalfigure>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple01.png" />
+					</imageobject>
-	  <para>It is possible to have more than one geometry column in a table.
-        This can be specified when the table is created, or a column can be added using the
-        <ulink url="https://www.postgresql.org/docs/current/sql-altertable.html">ALTER TABLE</ulink>
-        SQL statement.
-        This example adds a column that can hold 3D LineStrings:</para>
+					<caption><para><emphasis role="bold">(a)</emphasis></para></caption>
+				  </mediaobject>
+				</informalfigure></para></entry>
-	  <programlisting>ALTER TABLE roads ADD COLUMN geom2 geometry(LINESTRINGZ,4326);</programlisting>
-	</sect2>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple02.png" />
+					</imageobject>
-	<sect2 id="geometry_columns">
-	  <title>GEOMETRY_COLUMNS View</title>
+					<caption><para><emphasis role="bold">(b)</emphasis></para></caption>
+				  </mediaobject>
+			</row>
-      <para>The OGC <emphasis>Simple Features Specification for SQL</emphasis> defines
-      the <varname>GEOMETRY_COLUMNS</varname> metadata table to describe geometry table structure.
-      In PostGIS <varname>geometry_columns</varname> is a view reading from database system catalog tables.
-      This ensures that the spatial metadata information is always consistent with the currently defined tables and views.
-	  The view structure is:</para>
+			<row>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple03.png" />
+					</imageobject>
-	  <programlisting>\d geometry_columns</programlisting>
-<screen>             View "public.geometry_columns"
-      Column       |          Type          | Modifiers
- f_table_catalog   | character varying(256) |
- f_table_schema    | character varying(256) |
- f_table_name      | character varying(256) |
- f_geometry_column | character varying(256) |
- coord_dimension   | integer                |
- srid              | integer                |
- type              | character varying(30)  |</screen>
+					<caption><para><emphasis role="bold">(c)</emphasis></para></caption>
+				  </mediaobject>
-	  <para>The columns are:</para>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple04.png" />
+					</imageobject>
-	  <variablelist>
-		<varlistentry>
-		  <term>f_table_catalog, f_table_schema, f_table_name</term>
+					<caption><para><emphasis role="bold">(d)</emphasis></para></caption>
+				  </mediaobject>
+			</row>
+		  </tbody>
+		</tgroup>
-		  <listitem>
-			<para>The fully qualified name of the feature table containing the
-			geometry column. There is no PostgreSQL analogue of "catalog" so that
-			column is left blank. For "schema" the PostgreSQL schema name is
-			used (<varname>public</varname> is the default).</para>
-		  </listitem>
-		</varlistentry>
+	  </informaltable>
-		<varlistentry>
-		  <term>f_geometry_column</term>
+	  <para>A <varname>MULTILINESTRING</varname> is <emphasis>simple</emphasis>
+	  only if all of its elements are simple and the only intersection between
+	  any two elements occurs at points that are on the
+	  boundaries of both elements.  </para>
-		  <listitem>
-			<para>The name of the geometry column in the feature table.</para>
-		  </listitem>
-		</varlistentry>
+		<tgroup cols="1">
+		  <tbody>
+			<row>
+                <emphasis role="bold">(e)</emphasis> and
+				<emphasis role="bold">(f)</emphasis> are simple
+				<varname>MULTILINESTRING</varname>s.
+                <emphasis role="bold">(g)</emphasis> is not simple.
+			</row>
+		  </tbody>
+		</tgroup>
+		<tgroup cols="3" align="center">
+		  <tbody>
+			<row>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple05.png" />
+					</imageobject>
-		<varlistentry>
-		  <term>coord_dimension</term>
+					<caption><para><emphasis role="bold">(e)</emphasis></para></caption>
+				  </mediaobject>
-		  <listitem>
-			<para>The coordinate dimension (2, 3 or 4) of the column.</para>
-		  </listitem>
-		</varlistentry>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple06.png" />
+					</imageobject>
-		<varlistentry>
-		  <term>srid</term>
+					<caption><para><emphasis role="bold">(f)</emphasis></para></caption>
+				  </mediaobject>
-		  <listitem>
-			<para>The ID of the spatial reference system used for the
-			coordinate geometry in this table. It is a foreign key reference
-			to the <varname>spatial_ref_sys</varname> table
-            (see <xref linkend="spatial_ref_sys_table" />).</para>
-		  </listitem>
-		</varlistentry>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_issimple07.png" />
+					</imageobject>
-		<varlistentry>
-		  <term>type</term>
+					<caption><para><emphasis role="bold">(g)</emphasis></para></caption>
+				  </mediaobject>
+			</row>
+		  </tbody>
+		</tgroup>
+	  </informaltable>
-		  <listitem>
-			<para>The type of the spatial object. To restrict the spatial
-			column to a single type, use one of: POINT, LINESTRING, POLYGON,
-			MULTIPOINT, MULTILINESTRING, MULTIPOLYGON, GEOMETRYCOLLECTION or
-			corresponding XYM versions POINTM, LINESTRINGM, POLYGONM,
-			MULTIPOINTM, MULTILINESTRINGM, MULTIPOLYGONM, GEOMETRYCOLLECTIONM.
