[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-482-g6893c5422
Fri Feb 4 06:54:04 PST 2022
the project "PostGIS".
       via  6893c542220566e29445faf6b2de2b54aca77169 (commit)
      from  3878e2497790025ef5c08a6c9c71fefc8f17d687 (commit)
revisions in full, below.
commit 6893c542220566e29445faf6b2de2b54aca77169
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 4 15:53:39 2022 +0100
    Use modern (typmod, format) syntax in CreateTopology
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 6382b5b50..eaf6f8b8c 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1446,11 +1446,12 @@ CREATE CAST (topology.TopoGeometry AS Geometry) WITH FUNCTION topology.Geometry(
 CREATE OR REPLACE FUNCTION topology.CreateTopology(atopology varchar, srid integer, prec float8, hasZ boolean)
 RETURNS integer
 AS
+$BODY$
 DECLARE
   rec RECORD;
   topology_id integer;
-  ndims integer;
+  sql TEXT;
+  zsuffix TEXT := '';
 BEGIN
 --  FOR rec IN SELECT * FROM pg_namespace WHERE text(nspname) = atopology
@@ -1458,8 +1459,9 @@ BEGIN
 --    RAISE EXCEPTION 'SQL/MM Spatial exception - schema already exists';
 --  END LOOP;
-  ndims = 2;
-  IF hasZ THEN ndims = 3; END IF;
+  IF hasZ THEN
+    zsuffix := 'z';
+  END IF;
   IF srid < 0 THEN
     RAISE NOTICE 'SRID value % converted to the officially unknown SRID value 0', srid;
@@ -1475,232 +1477,295 @@ BEGIN
   EXECUTE 'CREATE SCHEMA ' || quote_ident(atopology);
   -------------{ face CREATION
-  EXECUTE
-  'CREATE TABLE ' || quote_ident(atopology) || '.face ('
-     'face_id SERIAL,'
-     ' CONSTRAINT face_primary_key PRIMARY KEY(face_id)'
-  -- Add mbr column to the face table
-  EXECUTE
-  'SELECT AddGeometryColumn('||quote_literal(atopology)
-  ||',''face'',''mbr'','||quote_literal(srid)
-  ||',''POLYGON'',2)'; -- 2d only mbr is good enough
+  sql := format(
+      CREATE TABLE %I.face(
+        face_id SERIAL,
+        mbr GEOMETRY(polygon%s, %L),
+        CONSTRAINT face_primary_key
+        PRIMARY KEY(face_id)
+    atopology,
+    zsuffix,
+    srid
+#ifdef POSTGIS_TOPOLOGY_DEBUG
+  RAISE DEBUG 'SQL: %', sql;
+#endif
+  EXECUTE sql;
   -- Face standard view description
-  EXECUTE 'COMMENT ON TABLE ' || quote_ident(atopology)
-    || '.face IS '
-       '''Contains face topology primitives''';
+  sql := format(
+      COMMENT ON TABLE %I.face IS
+      'Contains face topology primitives'
+    atopology
+#endif
+  EXECUTE sql;
   -------------} END OF face CREATION
   --------------{ node CREATION
-  EXECUTE
-  'CREATE TABLE ' || quote_ident(atopology) || '.node ('
-     'node_id SERIAL,'
-  --|| 'geom GEOMETRY,'
-     'containing_face INTEGER,'
-     'CONSTRAINT node_primary_key PRIMARY KEY(node_id),'
-  --|| 'CONSTRAINT node_geometry_type CHECK '
-  --|| '( GeometryType(geom) = ''POINT'' ),'
-     'CONSTRAINT face_exists FOREIGN KEY(containing_face) '
-     'REFERENCES ' || quote_ident(atopology) || '.face(face_id)'
-  -- Add geometry column to the node table
-  EXECUTE
-  ||',''node'',''geom'','||quote_literal(srid)
-  ||',''POINT'',' || ndims || ')';
+  sql := format(
+      CREATE TABLE %1$I.node(
+        node_id SERIAL,
+        geom GEOMETRY(point%3$s, %2$L),
+        containing_face INTEGER,
+        CONSTRAINT node_primary_key
+          PRIMARY KEY(node_id),
+        CONSTRAINT face_exists
+          FOREIGN KEY(containing_face)
+          REFERENCES %1$I.face(face_id)
+    atopology,
+    srid,
+    zsuffix
+#endif
+  EXECUTE sql;
   -- Node standard view description
-    || '.node IS '
-       '''Contains node topology primitives''';
+  sql := format(
+      COMMENT ON TABLE %I.node IS
+      'Contains node topology primitives'
