[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-504-g05d3150c9
Sun Feb 6 12:52:50 PST 2022
the project "PostGIS".
       via  05d3150c9222bd781871e627cf5b3973d18bcfc2 (commit)
      from  cf3f416ed80628142c498d80d846a22d4cb7a2e9 (commit)
revisions in full, below.
commit 05d3150c9222bd781871e627cf5b3973d18bcfc2
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Feb 6 21:51:46 2022 +0100
    Update translation files after documentation fix
diff --git a/doc/po/de/reference_output.xml.po b/doc/po/de/reference_output.xml.po
index de3c93a7c..cbf0dd2b6 100644
--- a/doc/po/de/reference_output.xml.po
+++ b/doc/po/de/reference_output.xml.po
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2022-02-06 07:55+0000\n"
+"POT-Creation-Date: 2022-02-06 20:51+0000\n"
 "PO-Revision-Date: 2022-01-19 08:46+0000\n"
 "Last-Translator: Sandro Santilli <strk at kbt.io>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
@@ -81,7 +81,7 @@ msgstr ""
 #: reference_output.xml:694 reference_output.xml:808 reference_output.xml:871
 #: reference_output.xml:939 reference_output.xml:1015 reference_output.xml:1093
 #: reference_output.xml:1146 reference_output.xml:1194
-#: reference_output.xml:1328
+#: reference_output.xml:1333
 #, no-c-format
 msgid "Description"
 msgstr "Beschreibung"
@@ -157,7 +157,7 @@ msgstr "&Z_support;"
 #. Tag: para
 #: reference_output.xml:74 reference_output.xml:160 reference_output.xml:249
-#: reference_output.xml:315 reference_output.xml:368 reference_output.xml:1342
+#: reference_output.xml:315 reference_output.xml:368 reference_output.xml:1347
 #, no-c-format
 msgid "&curve_support;"
 msgstr "&curve_support;"
@@ -182,7 +182,7 @@ msgstr "&T_support;"
 #: reference_output.xml:509 reference_output.xml:616 reference_output.xml:844
 #: reference_output.xml:900 reference_output.xml:959 reference_output.xml:1055
 #: reference_output.xml:1112 reference_output.xml:1161
-#: reference_output.xml:1346
+#: reference_output.xml:1351
 #, no-c-format
 msgid "Examples"
 msgstr "Beispiele"
@@ -234,7 +234,7 @@ msgstr ""
 #: reference_output.xml:330 reference_output.xml:424 reference_output.xml:639
 #: reference_output.xml:773 reference_output.xml:848 reference_output.xml:964
 #: reference_output.xml:1061 reference_output.xml:1170
-#: reference_output.xml:1350
+#: reference_output.xml:1355
 #, no-c-format
 msgid "See Also"
 msgstr "Siehe auch"
@@ -3283,12 +3283,20 @@ msgstr ""
 msgid "PostGIS buildings"
 msgstr ""
-#. Tag: programlisting
+#. Tag: para
 #: reference_output.xml:1286
 #, no-c-format
 msgid ""
-"<![CDATA[SELECT string_agg('<Shape>' || ST_AsX3D(ST_Extrude(geom, 0,0, i*4)) "
-"||\n"
+"Copy and paste the output of this query to <ulink url=\"http://postgis.net/"
+"docs/support/viewers/x3d_viewer.htm\">x3d scene viewer</ulink> and click Show"
+msgstr ""
+#. Tag: programlisting
+#: reference_output.xml:1291
+#, no-c-format
+msgid ""
+"<![CDATA[SELECT string_agg('<Shape>' || ST_AsX3D(ST_Extrude(geom, 0,0, "
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
 "          <Material diffuseColor=\"' || (0.01*i)::text || ' 0.8 0.2\" "
 "specularColor=\"' || (0.05*i)::text || ' 0 0.5\"/>\n"
@@ -3298,13 +3306,13 @@ msgid ""