-			For heterogeneous (mixed-type) collections, you can use "GEOMETRY"
-			as the type.</para>
-		  </listitem>
-		</varlistentry>
-	  </variablelist>
-	</sect2>
+    <para>As described in the next section, the linear rings forming a
+    <varname>POLYGON</varname> must be simple for it to be valid.</para>
-	  <sect2 id="Manual_Register_Spatial_Column">
-		<title>Manually Registering Geometry Columns</title>
+    <para>To test if a geometry is simple
+	use the <xref linkend="ST_IsSimple" /> function:</para>
-		<para>Two of the cases where you may need this are the case of SQL Views and bulk inserts.  For bulk insert case, you can correct the registration in the geometry_columns table
-		by constraining the column or doing an alter table.  For views, you could expose using a CAST operation.
-		Note, if your column is typmod based, the creation process would register it correctly, so no need to do anything.
-		Also views that have no spatial function applied to the geometry will register the same as the underlying table geometry column.</para>
+	  <programlisting>
+SELECT
+   ST_IsSimple('LINESTRING(0 0, 100 100)') AS straight,
+   ST_IsSimple('LINESTRING(0 0, 100 100, 100 0, 0 100)') AS crossing;
-		<programlisting>-- Lets say you have a view created like this
-CREATE VIEW public.vwmytablemercator AS
-	SELECT gid, ST_Transform(geom, 3395) As geom, f_name
-	FROM public.mytable;
+ straight | crossing
+ t        | f
+</programlisting>
--- For it to register correctly
--- You need to cast the geometry
-DROP VIEW public.vwmytablemercator;
-	SELECT gid, ST_Transform(geom, 3395)::geometry(Geometry, 3395) As geom, f_name
+    <para>Generally, PostGIS functions do not require geometric arguments to be simple.
+	Simplicity is primarily used as a basis for defining geometric validity.
+    It is also a requirement for some kinds of spatial data models
+    (for example, linear networks often disallow lines that cross).
+    </para>
+    </sect2>
--- If you know the geometry type for sure is a 2D POLYGON then you could do
-	SELECT gid, ST_Transform(geom,3395)::geometry(Polygon, 3395) As geom, f_name
-	FROM public.mytable;</programlisting>
-		<programlisting>--Lets say you created a derivative table by doing a bulk insert
-SELECT poi.gid, poi.geom, citybounds.city_name
-INTO myschema.my_special_pois
-FROM poi INNER JOIN citybounds ON ST_Intersects(citybounds.geom, poi.geom);
+	<sect2 id="Valid_Geometry">
+	  <title>Valid Geometry</title>
--- Create 2D index on new table
-CREATE INDEX idx_myschema_myspecialpois_geom_gist
-  ON myschema.my_special_pois USING gist(geom);
+        <para>Geometry validity primarily applies to 2-dimensional
+        geometries (<varname>POLYGON</varname>s and <varname>MULTIPOLYGON</varname>s) .
+        Validity is defined by rules that allow polygonal geometry
+        to model planar areas unambiguously.
+        </para>
--- If your points are 3D points or 3M points,
--- then you might want to create an nd index instead of a 2D index
-CREATE INDEX my_special_pois_geom_gist_nd
-	ON my_special_pois USING gist(geom gist_geometry_ops_nd);
+      <para>A <varname>POLYGON</varname> is <emphasis>valid</emphasis> if:
+      </para>
--- To manually register this new table's geometry column in geometry_columns.
--- Note it will also change the underlying structure of the table to
--- to make the column typmod based.
-SELECT populate_geometry_columns('myschema.my_special_pois'::regclass);
+        <orderedlist>
+	    <listitem><para>
+        the polygon boundary rings (the exterior shell ring and interior hole rings)
+        are <emphasis>simple</emphasis> (do not cross or self-touch).
+        Because of this a polygon cannnot have cut lines, spikes or loops.
+        This implies that polygon holes must be represented as interior rings,
+        rather than by the exterior ring self-touching (a so-called "inverted hole").
+        </para></listitem>
+	    <listitem><para>
+        boundary rings do not cross
+	    <listitem><para>
+        boundary rings may touch at points but only as a tangent (i.e. not in a line)
+	    <listitem><para>
+        interior rings are contained in the exterior ring
+	    <listitem><para>
+        the polygon interior is simply connected
+        (i.e. the rings must not touch in a way that splits the polygon into more than one part)
+        </orderedlist>
--- If you are using PostGIS 2.0 and for whatever reason, you
--- you need the constraint based definition behavior
--- (such as case of inherited tables where all children do not have the same type and srid)
--- set optional use_typmod argument to false
-SELECT populate_geometry_columns('myschema.my_special_pois'::regclass, false); </programlisting>
+		<tgroup cols="1">
+		  <tbody>
+			<row>
+                <emphasis role="bold">(h)</emphasis> and
+				<emphasis role="bold">(i)</emphasis> are valid <varname>POLYGON</varname>s.
+                <emphasis role="bold">(j-m)</emphasis> are invalid.
+				<emphasis role="bold">(j)</emphasis>
+				can be represented as a valid <varname>MULTIPOLYGON</varname>.
+			</row>
+		  </tbody>
+		</tgroup>
+		  <tbody>
+			<row>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid01.png" />
+					</imageobject>
-<para>Although the old-constraint based method is still supported, a constraint-based geometry column used directly
-in a view, will not register correctly in geometry_columns, as will a typmod one.
