[postgis-tickets] [SCM] PostGIS branch spatial-ref-sys-view updated. 3.2.0-484-g7306f765a
Fri Feb 4 08:16:29 PST 2022
the project "PostGIS".
The branch, spatial-ref-sys-view has been updated
       via  7306f765ac14f1d185afb2815708c0ccc7436764 (commit)
      from  b1e20a73d0d01b07e46a39f26ba8a52347191204 (commit)
revisions in full, below.
commit 7306f765ac14f1d185afb2815708c0ccc7436764
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Feb 4 17:15:56 2022 +0100
    Have spatial_ref_sys.sql drop user entries matching system ones
    Reduces amount of overrides upon upgrade
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index b69bf44d5..e0be27b27 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -24,8 +24,8 @@ DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
 DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
--- Delete all custom SRIDs
+-- Delete ONLY the custom SRIDs
 -- TODO: do something smarter like making a copy of
 --       them somewhere for tests to run some tests
 --       on them...
-DELETE FROM spatial_ref_sys_user;
+DELETE FROM spatial_ref_sys_user WHERE SRID = 909090;
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 046d5c730..7b3a7c3a3 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -88,5 +88,15 @@ UPDATE pg_proc SET probin = probin || '-uninstalled'
 WHERE probin like '%postgis%';
 -- Insert a custom SRID to spatial_ref_sys
+-- NOTE: we're assuming 909090 never existed as a system srid
 INSERT INTO spatial_ref_sys(srid,auth_name,auth_srid,srtext,proj4text)
-VALUES (900100, 'pgis_test', 2, 'srtext', 'prjtext');
+VALUES (909090, 'pgis_test', 2, 'srtext', 'prjtext');
+-- Insert a SRID which is known to be in current postgis version
+-- (and ideally not available in older version)
+WITH recent_entry ("srid","auth_name","auth_srid","srtext","proj4text")
+AS (
+	VALUES (103971,'ESRI',103971,'PROJCS["NAD_1983_HARN_Adj_WI_Wood_Feet (deprecated)",GEOGCS["GCS_NAD_1983_HARN_Adj_WI_Wood (deprecated)",DATUM["D_NAD_1983_HARN_Adj_WI_WD",SPHEROID["GRS_1980_Adj_WI_WD",6378437.651,298.271281273316,AUTHORITY["ESRI","107850"]],AUTHORITY["ESRI","106850"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["ESRI","104871"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["latitude_of_origin",43.1513888888889],PARAMETER["central_meridian",-90],PARAMETER["standard_parallel_1",44.1805555555556],PARAMETER["standard_parallel_2",44.5444444444444],PARAMETER["false_easting",684000],PARAMETER["false_northing",0],UNIT["US survey foot",0.304800609601219,AUTHORITY["EPSG","9003"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["ESRI","103971"]]','+proj=lcc +lat_0=43.1513888888889 +lon_0=-90 +lat_1=44.1805555555556 +lat_2=44.5444444444444 +x_0=208483.616967234 +y_0=0 +a=6378437.651 +rf=298.2712
 81273316 +units=us-ft +no_defs')
+INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text")
+SELECT * FROM recent_entry r
+WHERE NOT EXISTS (SELECT 1 FROM spatial_ref_sys WHERE srid = r.srid );
diff --git a/spatial_ref_sys.sql b/spatial_ref_sys.sql
index a35a533b9..0bf1b1ae0 100644
--- a/spatial_ref_sys.sql
+++ b/spatial_ref_sys.sql
@@ -34299,5 +34299,24 @@ INSERT INTO "spatial_ref_sys_postgis" ("srid","auth_name","auth_srid","srtext","
 INSERT INTO "spatial_ref_sys_postgis" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (103971,'ESRI',103971,'PROJCS["NAD_1983_HARN_Adj_WI_Wood_Feet (deprecated)",GEOGCS["GCS_NAD_1983_HARN_Adj_WI_Wood (deprecated)",DATUM["D_NAD_1983_HARN_Adj_WI_WD",SPHEROID["GRS_1980_Adj_WI_WD",6378437.651,298.271281273316,AUTHORITY["ESRI","107850"]],AUTHORITY["ESRI","106850"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["ESRI","104871"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["latitude_of_origin",43.1513888888889],PARAMETER["central_meridian",-90],PARAMETER["standard_parallel_1",44.1805555555556],PARAMETER["standard_parallel_2",44.5444444444444],PARAMETER["false_easting",684000],PARAMETER["false_northing",0],UNIT["US survey foot",0.304800609601219,AUTHORITY["EPSG","9003"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["ESRI","103971"]]','+proj=lcc +lat_0=43.1513888888889 +lon_0=-90 +lat_1=44.180
 5555555556 +lat_2=44.5444444444444 +x_0=208483.616967234 +y_0=0 +a=6378437.651 +rf=298.271281273316 +units=us-ft +no_defs');
+-- Drop entries from user table not marked
+-- as "force_keep_on_upgrade" if an identical
+-- entry is found in the system table
+WITH equal_entries AS (
+  SELECT s.srid
+	FROM spatial_ref_sys_postgis s
+	JOIN spatial_ref_sys_user u
+		ON (
+			u.srid = s.srid AND
+			u.auth_name = s.auth_name AND
+			u.auth_srid = s.auth_srid AND
+			u.srtext = s.srtext AND
+			u.proj4text = s.proj4text
+WHERE SRID IN ( SELECT srid FROM equal_entries )
 COMMIT;
 ANALYZE spatial_ref_sys_postgis;
Summary of changes:
 regress/hooks/hook-after-upgrade.sql  |  4 ++--
 regress/hooks/hook-before-upgrade.sql | 12 +++++++++++-
 spatial_ref_sys.sql                   | 19 +++++++++++++++++++
 3 files changed, 32 insertions(+), 3 deletions(-)
hooks/post-receive