 msgstr ""
 #. Tag: para
-#: reference_output.xml:1292
+#: reference_output.xml:1297
 #, no-c-format
 msgid "Buildings formed by subdividing PostGIS and extrusion"
 msgstr ""
 #. Tag: title
-#: reference_output.xml:1297
+#: reference_output.xml:1302
 #, no-c-format
 msgid "Example: An Octagon elevated 3 Units and decimal precision of 6"
 msgstr ""
@@ -3312,7 +3320,7 @@ msgstr ""
 "Genauigkeit von 6"
-#: reference_output.xml:1298
+#: reference_output.xml:1303
 #, no-c-format
 msgid ""
 "SELECT ST_AsX3D(\n"
@@ -3344,13 +3352,13 @@ msgstr ""
 "</IndexedFaceSet>]]>"
 #. Tag: title
-#: reference_output.xml:1301
+#: reference_output.xml:1306
 #, no-c-format
 msgid "Example: TIN"
 msgstr "Beispiel: TIN"
-#: reference_output.xml:1302
+#: reference_output.xml:1307
 #, no-c-format
 msgid ""
 "<![CDATA[SELECT ST_AsX3D(ST_GeomFromEWKT('TIN (((\n"
@@ -3390,7 +3398,7 @@ msgstr ""
 "0 1 0 1 0 0 0 0 0 1 0 1 1 0'/></IndexedTriangleSet>]]>"
 #. Tag: title
-#: reference_output.xml:1305
+#: reference_output.xml:1310
 #, no-c-format
 msgid "Example: Closed multilinestring (the boundary of a polygon with holes)"
 msgstr ""
@@ -3398,7 +3406,7 @@ msgstr ""
 "Lücken)"
-#: reference_output.xml:1306
+#: reference_output.xml:1311
 #, no-c-format
 msgid ""
 "<![CDATA[SELECT ST_AsX3D(\n"
@@ -3434,19 +3442,19 @@ msgstr ""
 " </IndexedLineSet>]]>"
 #. Tag: refname
-#: reference_output.xml:1312
+#: reference_output.xml:1317
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
-#: reference_output.xml:1314
+#: reference_output.xml:1319
 #, no-c-format
 msgid "Return a GeoHash representation of the geometry."
 msgstr "Gibt die Geometrie in der GeoHash Darstellung aus."
 #. Tag: funcprototype
-#: reference_output.xml:1319
+#: reference_output.xml:1324
 #, no-c-format
 msgid ""
 "<funcdef>text <function>ST_GeoHash</function></funcdef> "
@@ -3460,7 +3468,7 @@ msgstr ""
 "<parameter>maxchars=full_precision_of_point</parameter></paramdef>"
 #. Tag: para
-#: reference_output.xml:1330
+#: reference_output.xml:1335
 #, no-c-format
 msgid ""
 "Return a GeoHash representation (<ulink url=\"http://en.wikipedia.org/wiki/"
@@ -3477,7 +3485,7 @@ msgstr ""
 "eine Box vorstellen, welche den tatsächlichen Punkt enthält."
 #. Tag: para
-#: reference_output.xml:1332
+#: reference_output.xml:1337
 #, no-c-format
 msgid ""
 "If no <varname>maxchars</varname> is specified ST_GeoHash returns a GeoHash "
@@ -3500,7 +3508,7 @@ msgstr ""
 "Box immer das gegebene Geoobjekt beinhaltet."
 #. Tag: para
-#: reference_output.xml:1334
+#: reference_output.xml:1339
 #, no-c-format
 msgid ""
 "If <varname>maxchars</varname> is specified ST_GeoHash returns a GeoHash "
@@ -3515,13 +3523,13 @@ msgstr ""
 "Berechnung im Mittelpunkt des Umgebungsrechtecks der Geometrie."
 #. Tag: para
-#: reference_output.xml:1336
+#: reference_output.xml:1341
 #, no-c-format
 msgid "Availability: 1.4.0"
 msgstr "Verfügbarkeit: 1.4.0"
 #. Tag: para
-#: reference_output.xml:1339
+#: reference_output.xml:1344
 #, no-c-format
 msgid ""
 "ST_GeoHash will not work with geometries that are not in geographic (lon/"
@@ -3531,7 +3539,7 @@ msgstr ""
 "(Länge/Breite) Koordinaten vorliegen."