-In this example we define a column using typmod and another using constraints.</para>
-<programlisting>CREATE TABLE pois_ny(gid SERIAL PRIMARY KEY, poi_name text, cat text, geom geometry(POINT,4326));
-SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2, false);</programlisting>
-<para>If we run in psql</para>
-<programlisting>\d pois_ny;</programlisting>
-<para>We observe they are defined differently -- one is typmod, one is constraint</para>
-<screen>                                  Table "public.pois_ny"
+					<caption><para><emphasis role="bold">(h)</emphasis></para></caption>
+				  </mediaobject>
- gid       | integer               | not null default nextval('pois_ny_gid_seq'::regclass)
- poi_name  | text                  |
- cat       | character varying(20) |
- geom      | geometry(Point,4326)  |
- geom_2160 | geometry              |
-Indexes:
-    "pois_ny_pkey" PRIMARY KEY, btree (gid)
-Check constraints:
-    "enforce_dims_geom_2160" CHECK (st_ndims(geom_2160) = 2)
-    "enforce_geotype_geom_2160" CHECK (geometrytype(geom_2160) = 'POINT'::text
-        OR geom_2160 IS NULL)
-    "enforce_srid_geom_2160" CHECK (st_srid(geom_2160) = 2160)</screen>
-<para>In geometry_columns, they both register correctly</para>
-<programlisting>SELECT f_table_name, f_geometry_column, srid, type
-	FROM geometry_columns
-	WHERE f_table_name = 'pois_ny';</programlisting>
-<screen>f_table_name | f_geometry_column | srid | type
-pois_ny      | geom              | 4326 | POINT
-pois_ny      | geom_2160         | 2160 | POINT</screen>
-<para>However -- if we were to create a view like this</para>
-<programlisting>CREATE VIEW vw_pois_ny_parks AS
-SELECT *
-  FROM pois_ny
-  WHERE cat='park';
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid02.png" />
+					</imageobject>
-SELECT f_table_name, f_geometry_column, srid, type
-	WHERE f_table_name = 'vw_pois_ny_parks';</programlisting>
-<para>The typmod based geom view column registers correctly,
-but the constraint based one does not.</para>
-<screen>   f_table_name   | f_geometry_column | srid |   type
- vw_pois_ny_parks | geom              | 4326 | POINT
- vw_pois_ny_parks | geom_2160         |    0 | GEOMETRY</screen>
+					<caption><para><emphasis role="bold">(i)</emphasis></para></caption>
+				  </mediaobject>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid03.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(j)</emphasis></para></caption>
+				  </mediaobject>
+			</row>
+			<row>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid04.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(k)</emphasis></para></caption>
+				  </mediaobject>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid05.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(l)</emphasis></para></caption>
+				  </mediaobject>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid06.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(m)</emphasis></para></caption>
+				  </mediaobject>
+			</row>
+		  </tbody>
+		</tgroup>
+	  </informaltable>
+	  <para>A <varname>MULTIPOLYGON</varname> is <emphasis>valid</emphasis> if:
+	  </para>
+        <orderedlist>
+        <listitem><para>
+        its element <varname>POLYGON</varname>s are valid
+        <listitem><para>
+        elements do not overlap (i.e. their interiors must not intersect)
+        <listitem><para>
+        elements touch only at points (i.e. not along a line)
+        </orderedlist>
+		<tgroup cols="1">
+		  <tbody>
+			<row>
+                <emphasis role="bold">(n)</emphasis> is a valid <varname>MULTIPOLYGON</varname>.
+				<emphasis role="bold">(o)</emphasis> and <emphasis role="bold">(p)</emphasis> are invalid.
+			</row>
+		  </tbody>
+		</tgroup>
+		  <tbody>
+			<row>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid09.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(n)</emphasis></para></caption>
+				  </mediaobject>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid07.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(o)</emphasis></para></caption>
+				  </mediaobject>
+				  <mediaobject>
+					<imageobject>
+					  <imagedata fileref="images/st_isvalid08.png" />
+					</imageobject>
+					<caption><para><emphasis role="bold">(p)</emphasis></para></caption>
+				  </mediaobject>
+			</row>
+		  </tbody>
+		</tgroup>
+	  </informaltable>
+	  <para>These rules mean that valid polygonal geometry is also <emphasis>simple</emphasis>.
+       </para>
+	<para>For linear geometry the only validity rule is that <varname>LINESTRING</varname>s must
+    have at least two points and have non-zero length
+    (or equivalently, have at least two distinct points.)
+    Note that non-simple (self-intersecting) lines are valid.
+    </para>
+<programlisting>
+SELECT
+   ST_IsValid('LINESTRING(0 0, 1 1)') AS len_nonzero,
+   ST_IsValid('LINESTRING(0 0, 0 0, 0 0)') AS len_zero,
+   ST_IsValid('LINESTRING(10 10, 150 150, 180 50, 20 130)') AS self_int;
+ len_nonzero | len_zero | self_int
+ t           | f        | t
+</programlisting>
+    <para><varname>POINT</varname> and <varname>MULTIPOINT</varname> geometries
+    have no validity rules.
+    </para>
+    </sect2>
+    <sect2 id="Managing_Validity">
+	  <title>Managing Validity</title>
+        <para>PostGIS allows creating and storing both valid and invalid Geometry.
