[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-502-gcff010336
Sun Feb 6 12:20:28 PST 2022
the project "PostGIS".
       via  cff01033637ddcf984d12edbbecc9f70b0e4de4e (commit)
      from  5f8782f02d7533cf5e947f65e8c6d05ed8be5e1d (commit)
revisions in full, below.
commit cff01033637ddcf984d12edbbecc9f70b0e4de4e
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Feb 5 01:27:06 2022 +0100
    Have postgis_extensions_upgrade set extversion to ANY prior to update
    This allows upgrading from any version of PostGIS even if no
    specific upgrade script exists on disk (which often happens as
    we support multiple stable branches).
diff --git a/NEWS b/NEWS
index 5d22df3aa..5a13ae0a7 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.3.0dev
  * Enhancements *
+  - postgis_extensions_upgrade() support for upgrades from any PostGIS
+    version, including yet to be released ones (Sandro Santilli)
   - #5037, add convexhull 3D (Loïc Bartoletti)
   - #5040, add postgis_sfcgal_full_version (Loïc Bartoletti)
   - GH655, GiST: balance the tree splits better in recursive calls (Darafei Praliaskouski)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index d3450bbf2..a6c2060d9 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3034,28 +3034,16 @@ BEGIN
 			ELSE
 				RAISE DEBUG 'Skipping % (not in use)', rec.name;
 			END IF;
-		ELSIF target_version != rec.installed_version
-		THEN --}{
-			sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' ||
-						quote_ident(target_version)   || ';';
+		ELSE -- IF target_version != rec.installed_version THEN --}{
+			sql = format(
+				'UPDATE pg_catalog.pg_extension SET extversion = ''ANY'' WHERE extname = %1$L;'
+				'ALTER EXTENSION %1$I UPDATE TO %2$I',
+				rec.name, target_version
 			RAISE NOTICE 'Updating extension % %',
 				rec.name, rec.installed_version;
 			RAISE DEBUG '%', sql;
 			EXECUTE sql;
-		ELSIF (target_version = rec.installed_version AND rec.installed_version ILIKE '%dev') OR
-			(@extschema at ._postgis_pgsql_version() != @extschema at ._postgis_scripts_pgsql_version())
-		THEN --}{
-			-- we need to upgrade to next and back
-			RAISE NOTICE 'Updating extension % % (self refresh)',
-				rec.name, rec.installed_version;
-						quote_ident(target_version || 'next')   || ';';
-			RAISE DEBUG '%', sql;
-			EXECUTE sql;
-			EXECUTE sql;
 		END IF; --}
 	END LOOP; --}
Summary of changes:
 NEWS                   |  2 ++
 postgis/postgis.sql.in | 24 ++++++------------------
 2 files changed, 8 insertions(+), 18 deletions(-)
hooks/post-receive