-#: reference_output.xml:1347
+#: reference_output.xml:1352
 #, no-c-format
 msgid ""
 "<![CDATA[SELECT ST_GeoHash(ST_SetSRID(ST_Point(-126,48),4326));\n"
diff --git a/doc/po/es/reference_output.xml.po b/doc/po/es/reference_output.xml.po
index ed641e806..a9a09ef09 100644
--- a/doc/po/es/reference_output.xml.po
+++ b/doc/po/es/reference_output.xml.po
@@ -7,7 +7,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2021-11-28 22:06+0000\n"
 "Last-Translator: Regina Obe\n"
 "Language-Team: Spanish (http://www.transifex.com/postgis/postgis/language/"
@@ -77,7 +77,7 @@ msgstr ""
 #, no-c-format
 msgid "Description"
 msgstr "Descripción"
@@ -151,7 +151,7 @@ msgstr "&Z_support;"
 #. Tag: para
 #, no-c-format
@@ -176,7 +176,7 @@ msgstr "&T_support;"
 #, no-c-format
 msgid "Examples"
 msgstr "Ejemplos"
@@ -210,7 +210,7 @@ msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr "Ver también"
@@ -2580,12 +2580,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -2595,19 +2603,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2626,13 +2634,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "Ejemplo: TIN"
 #, no-c-format
 msgid ""
@@ -2655,13 +2663,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2682,19 +2690,19 @@ msgid ""
 msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2704,7 +2712,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2715,7 +2723,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2729,7 +2737,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2739,13 +2747,13 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr "Disponibilidad: 1.4.0"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2753,7 +2761,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
diff --git a/doc/po/fr/reference_output.xml.po b/doc/po/fr/reference_output.xml.po
index 30b0e7945..625cada02 100644
--- a/doc/po/fr/reference_output.xml.po
+++ b/doc/po/fr/reference_output.xml.po
@@ -8,7 +8,7 @@ msgid ""
 msgstr ""
 "Language-Team: French (http://www.transifex.com/postgis/postgis/language/"
@@ -78,7 +78,7 @@ msgstr ""
 #, no-c-format
 msgid "Description"
 msgstr "Description"
@@ -152,7 +152,7 @@ msgstr "&Z_support;"
 #. Tag: para
 #, no-c-format
@@ -177,7 +177,7 @@ msgstr "&T_support;"
 #, no-c-format
 msgid "Examples"
 msgstr "Exemples"
@@ -229,7 +229,7 @@ msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr "Voir aussi"
@@ -2657,12 +2657,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -2672,19 +2680,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2703,13 +2711,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2732,13 +2740,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2759,19 +2767,19 @@ msgid ""
 msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2785,7 +2793,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2796,7 +2804,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2810,7 +2818,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2820,13 +2828,13 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr "Disponibilité: 1.4.0"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2834,7 +2842,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
diff --git a/doc/po/it_IT/reference_output.xml.po b/doc/po/it_IT/reference_output.xml.po
index eac47bcd2..71bd02c45 100644
--- a/doc/po/it_IT/reference_output.xml.po
+++ b/doc/po/it_IT/reference_output.xml.po
 msgstr ""
 "PO-Revision-Date: 2022-01-19 00:27+0000\n"
 "Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
 #, no-c-format
 msgid "Description"
 msgstr "Descrizione"
 #. Tag: para
 #, no-c-format
 #, no-c-format
 msgid "Examples"
 msgstr "Esempi"
 #, no-c-format
 msgid "See Also"
 msgstr "Si veda anche"
@@ -2671,12 +2671,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -2686,19 +2694,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2730,13 +2738,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "Esempio: TIN"
 #, no-c-format
 msgid ""
@@ -2759,13 +2767,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2786,19 +2794,19 @@ msgid ""
 msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2812,7 +2820,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2823,7 +2831,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2837,7 +2845,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2847,13 +2855,13 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr "Disponibilità: 1.4.0"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2861,7 +2869,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
diff --git a/doc/po/ja/reference_output.xml.po b/doc/po/ja/reference_output.xml.po
index 32b9256f8..7112bde5e 100644
--- a/doc/po/ja/reference_output.xml.po
+++ b/doc/po/ja/reference_output.xml.po
@@ -5,7 +5,7 @@ msgid ""
 msgstr ""
 "PO-Revision-Date: 2022-01-31 10:53+0000\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
@@ -91,7 +91,7 @@ msgstr ""
 #, no-c-format
 msgid "Description"
 msgstr "説明"
@@ -179,7 +179,7 @@ msgstr "&Z_support;"