+        This allows invalid geometry to be detected and flagged or fixed.
+        There are also situations where the OGC validity rules are stricter than desired
+        (examples of this are zero-length linestrings and polygons with inverted holes.)
+        </para>
+	  <para>Many of the functions provided by PostGIS rely on the
+	  assumption that geometry arguments are valid.
+      For example, it does not make sense to calculate the area of
+	  a polygon that has a hole defined outside of the polygon, or to construct
+	  a polygon from a non-simple boundary line.
+      Assuming valid geometric inputs allows functions to operate more efficiently,
+      since they do not need to check for topological correctness.
+      (Notable exceptions are that zero-length lines
+      and polygons with inversions are generally handled correctly.)
+      Also, most PostGIS functions produce valid geometry output if the inputs are valid.
+      This allows PostGIS functions to be chained together safely.
+      </para>
+	  <para>If you encounter unexpected error messages when calling PostGIS functions
+      (such as "GEOS Intersection() threw an error!"),
+      you should first confirm that the function arguments are valid.
+      If they are not, then consider using one of the techniques below to ensure
+      the data you are processing is valid.
+        </para>
+      <note><para>
+      If a function reports an error with valid inputs,
+      then you may have found an error in either PostGIS or one of
+		the libraries it uses, and you should report this to the PostGIS project.
+		The same is true if a PostGIS function returns an invalid geometry for
+		valid input.</para></note>
+	  <para>To test if a geometry is valid use the
+	  <xref linkend="ST_IsValid" /> function:
+      </para>
+<programlisting>
+SELECT ST_IsValid('POLYGON ((20 180, 180 180, 180 20, 20 20, 20 180))');
+ t
+</programlisting>
+	  <para>Information about the nature and location of an geometry invalidity are provided by
+	  the <xref linkend="ST_IsValidDetail" /> function:
+      </para>
+<programlisting>
+SELECT valid, reason, ST_AsText(location) AS location
+    FROM ST_IsValidDetail('POLYGON ((20 20, 120 190, 50 190, 170 50, 20 20))') AS t;
+ valid |      reason       |                  location
+ f     | Self-intersection | POINT(91.51162790697674 141.56976744186045)
+</programlisting>
+	  <para>In some situations it is desirable to correct invalid geometry automatically.
+	  Use the <xref linkend="ST_MakeValid" /> function to do this.
+      (<code>ST_MakeValid</code> is a case of a spatial function that <emphasis>does</emphasis> allow invalid input!)
+      </para>
+      <para>By default, PostGIS does not check for validity when loading geometry,
+	  because validity testing can take a lot of CPU time for complex
+	  geometries. If you do not trust your data sources,
+	  you can enforce a validity check on your tables by adding a check
+	  constraint:</para>
+	  <programlisting>ALTER TABLE mytable
+  ADD CONSTRAINT geometry_valid_check
+	CHECK (ST_IsValid(geom));</programlisting>
-<para>This may change in future versions of PostGIS, but for now
-to force the constraint-based view column to register correctly, you need to do this:</para>
-<programlisting>DROP VIEW vw_pois_ny_parks;
-CREATE VIEW vw_pois_ny_parks AS
-SELECT gid, poi_name, cat,
-  geom,
-  geom_2160::geometry(POINT,2160) As geom_2160
-  FROM pois_ny
-  WHERE cat = 'park';
- vw_pois_ny_parks | geom_2160         | 2160 | POINT</screen>
     </sect2>
 </sect1>
 <sect1 id="spatial_ref_sys">
 	<title>Spatial Reference Systems</title>
@@ -1326,375 +1507,280 @@ VALUES ( 990000,
 	</sect2>
 </sect1>
-<sect1 id="OGC_Validity">
-	  <title>Geometry Validation</title>
-	  <para>PostGIS is compliant with the Open Geospatial Consortium’s (OGC)
-	  OpenGIS Specifications.  As such, many PostGIS methods require, or more
-	  accurately, assume that geometries that are operated on are both simple
-	  and valid. For example, it does not make sense to calculate the area of
-	  a polygon that has a hole defined outside of the polygon, or to construct
-	  a polygon from a non-simple boundary line.</para>
-	  <para>According to the OGC Specifications, a <emphasis>simple</emphasis>
-	  geometry is one that has no anomalous geometric points, such as self
-	  intersection or self tangency and primarily refers to 0 or 1-dimensional
-	  geometries (i.e. <varname>[MULTI]POINT, [MULTI]LINESTRING</varname>).
-	  Geometry validity, on the other hand, primarily refers to 2-dimensional
-	  geometries (i.e. <varname>[MULTI]POLYGON)</varname> and defines the set
-	  of assertions that characterizes a valid polygon. The description of each
-	  geometric class includes specific conditions that further detail geometric
-	  simplicity and validity.</para>
-	  <para>A <varname>POINT</varname> is inherently <emphasis>simple</emphasis>
-	  as a 0-dimensional geometry object.</para>
-	  <para><varname>MULTIPOINT</varname>s are <emphasis>simple</emphasis> if
-	  no two coordinates (<varname>POINT</varname>s) are equal (have identical
-	  coordinate values).</para>
-	  <para>A <varname>LINESTRING</varname> is <emphasis>simple</emphasis> if
-	  it does not pass through the same point twice (except
-	  for the endpoints, in which case it is referred to as a Linear Ring and
-	  additionally considered <emphasis>closed</emphasis>).</para>
-	  <informaltable border="0" frame="none">
-		<tgroup cols="1">
-		  <tbody>
-			<row>
-				<entry><para><emphasis>
-                <emphasis role="bold">(a)</emphasis> and
-				<emphasis role="bold">(c)</emphasis> are simple	<varname>LINESTRING</varname>s.
