[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-474-g9416eb170
Thu Feb 3 11:04:30 PST 2022
the project "PostGIS".
       via  9416eb1705253f8365461f8050a7536b0a0ce060 (commit)
      from  2fca37fcdd2effe84595ec313fb0e378e7f48c4c (commit)
revisions in full, below.
commit 9416eb1705253f8365461f8050a7536b0a0ce060
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 3 20:04:03 2022 +0100
    Update doc/README documentation
    Add check and localization rules
    [ci skip]
diff --git a/doc/README b/doc/README
index 6a30eaaf4..246d5bfda 100644
--- a/doc/README
+++ b/doc/README
@@ -23,12 +23,20 @@ Make targets
 ``make html``
   generates a single-file ``html/postgis.html``
+``make html-localized``
+  generates single-file ``html/postgis-<lang>.html`` for
+  each supported language
 ``make chunked-html``
   generates a separate html file for every chapter or section break
 ``make pdf``
   generates a single PDF file with the PostGIS version as a filename
+``make pdf``
+  generates a single PDF file with the PostGIS version as a filename
+  and ``-<lang>`` suffix for each supported language
 ``make images``
   generates all the images used in the HTML and PDF targets
@@ -52,6 +60,18 @@ Make targets
 ``make maintainer-clean``
   removes all generated files (including comments)
+``make update-po``
+  update translation files to be in sync with the source
+  XML files. See ``make check-localized``
+``make check``
+  check structural correctness of XML documentation
+``make check-localized``
+  check structural correctness of localized (translated)
+  XML documentation. Remember to run this before committing
+  updates to translation files (see ``make update-po``)
 Requirements
@@ -71,6 +91,9 @@ To generate the developer's documentation:
  * Doxygen - http://www.stack.nl/~dimitri/doxygen/
  * Graphviz - http://www.graphviz.org/
+To generate the translated XML files:
+ * poxml - https://github.com/KDE/poxml
 How to
Summary of changes:
 doc/README | 23 +++++++++++++++++++++++
 1 file changed, 23 insertions(+)
hooks/post-receive