+    atopology
+#endif
+  EXECUTE sql;
   --------------} END OF node CREATION
   --------------{ edge CREATION
   -- edge_data table
-  EXECUTE
-  'CREATE TABLE ' || quote_ident(atopology) || '.edge_data ('
-     'edge_id SERIAL NOT NULL PRIMARY KEY,'
-     'start_node INTEGER NOT NULL,'
-     'end_node INTEGER NOT NULL,'
-     'next_left_edge INTEGER NOT NULL,'
-     'abs_next_left_edge INTEGER NOT NULL,'
-     'next_right_edge INTEGER NOT NULL,'
-     'abs_next_right_edge INTEGER NOT NULL,'
-     'left_face INTEGER NOT NULL,'
-     'right_face INTEGER NOT NULL,'
-  --   'geom GEOMETRY NOT NULL,'
-  --   'CONSTRAINT edge_geometry_type CHECK '
-  --   '( GeometryType(geom) = ''LINESTRING'' ),'
-     'CONSTRAINT start_node_exists FOREIGN KEY(start_node)'
-     ' REFERENCES ' || quote_ident(atopology) || '.node(node_id),'
-     'CONSTRAINT end_node_exists FOREIGN KEY(end_node) '
-     'CONSTRAINT left_face_exists FOREIGN KEY(left_face) '
-     'REFERENCES ' || quote_ident(atopology) || '.face(face_id),'
-     'CONSTRAINT right_face_exists FOREIGN KEY(right_face) '
-     'CONSTRAINT next_left_edge_exists FOREIGN KEY(abs_next_left_edge)'
-  || '.edge_data(edge_id)'
-     ' DEFERRABLE INITIALLY DEFERRED,'
-     'CONSTRAINT next_right_edge_exists '
-     'FOREIGN KEY(abs_next_right_edge)'
-  || '.edge_data(edge_id) '
-     ' DEFERRABLE INITIALLY DEFERRED'
-  -- Add geometry column to the edge_data table
-  EXECUTE
-  ||',''edge_data'',''geom'','||quote_literal(srid)
-  ||',''LINESTRING'',' || ndims || ')';
+  sql := format(
+      CREATE TABLE %1$I.edge_data (
+        edge_id SERIAL NOT NULL PRIMARY KEY,
+        start_node INTEGER NOT NULL,
+        end_node INTEGER NOT NULL,
+        next_left_edge INTEGER NOT NULL,
+        abs_next_left_edge INTEGER NOT NULL,
+        next_right_edge INTEGER NOT NULL,
+        abs_next_right_edge INTEGER NOT NULL,
+        left_face INTEGER NOT NULL,
+        right_face INTEGER NOT NULL,
+        geom GEOMETRY(linestring%3$s, %2$L) NOT NULL,
+        CONSTRAINT start_node_exists
+          FOREIGN KEY(start_node)
+          REFERENCES %1$I.node(node_id),
+        CONSTRAINT end_node_exists
+          FOREIGN KEY(end_node)
+        CONSTRAINT left_face_exists
+          FOREIGN KEY(left_face)
+          REFERENCES %1$I.face(face_id),
+        CONSTRAINT right_face_exists
+          FOREIGN KEY(right_face)
+        CONSTRAINT next_left_edge_exists
+          FOREIGN KEY(abs_next_left_edge)
+          REFERENCES %1$I.edge_data(edge_id)
+          DEFERRABLE INITIALLY DEFERRED,
+        CONSTRAINT next_right_edge_exists
+          FOREIGN KEY(abs_next_right_edge)
+          REFERENCES %1$I .edge_data(edge_id)
+    atopology,
+    srid,
+    zsuffix
+#endif
+  EXECUTE sql;
   -- edge standard view (select rule)
-  EXECUTE 'CREATE VIEW ' || quote_ident(atopology)
-    || '.edge AS SELECT '
-       ' edge_id, start_node, end_node, next_left_edge, '
-       ' next_right_edge, '
-       ' left_face, right_face, geom FROM '
-    || quote_ident(atopology) || '.edge_data';
+  sql := format(
+      CREATE VIEW %1$I.edge AS
+      SELECT
+        edge_id, start_node, end_node, next_left_edge,
+        next_right_edge, left_face, right_face, geom
+      FROM %1$I.edge_data
+    atopology
+#endif
+  EXECUTE sql;
   -- Edge standard view description
-  EXECUTE 'COMMENT ON VIEW ' || quote_ident(atopology)
-    || '.edge IS '
-       '''Contains edge topology primitives''';
-  EXECUTE 'COMMENT ON COLUMN ' || quote_ident(atopology)
-    || '.edge.edge_id IS '
-       '''Unique identifier of the edge''';
-    || '.edge.start_node IS '