-                <emphasis role="bold">(b)</emphasis> and <emphasis role="bold">(d)</emphasis> are not simple.
-                <emphasis role="bold">(c)</emphasis> is a closed Linear Ring.
-                </emphasis></para></entry>
-			</row>
-		  </tbody>
-		</tgroup>
-		<tgroup cols="2" align="center">
-		  <tbody>
-			<row>
-			  <entry><para><informalfigure>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple01.png" />
-					</imageobject>
-					<caption><para><emphasis role="bold">(a)</emphasis></para></caption>
-				  </mediaobject>
-				</informalfigure></para></entry>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple02.png" />
-					</imageobject>
-					<caption><para><emphasis role="bold">(b)</emphasis></para></caption>
-				  </mediaobject>
-			</row>
-			<row>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple03.png" />
-					</imageobject>
-					<caption><para><emphasis role="bold">(c)</emphasis></para></caption>
-				  </mediaobject>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple04.png" />
-					</imageobject>
-					<caption><para><emphasis role="bold">(d)</emphasis></para></caption>
-				  </mediaobject>
-			</row>
-		  </tbody>
-		</tgroup>
+<sect1>
+	<title>Spatial Tables</title>
-	  </informaltable>
+	<sect2 id="Create_Spatial_Table">
+	  <title>Creating a Spatial Table</title>
-	  <para>A <varname>MULTILINESTRING</varname> is <emphasis>simple</emphasis>
-	  only if all of its elements are simple and the only intersection between
-	  any two elements occurs at points that are on the
-	  boundaries of both elements.  </para>
+		<para>You can create a table to store geometry data using the
+        <ulink url="https://www.postgresql.org/docs/current/sql-createtable.html">CREATE TABLE</ulink>
+        SQL statement with a column of type <varname>geometry</varname>.
+        The following example creates a table with a geometry column storing 2D (XY) LineStrings
+        in the BC-Albers coordinate system (SRID 3005):</para>
-		<tgroup cols="1">
-		  <tbody>
-			<row>
-                <emphasis role="bold">(e)</emphasis> and
-				<emphasis role="bold">(f)</emphasis> are simple
-				<varname>MULTILINESTRING</varname>s.
-                <emphasis role="bold">(g)</emphasis> is not simple.
-			</row>
-		  </tbody>
-		</tgroup>
-		<tgroup cols="3" align="center">
-		  <tbody>
-			<row>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple05.png" />
-					</imageobject>
+<programlisting>CREATE TABLE roads (
+    id SERIAL PRIMARY KEY,
+    name VARCHAR(64),
+    geom geometry(LINESTRING,3005)
+  );</programlisting>
-					<caption><para><emphasis role="bold">(e)</emphasis></para></caption>
-				  </mediaobject>
+		<para>The <varname>geometry</varname> type supports two optional <emphasis role="bold">type modifiers</emphasis>:</para>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple06.png" />
-					</imageobject>
+        <itemizedlist>
+		<listitem>
+        <para>the <emphasis role="bold">spatial type modifier</emphasis>
+        restricts the kind of shapes and dimensions allowed in the column.
+		The value can be any of the supported
+        <link linkend="RefObject">geometry subtypes</link>
+        (e.g. POINT, LINESTRING, POLYGON, MULTIPOINT, MULTILINESTRING, MULTIPOLYGON, GEOMETRYCOLLECTION, etc).
+        The modifier supports coordinate dimensionality restrictions by adding suffixes: Z, M and ZM.
+        For example, a modifier of 'LINESTRINGM' allows only linestrings with three dimensions, and treats the third dimension as a measure.
+		Similarly, 'POINTZM' requires four dimensional (XYZM) data.
+        </para>
+		</listitem>
+		<listitem>
+        <para>the <emphasis role="bold">SRID modifier</emphasis> restricts the
+        <link linkend="spatial_ref_sys">spatial reference system</link> SRID to a particular number.
+        If omitted, the SRID defaults to 0.