 #. Tag: para
 #, no-c-format
@@ -204,7 +204,7 @@ msgstr "&T_support;"
 #, no-c-format
 msgid "Examples"
 msgstr "例"
@@ -256,7 +256,7 @@ msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr "関連情報"
@@ -3401,12 +3401,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -3416,19 +3424,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "例: 高さ3単位で精度が6桁の八角柱"
 #, no-c-format
 msgid ""
@@ -3460,13 +3468,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "例: TIN"
 #, no-c-format
 msgid ""
@@ -3506,13 +3514,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "例: 閉じたラインストリング (穴のあるポリゴンの境界)"
 #, no-c-format
 msgid ""
@@ -3548,19 +3556,19 @@ msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
 #, no-c-format
 msgstr "ジオメトリのGeoHash表現を返します。"
 #, no-c-format
 msgid ""
@@ -3574,7 +3582,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3590,7 +3598,7 @@ msgstr ""
 "られます。"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3610,7 +3618,7 @@ msgstr ""
 "れます。GeoHashが含むボックスは常に入力フィーチャーを含むようにしています。"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3623,13 +3631,13 @@ msgstr ""
 "以外では、計算の開始点はジオメトリのバウンディングボックスの中心となります。"
 #. Tag: para
 #, no-c-format
 msgstr "Availability: 1.4.0"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3637,7 +3645,7 @@ msgid ""
 msgstr "ST_GeoHashはジオグラフィ (経度緯度)座標系では動作しません。"
 #, no-c-format
 msgid ""
diff --git a/doc/po/ko_KR/reference_output.xml.po b/doc/po/ko_KR/reference_output.xml.po
index 959fba6d6..cc1017516 100644
--- a/doc/po/ko_KR/reference_output.xml.po
+++ b/doc/po/ko_KR/reference_output.xml.po
 msgstr ""
 "Language-Team: Korean (Korea) (http://www.transifex.com/postgis/postgis/"
 #, no-c-format
 msgid "Description"
 msgstr "설명"
@@ -154,7 +154,7 @@ msgstr "&Z_support;"
 #. Tag: para
 #, no-c-format
@@ -179,7 +179,7 @@ msgstr "&T_support;"
 #, no-c-format
 msgid "Examples"
 msgstr "예시"
@@ -231,7 +231,7 @@ msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr "참고"
@@ -3027,12 +3027,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -3042,19 +3050,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "예시: 소수점 정밀도 6이며 3단위 상승한  팔각형"
 #, no-c-format
 msgid ""
@@ -3086,13 +3094,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "예시: TIN"
 #, no-c-format
 msgid ""
@@ -3132,13 +3140,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "예시: 닫힌 멀티라인스트링(구멍을 가진 폴리곤의 경계선)"
 #, no-c-format
 msgid ""
@@ -3174,19 +3182,19 @@ msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
 #, no-c-format
 msgstr "도형의 GeoHash 표현식을 반환합니다."
 #, no-c-format
 msgid ""
@@ -3200,7 +3208,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3216,7 +3224,7 @@ msgstr ""
 "제 포인트를 담고 있는 상자로 생각할 수도 있습니다."
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3237,7 +3245,7 @@ msgstr ""
 "는 가정 때문입니다."
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3251,13 +3259,13 @@ msgstr ""
 "합니다."
 #. Tag: para
 #, no-c-format
 msgstr "1.4.0 버전부터 사용할 수 있습니다."
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3267,7 +3275,7 @@ msgstr ""
 "다."
 #, no-c-format
 msgid ""
diff --git a/doc/po/pl/reference_output.xml.po b/doc/po/pl/reference_output.xml.po
index 0882e8814..7ed8aa56d 100644
--- a/doc/po/pl/reference_output.xml.po
+++ b/doc/po/pl/reference_output.xml.po
 msgstr ""
 "Language-Team: Polish (http://www.transifex.com/postgis/postgis/language/"
 #, no-c-format
 msgid "Description"
 msgstr "Opis"
 #. Tag: para
 #, no-c-format
 #, no-c-format
 msgid "Examples"
 msgstr "Przykłady"
 #, no-c-format
 msgid "See Also"
 msgstr "Zobacz także"
@@ -2575,12 +2575,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -2590,19 +2598,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2621,13 +2629,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2650,13 +2658,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2677,19 +2685,19 @@ msgid ""
 msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2699,7 +2707,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2710,7 +2718,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2724,7 +2732,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2734,13 +2742,13 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr "Dostępność: 1.4.0"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2748,7 +2756,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
diff --git a/doc/po/pt_BR/reference_output.xml.po b/doc/po/pt_BR/reference_output.xml.po
index fe043a9d2..a29087103 100644
--- a/doc/po/pt_BR/reference_output.xml.po
+++ b/doc/po/pt_BR/reference_output.xml.po
 msgstr ""
 "Language-Team: Portuguese (Brazil) (http://www.transifex.com/postgis/postgis/"
@@ -80,7 +80,7 @@ msgstr ""
 #, no-c-format
 msgid "Description"
 msgstr "Descrição"
@@ -156,7 +156,7 @@ msgstr "&Z_support;"
 #. Tag: para
 #, no-c-format
@@ -181,7 +181,7 @@ msgstr "&T_support;"
 #, no-c-format
 msgid "Examples"
 msgstr "Examples"
@@ -233,7 +233,7 @@ msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr "Veja também."