-       '''Unique identifier of the node at the start of the edge''';
-    || '.edge.end_node IS '
-       '''Unique identifier of the node at the end of the edge''';
-    || '.edge.next_left_edge IS '
-       '''Unique identifier of the next edge of the face on the left (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary''';
-    || '.edge.next_right_edge IS '
-       '''Unique identifier of the next edge of the face on the right (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary''';
-    || '.edge.left_face IS '
-       '''Unique identifier of the face on the left side of the edge when looking in the direction from START_NODE to END_NODE''';
-    || '.edge.right_face IS '
-       '''Unique identifier of the face on the right side of the edge when looking in the direction from START_NODE to END_NODE''';
-    || '.edge.geom IS '
-       '''The geometry of the edge''';
+  sql := format(
+  COMMENT ON VIEW %1$I.edge IS
+       'Contains edge topology primitives';
+  COMMENT ON COLUMN %1$I.edge.edge_id IS
+       'Unique identifier of the edge';
+  COMMENT ON COLUMN %1$I.edge.start_node IS
+       'Unique identifier of the node at the start of the edge';
+  COMMENT ON COLUMN %1$I.edge.end_node IS
+       'Unique identifier of the node at the end of the edge';
+  COMMENT ON COLUMN %1$I.edge.next_left_edge IS
+       'Unique identifier of the next edge of the face on the left (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary';
+  COMMENT ON COLUMN %1$I.edge.next_right_edge IS
+       'Unique identifier of the next edge of the face on the right (when looking in the direction from START_NODE to END_NODE), moving counterclockwise around the face boundary';
+  COMMENT ON COLUMN %1$I.edge.left_face IS
+       'Unique identifier of the face on the left side of the edge when looking in the direction from START_NODE to END_NODE';
+  COMMENT ON COLUMN %1$I.edge.right_face IS
+       'Unique identifier of the face on the right side of the edge when looking in the direction from START_NODE to END_NODE';
+  COMMENT ON COLUMN %1$I.edge.geom IS
+       'The geometry of the edge';
+    atopology
+#endif
+  EXECUTE sql;
   -- edge standard view (insert rule)
-  EXECUTE 'CREATE RULE edge_insert_rule AS ON INSERT '
-             'TO ' || quote_ident(atopology)
-    || '.edge DO INSTEAD '
-                   ' INSERT into ' || quote_ident(atopology)
-    || '.edge_data '
-                   ' VALUES (NEW.edge_id, NEW.start_node, NEW.end_node, '
-       ' NEW.next_left_edge, abs(NEW.next_left_edge), '
-       ' NEW.next_right_edge, abs(NEW.next_right_edge), '
-       ' NEW.left_face, NEW.right_face, NEW.geom);';
+  sql := format(
+      CREATE RULE edge_insert_rule AS
+      ON INSERT TO %1$I.edge
+      DO INSTEAD INSERT into %1$I.edge_data
+      VALUES (
+        NEW.edge_id, NEW.start_node, NEW.end_node,
+        NEW.next_left_edge, abs(NEW.next_left_edge),
+        NEW.next_right_edge, abs(NEW.next_right_edge),
+        NEW.left_face, NEW.right_face, NEW.geom
+    atopology
+#endif
+  EXECUTE sql;
   --------------} END OF edge CREATION
   --------------{ layer sequence
-  EXECUTE 'CREATE SEQUENCE '
-    || quote_ident(atopology) || '.layer_id_seq;';
+  sql := format(
+    'CREATE SEQUENCE %I.layer_id_seq',
+    atopology
+#endif
+  EXECUTE sql;
   --------------} layer sequence
   --------------{ relation CREATION
-  EXECUTE
-  'CREATE TABLE ' || quote_ident(atopology) || '.relation ('
-     ' topogeo_id integer NOT NULL, '
-     ' layer_id integer NOT NULL, '
-     ' element_id integer NOT NULL, '
-     ' element_type integer NOT NULL, '
-     ' UNIQUE(layer_id,topogeo_id,element_id,element_type));';