+        </para>
+		</listitem>
+		</itemizedlist>
-					<caption><para><emphasis role="bold">(f)</emphasis></para></caption>
-				  </mediaobject>
+		<para></para>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_issimple07.png" />
-					</imageobject>
+        <para>Examples of creating tables with geometry columns:</para>
+		<itemizedlist>
+		<listitem>
+		  <para>Create a table holding any kind of geometry with the default SRID:</para>
+		  <para><programlisting>CREATE TABLE geoms(gid serial PRIMARY KEY, geom geometry );</programlisting></para>
+		</listitem>
+		<listitem>
+		  <para>Create a table with 2D POINT geometry with the default SRID:</para>
+		  <para><programlisting>CREATE TABLE pts(gid serial PRIMARY KEY, geom geometry(POINT) );</programlisting></para>
+		</listitem>
+		<listitem>
+		  <para>Create a table with 3D (XYZ) POINTs and an explicit SRID of 3005:</para>
+		  <para><programlisting>CREATE TABLE pts(gid serial PRIMARY KEY, geom geometry(POINTZ,3005) );</programlisting></para>
+		</listitem>
+		<listitem>
+			<para>Create a table with 4D (XYZM) LINESTRING geometry with the default SRID:</para>
+			<para><programlisting>CREATE TABLE lines(gid serial PRIMARY KEY, geom geometry(LINESTRINGZM) );</programlisting></para>
+		</listitem>
+		<listitem>
+			<para>Create a table with 2D POLYGON geometry with the SRID 4267 (NAD 1927 long lat):</para>
+			<para><programlisting>CREATE TABLE polys(gid serial PRIMARY KEY, geom geometry(POLYGON,4267) );</programlisting></para>
+		</listitem>
+		</itemizedlist>
-					<caption><para><emphasis role="bold">(g)</emphasis></para></caption>
-				  </mediaobject>
-			</row>
-		  </tbody>
-		</tgroup>
+	  <para>It is possible to have more than one geometry column in a table.
+        This can be specified when the table is created, or a column can be added using the
+        <ulink url="https://www.postgresql.org/docs/current/sql-altertable.html">ALTER TABLE</ulink>
+        SQL statement.
+        This example adds a column that can hold 3D LineStrings:</para>
-	  </informaltable>
+	  <programlisting>ALTER TABLE roads ADD COLUMN geom2 geometry(LINESTRINGZ,4326);</programlisting>
+	</sect2>
-      <para>A <varname>POLYGON</varname> is <emphasis>valid</emphasis> if:
-      </para>
+	<sect2 id="geometry_columns">
+	  <title>GEOMETRY_COLUMNS View</title>
-        <orderedlist>
-	    <listitem><para>
-        the polygon boundary rings (the exterior shell ring and interior hole rings)
-        are <emphasis>simple</emphasis> (do not cross or self-touch).
-        Because of this a polygon cannnot have cut lines or spikes.
-        </para></listitem>
-	    <listitem><para>
-        boundary rings do not cross
-	    <listitem><para>
-        boundary rings may touch at points but only as a tangent (i.e. not in a line)
-	    <listitem><para>
-        the interior rings are contained in the exterior ring
-	    <listitem><para>
-        the polygon interior is simply connected
-        (i.e. the interior rings must not split the polygon into more than one part)
-        </orderedlist>
+      <para>The OGC <emphasis>Simple Features Specification for SQL</emphasis> defines
+      the <varname>GEOMETRY_COLUMNS</varname> metadata table to describe geometry table structure.
+      In PostGIS <varname>geometry_columns</varname> is a view reading from database system catalog tables.
+      This ensures that the spatial metadata information is always consistent with the currently defined tables and views.
+	  The view structure is:</para>
-	  <para>These rules imply that valid <varname>POLYGON</varname>s are
-	  <emphasis>simple</emphasis> as well.
-       </para>
+	  <programlisting>\d geometry_columns</programlisting>
+<screen>             View "public.geometry_columns"
+      Column       |          Type          | Modifiers
+ f_table_catalog   | character varying(256) |
+ f_table_schema    | character varying(256) |
+ f_table_name      | character varying(256) |
+ f_geometry_column | character varying(256) |
+ coord_dimension   | integer                |
+ srid              | integer                |
+ type              | character varying(30)  |</screen>
-		<tgroup cols="1">
-		  <tbody>
-			<row>
-                <emphasis role="bold">(h)</emphasis> and
-				<emphasis role="bold">(i)</emphasis> are valid <varname>POLYGON</varname>s.
-                <emphasis role="bold">(j-m)</emphasis> are invalid.
-				<emphasis role="bold">(j)</emphasis>
-				could be represented as a valid <varname>MULTIPOLYGON</varname>.
-			</row>
-		  </tbody>
-		</tgroup>
-		  <tbody>
-			<row>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid01.png" />
-					</imageobject>
+	  <para>The columns are:</para>
-					<caption><para><emphasis role="bold">(h)</emphasis></para></caption>
-				  </mediaobject>
+	  <variablelist>
+		<varlistentry>
+		  <term>f_table_catalog, f_table_schema, f_table_name</term>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid02.png" />
-					</imageobject>
+		  <listitem>
+			<para>The fully qualified name of the feature table containing the
+			geometry column. There is no PostgreSQL analogue of "catalog" so that
+			column is left blank. For "schema" the PostgreSQL schema name is
+			used (<varname>public</varname> is the default).</para>
+		  </listitem>
+		</varlistentry>
-					<caption><para><emphasis role="bold">(i)</emphasis></para></caption>
-				  </mediaobject>
+		<varlistentry>
+		  <term>f_geometry_column</term>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid03.png" />
-					</imageobject>
+		  <listitem>
+			<para>The name of the geometry column in the feature table.</para>
+		  </listitem>
+		</varlistentry>
-					<caption><para><emphasis role="bold">(j)</emphasis></para></caption>
-				  </mediaobject>
-			</row>
-			<row>
+		<varlistentry>
+		  <term>coord_dimension</term>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid04.png" />
-					</imageobject>
+		  <listitem>
+			<para>The coordinate dimension (2, 3 or 4) of the column.</para>
+		  </listitem>
+		</varlistentry>
-					<caption><para><emphasis role="bold">(k)</emphasis></para></caption>
-				  </mediaobject>
+		<varlistentry>
+		  <term>srid</term>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid05.png" />
-					</imageobject>
+		  <listitem>
+			<para>The ID of the spatial reference system used for the
+			coordinate geometry in this table. It is a foreign key reference
+			to the <varname>spatial_ref_sys</varname> table
+            (see <xref linkend="spatial_ref_sys_table" />).</para>
+		  </listitem>
+		</varlistentry>
-					<caption><para><emphasis role="bold">(l)</emphasis></para></caption>
-				  </mediaobject>
+		<varlistentry>
+		  <term>type</term>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid06.png" />
-					</imageobject>
+		  <listitem>
+			<para>The type of the spatial object. To restrict the spatial
+			column to a single type, use one of: POINT, LINESTRING, POLYGON,
+			MULTIPOINT, MULTILINESTRING, MULTIPOLYGON, GEOMETRYCOLLECTION or
+			corresponding XYM versions POINTM, LINESTRINGM, POLYGONM,
+			MULTIPOINTM, MULTILINESTRINGM, MULTIPOLYGONM, GEOMETRYCOLLECTIONM.