@@ -3045,12 +3045,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -3060,19 +3068,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "Exemplo: Um octógono elevado 3 unidades e com precisão decimal de 6"
 #, no-c-format
 msgid ""
@@ -3104,13 +3112,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "Exemplo: TIN"
 #, no-c-format
 msgid ""
@@ -3150,13 +3158,13 @@ msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr "Exemplo: Multilinestring fechada (o limite de um polígono com buracos)"
 #, no-c-format
 msgid ""
@@ -3192,19 +3200,19 @@ msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr "ST_GeoHash"
 #. Tag: refpurpose
 #, no-c-format
 msgstr "Retorna uma representação GeoHash da geometria. "
 #, no-c-format
 msgid ""
@@ -3218,7 +3226,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3235,7 +3243,7 @@ msgstr ""
 "atual. "
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3257,7 +3265,7 @@ msgstr ""
 "sempre conterá o traço de entrada. "
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3271,13 +3279,13 @@ msgstr ""
 "é o centro da caixa limitadora da geometria. "
 #. Tag: para
 #, no-c-format
 msgstr "Disponibilidade: 1.4.0"
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -3287,7 +3295,7 @@ msgstr ""
 "geográficas (lon/lat)."
 #, no-c-format
 msgid ""
diff --git a/doc/po/ru/reference_output.xml.po b/doc/po/ru/reference_output.xml.po
index 9cd6de30f..bb84a85c4 100644
--- a/doc/po/ru/reference_output.xml.po
+++ b/doc/po/ru/reference_output.xml.po
 msgstr ""
 "Language-Team: Russian (http://www.transifex.com/postgis/postgis/language/"
 #, no-c-format
 msgid "Description"
 msgstr ""
@@ -151,7 +151,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
@@ -176,7 +176,7 @@ msgstr ""
 #, no-c-format
 msgid "Examples"
 msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
diff --git a/doc/po/templates/reference_output.xml.pot b/doc/po/templates/reference_output.xml.pot
index 5d40ae87c..122498f5e 100644
--- a/doc/po/templates/reference_output.xml.pot
+++ b/doc/po/templates/reference_output.xml.pot
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -73,7 +73,7 @@ msgstr ""
 #, no-c-format
 msgid "Description"
 msgstr ""
@@ -147,7 +147,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
@@ -172,7 +172,7 @@ msgstr ""
 #, no-c-format
 msgid "Examples"
 msgstr ""
@@ -206,7 +206,7 @@ msgstr ""
 #, no-c-format
 msgid "See Also"
 msgstr ""
@@ -2571,12 +2571,20 @@ msgstr ""
 msgstr ""
+#. Tag: para
 #, no-c-format
 msgid ""
-"||\n"
+msgstr ""
+#, no-c-format
+msgid ""
+"i*0.5)) ||\n"
 "    '<Appearance>\n"
@@ -2586,19 +2594,19 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2617,13 +2625,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2646,13 +2654,13 @@ msgid ""
 msgstr ""
 #. Tag: title
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2673,19 +2681,19 @@ msgid ""
 msgstr ""
 #. Tag: refname
 #, no-c-format
 msgid "ST_GeoHash"
 msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgstr ""
 #, no-c-format
 msgid ""
@@ -2695,7 +2703,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2706,7 +2714,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2720,7 +2728,7 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2730,13 +2738,13 @@ msgid ""
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
@@ -2744,7 +2752,7 @@ msgid ""
 msgstr ""
 #, no-c-format
 msgid ""
Summary of changes:
 doc/po/de/reference_output.xml.po         | 56 ++++++++++++++++++-------------
 doc/po/es/reference_output.xml.po         | 56 ++++++++++++++++++-------------
 doc/po/fr/reference_output.xml.po         | 56 ++++++++++++++++++-------------
 doc/po/it_IT/reference_output.xml.po      | 56 ++++++++++++++++++-------------
 doc/po/ja/reference_output.xml.po         | 56 ++++++++++++++++++-------------
 doc/po/ko_KR/reference_output.xml.po      | 56 ++++++++++++++++++-------------
 doc/po/pl/reference_output.xml.po         | 56 ++++++++++++++++++-------------
 doc/po/pt_BR/reference_output.xml.po      | 56 ++++++++++++++++++-------------
 doc/po/ru/reference_output.xml.po         | 56 ++++++++++++++++++-------------
 doc/po/templates/reference_output.xml.pot | 56 ++++++++++++++++++-------------
 10 files changed, 320 insertions(+), 240 deletions(-)
hooks/post-receive