-  EXECUTE
-  'CREATE TRIGGER relation_integrity_checks '
-     'BEFORE UPDATE OR INSERT ON '
-  || quote_ident(atopology) || '.relation FOR EACH ROW '
-     ' EXECUTE PROCEDURE topology.RelationTrigger('
-  ||topology_id||','||quote_literal(atopology)||')';
+  sql := format(
+      CREATE TABLE %1$I.relation (
+        topogeo_id integer NOT NULL,
+        layer_id integer NOT NULL,
+        element_id integer NOT NULL,
+        element_type integer NOT NULL,
+        UNIQUE(layer_id,topogeo_id,element_id,element_type)
+    atopology
+#endif
+  EXECUTE sql;
+  sql := format(
+      CREATE TRIGGER relation_integrity_checks
+      BEFORE UPDATE OR INSERT ON %1$I.relation
+      FOR EACH ROW EXECUTE PROCEDURE
+      topology.RelationTrigger(%2$L, %1$L)
+    atopology,
+    topology_id
+#endif
+  EXECUTE sql;
   --------------} END OF relation CREATION
   ------- Default (world) face
-  EXECUTE 'INSERT INTO ' || quote_ident(atopology) || '.face(face_id) VALUES(0);';
+  EXECUTE format('INSERT INTO %I.face(face_id) VALUES(0)', atopology);
   ------- GiST index on face
-  EXECUTE 'CREATE INDEX face_gist ON '
-    || '.face using gist (mbr);';
+  EXECUTE format($$
+    CREATE INDEX face_gist ON %1$I.face
+    USING gist (mbr)
+  $$, atopology);
   ------- GiST index on node
-  EXECUTE 'CREATE INDEX node_gist ON '
-    || '.node using gist (geom);';
+  EXECUTE format($$
+    CREATE INDEX node_gist ON %1$I.node
+    USING gist (geom)
+  $$, atopology);
   ------- GiST index on edge
-  EXECUTE 'CREATE INDEX edge_gist ON '
-    || '.edge_data using gist (geom);';
+  EXECUTE format($$
+    CREATE INDEX edge_gist ON %1$I.edge_data
+    USING gist (geom)
+  $$, atopology);
   ------- Indexes on left_face and right_face of edge_data
   ------- NOTE: these indexes speed up GetFaceGeometry (and thus
   -------       TopoGeometry::Geometry) by a factor of 10 !
   -------       See http://trac.osgeo.org/postgis/ticket/806
-  EXECUTE 'CREATE INDEX edge_left_face_idx ON '
-    || '.edge_data (left_face);';
-  EXECUTE 'CREATE INDEX edge_right_face_idx ON '
-    || '.edge_data (right_face);';
+  EXECUTE format($$
+    CREATE INDEX edge_left_face_idx
+      ON %1$I.edge_data (left_face);
+    CREATE INDEX edge_right_face_idx
+      ON %1$I.edge_data (right_face);
+  $$, atopology);
   ------- Indexes on start_node and end_node of edge_data
   ------- NOTE: this indexes speed up node deletion
   -------       by a factor of 1000 !
   -------       See http://trac.osgeo.org/postgis/ticket/2082
-  EXECUTE 'CREATE INDEX edge_start_node_idx ON '
-    || '.edge_data (start_node);';
-  EXECUTE 'CREATE INDEX edge_end_node_idx ON '
-    || '.edge_data (end_node);';
+  EXECUTE format($$
+    CREATE INDEX edge_start_node_idx
+      ON %1$I.edge_data (start_node);
+    CREATE INDEX edge_end_node_idx
+      ON %1$I.edge_data (end_node);
+  $$, atopology);
   -- TODO: consider also adding an index on node.containing_face
   ------- Add record to the "topology" metadata table
-  EXECUTE 'INSERT INTO topology.topology '
-    || '(id, name, srid, precision, hasZ) VALUES ('
-    || quote_literal(topology_id) || ','
-    || quote_literal(atopology) || ','
-    || quote_literal(srid) || ',' || quote_literal(prec)
-    || ',' || hasZ
+  INSERT INTO topology.topology (id, name, srid, precision, hasZ)
+  VALUES (topology_id, atopology, srid, prec, hasZ);
   RETURN topology_id;
 END
+$BODY$
 LANGUAGE 'plpgsql' VOLATILE STRICT;
 --} CreateTopology
Summary of changes:
 topology/topology.sql.in | 417 +++++++++++++++++++++++++++--------------------
 1 file changed, 241 insertions(+), 176 deletions(-)
hooks/post-receive