+			For heterogeneous (mixed-type) collections, you can use "GEOMETRY"
+			as the type.</para>
+		  </listitem>
+		</varlistentry>
+	  </variablelist>
+	</sect2>
-					<caption><para><emphasis role="bold">(m)</emphasis></para></caption>
-				  </mediaobject>
-			</row>
-		  </tbody>
-		</tgroup>
-	  </informaltable>
+	  <sect2 id="Manual_Register_Spatial_Column">
+		<title>Manually Registering Geometry Columns</title>
-	  <para>A <varname>MULTIPOLYGON</varname> is <emphasis>valid</emphasis> if:
-	  </para>
+		<para>Two of the cases where you may need this are the case of SQL Views and bulk inserts.  For bulk insert case, you can correct the registration in the geometry_columns table
+		by constraining the column or doing an alter table.  For views, you could expose using a CAST operation.
+		Note, if your column is typmod based, the creation process would register it correctly, so no need to do anything.
+		Also views that have no spatial function applied to the geometry will register the same as the underlying table geometry column.</para>
-        <orderedlist>
-        <listitem><para>
-        its element <varname>POLYGON</varname>s are valid
-        <listitem><para>
-        elements do not overlap (have intersecting interiors)
-        <listitem><para>
-        elements touch only at points (i.e. not along a line)
-        </orderedlist>
+		<programlisting>-- Lets say you have a view created like this
+CREATE VIEW public.vwmytablemercator AS
+	SELECT gid, ST_Transform(geom, 3395) As geom, f_name
+	FROM public.mytable;
-		<tgroup cols="1">
-		  <tbody>
-			<row>
-                <emphasis role="bold">(n)</emphasis> is a valid <varname>MULTIPOLYGON</varname>.
-				<emphasis role="bold">(o)</emphasis> and <emphasis role="bold">(p)</emphasis> are not valid.
-			</row>
-		  </tbody>
-		</tgroup>
-		  <tbody>
-			<row>
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid09.png" />
-					</imageobject>
+-- For it to register correctly
+-- You need to cast the geometry
+DROP VIEW public.vwmytablemercator;
+	SELECT gid, ST_Transform(geom, 3395)::geometry(Geometry, 3395) As geom, f_name
-					<caption><para><emphasis role="bold">(n)</emphasis></para></caption>
-				  </mediaobject>
+-- If you know the geometry type for sure is a 2D POLYGON then you could do
+	SELECT gid, ST_Transform(geom,3395)::geometry(Polygon, 3395) As geom, f_name
+	FROM public.mytable;</programlisting>
+		<programlisting>--Lets say you created a derivative table by doing a bulk insert
+SELECT poi.gid, poi.geom, citybounds.city_name
+INTO myschema.my_special_pois
+FROM poi INNER JOIN citybounds ON ST_Intersects(citybounds.geom, poi.geom);
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid07.png" />
-					</imageobject>
+-- Create 2D index on new table
+CREATE INDEX idx_myschema_myspecialpois_geom_gist
+  ON myschema.my_special_pois USING gist(geom);
-					<caption><para><emphasis role="bold">(o)</emphasis></para></caption>
-				  </mediaobject>
+-- If your points are 3D points or 3M points,
+-- then you might want to create an nd index instead of a 2D index
+CREATE INDEX my_special_pois_geom_gist_nd
+	ON my_special_pois USING gist(geom gist_geometry_ops_nd);
-				  <mediaobject>
-					<imageobject>
-					  <imagedata fileref="images/st_isvalid08.png" />
-					</imageobject>
+-- To manually register this new table's geometry column in geometry_columns.
+-- Note it will also change the underlying structure of the table to
+-- to make the column typmod based.
+SELECT populate_geometry_columns('myschema.my_special_pois'::regclass);
-					<caption><para><emphasis role="bold">(p)</emphasis></para></caption>
-				  </mediaobject>
-			</row>
-		  </tbody>
-		</tgroup>
-	  </informaltable>
+-- If you are using PostGIS 2.0 and for whatever reason, you
+-- you need the constraint based definition behavior
+-- (such as case of inherited tables where all children do not have the same type and srid)
+-- set optional use_typmod argument to false
+SELECT populate_geometry_columns('myschema.my_special_pois'::regclass, false); </programlisting>
-	  <para>Most of the functions implemented by the GEOS library rely on the
-	  assumption that input geometries are valid as specified by the OpenGIS
-	  Simple Feature Specification. To check simplicity or validity of
-	  geometries you can use the <link linkend="ST_IsSimple">ST_IsSimple()</link> and
-	  <link linkend="ST_IsValid">ST_IsValid()</link></para>
-	  <programlisting>-- Typically, it doesn't make sense to check
--- for validity on linear features since it will always return TRUE.
--- But in this example, PostGIS extends the definition of the OGC IsValid
--- by returning false if a LineString has less than 2 *distinct* vertices.
-gisdb=# SELECT
-   ST_IsValid('LINESTRING(0 0, 1 1)'),
-   ST_IsValid('LINESTRING(0 0, 0 0, 0 0)');
- st_isvalid | st_isvalid
-      t     |     f</programlisting>
-	  <para>By default, PostGIS does not apply this validity check on geometry
-	  input, because testing for validity needs lots of CPU time for complex
-	  geometries, especially polygons. If you do not trust your data sources,
-	  you can manually enforce such a check to your tables by adding a check
-	  constraint:</para>
+<para>Although the old-constraint based method is still supported, a constraint-based geometry column used directly
+in a view, will not register correctly in geometry_columns, as will a typmod one.
+In this example we define a column using typmod and another using constraints.</para>
+<programlisting>CREATE TABLE pois_ny(gid SERIAL PRIMARY KEY, poi_name text, cat text, geom geometry(POINT,4326));
+SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2, false);</programlisting>
+<para>If we run in psql</para>
+<programlisting>\d pois_ny;</programlisting>
+<para>We observe they are defined differently -- one is typmod, one is constraint</para>
+<screen>                                  Table "public.pois_ny"
-	  <programlisting>ALTER TABLE mytable
-  ADD CONSTRAINT geometry_valid_check
-	CHECK (ST_IsValid(geom));</programlisting>
+ gid       | integer               | not null default nextval('pois_ny_gid_seq'::regclass)
+ poi_name  | text                  |
+ cat       | character varying(20) |
+ geom      | geometry(Point,4326)  |
+ geom_2160 | geometry              |
+Indexes:
+    "pois_ny_pkey" PRIMARY KEY, btree (gid)
+Check constraints:
+    "enforce_dims_geom_2160" CHECK (st_ndims(geom_2160) = 2)
+    "enforce_geotype_geom_2160" CHECK (geometrytype(geom_2160) = 'POINT'::text
+        OR geom_2160 IS NULL)
+    "enforce_srid_geom_2160" CHECK (st_srid(geom_2160) = 2160)</screen>
+<para>In geometry_columns, they both register correctly</para>
+<programlisting>SELECT f_table_name, f_geometry_column, srid, type
+	FROM geometry_columns
+	WHERE f_table_name = 'pois_ny';</programlisting>
+<screen>f_table_name | f_geometry_column | srid | type
+pois_ny      | geom              | 4326 | POINT
+pois_ny      | geom_2160         | 2160 | POINT</screen>
+<para>However -- if we were to create a view like this</para>
+<programlisting>CREATE VIEW vw_pois_ny_parks AS
+SELECT *
+  FROM pois_ny
+  WHERE cat='park';
-	  <para>If you encounter any strange error messages such as "GEOS
-	  Intersection() threw an error!" when calling PostGIS functions with valid
-		input geometries, you likely found an error in either PostGIS or one of
-		the libraries it uses, and you should contact the PostGIS developers.
-		The same is true if a PostGIS function returns an invalid geometry for
-		valid input.</para>
+SELECT f_table_name, f_geometry_column, srid, type
+	WHERE f_table_name = 'vw_pois_ny_parks';</programlisting>
+<para>The typmod based geom view column registers correctly,
+but the constraint based one does not.</para>
+<screen>   f_table_name   | f_geometry_column | srid |   type
+ vw_pois_ny_parks | geom              | 4326 | POINT
+ vw_pois_ny_parks | geom_2160         |    0 | GEOMETRY</screen>
-	  <note>
-		<para>The <link linkend="ST_IsValid">ST_IsValid()</link>
-        function does not check the Z and M dimensions.
-        </para>
-	  </note>
+<para>This may change in future versions of PostGIS, but for now
+to force the constraint-based view column to register correctly, you need to do this:</para>
+<programlisting>DROP VIEW vw_pois_ny_parks;
+CREATE VIEW vw_pois_ny_parks AS
+SELECT gid, poi_name, cat,
+  geom,
+  geom_2160::geometry(POINT,2160) As geom_2160
+  FROM pois_ny
+  WHERE cat = 'park';
+ vw_pois_ny_parks | geom_2160         | 2160 | POINT</screen>
+    </sect2>
 </sect1>
   <sect1 id="loading-data">
 	<title>Loading Spatial Data</title>
Summary of changes:
 doc/using_postgis_dataman.xml | 1214 ++++++++++++++++++++++-------------------
 1 file changed, 650 insertions(+), 564 deletions(-)
hooks/post-receive
