[postgis-tickets] [PostGIS] #5087: 3.0.5 build error against PostgreSQL !4
PostGIS trac at osgeo.org
Mon Feb 7 06:26:13 PST 2022
 Reporter:  devrimgunduz  |      Owner:  pramsey
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 3.0.6
Component:  postgis       |    Version:  3.0.x
 Keywords:                |
 3.0.5 fails to build against PostgreSQL 14. I did not see any issues
 against other versions. Can you please take a look? Thanks!
 gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
 statement -Werror=vla -Wendif-labels -Wmissing-format-attribute
 -Wimplicit-fallthrough=3 -Wcast-function-type -Wformat-security -fno-
 strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation
 -Wno-stringop-truncation -O2 -flto=auto -ffat-lto-objects -fexceptions -g
 -grecord-gcc-switches -pipe -Wall -Werror=format-security
 -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS
 -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong
 -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -mtune=generic
 -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection
 -fPIC -I../liblwgeom -std=gnu99  -I/usr/gdal33/include -fno-math-errno
 -fno-signed-zeros -I../libpgcommon -I../deps/wagyu
 -I../deps/uthash/include  -I/usr/geos39/include -I/usr/proj82/include
 -I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c     -fPIC
 -DPIC -I/usr/include -I. -I./ -I/usr/pgsql-14/include/server
 -I/usr/pgsql-14/include/internal  -D_GNU_SOURCE -I/usr/include/libxml2
 -I/usr/include  -c -o gserialized_gist_nd.o gserialized_gist_nd.c
 In file included from /usr/pgsql-14/include/server/utils/geo_decls.h:21,
                  from ../libpgcommon/lwgeom_pg.h:24,
                  from gserialized_gist_nd.c:47:
 gserialized_gist_nd.c: In function 'gserialized_gist_compress':
 ../libpgcommon/gserialized_gist.h:68:40: warning: array subscript
 'float[32][1]' is partly outside array bounds of 'char[36]' [-Warray-
 bounds]
    68 | #define GIDX_GET_MAX(gidx, dimension) (*((_gidx_float_array
 *)(&(gidx)->c)))[2 * (dimension) + 1]
 gserialized_gist_nd.c:916:14: note: while referencing 'gidxmem'
   916 |         char gidxmem[GIDX_MAX_SIZE];
 ../libpgcommon/gserialized_gist.h:66:40: warning: array subscript
 bounds]
    66 | #define GIDX_GET_MIN(gidx, dimension) (*((_gidx_float_array
 *)(&(gidx)->c)))[2 * (dimension)]
 -I/usr/include  -c -o gserialized_supportfn.o gserialized_supportfn.c
 gserialized_supportfn.c: In function 'postgis_index_supportfn':
 gserialized_supportfn.c:420:75: warning: passing argument 1 of
 'is_pseudo_constant_for_index' from incompatible pointer type
 [-Wincompatible-pointer-types]
   420 |                                         if
 (!is_pseudo_constant_for_index((Node*)expandexpr, req->index))
 Node *
 In file included from gserialized_supportfn.c:38:
 /usr/pgsql-14/include/server/optimizer/optimizer.h:100:55: note: expected
 'PlannerInfo *' but argument is of type 'Node *'
   100 | extern bool is_pseudo_constant_for_index(PlannerInfo *root, Node
 *expr,
 gserialized_supportfn.c:420:97: warning: passing argument 2 of
   420 |                                         if
 struct IndexOptInfo *
 /usr/pgsql-14/include/server/optimizer/optimizer.h:100:67: note: expected
 'Node *' but argument is of type 'struct IndexOptInfo *'
 *expr,
 gserialized_supportfn.c:420:46: error: too few arguments to function
   420 |                                         if
 /usr/pgsql-14/include/server/optimizer/optimizer.h:100:13: note: declared
 here
 *expr,
 gserialized_supportfn.c:443:75: warning: passing argument 1 of
   443 |                                         if
 (!is_pseudo_constant_for_index(rightarg, req->index))
 Node *
 *expr,
 gserialized_supportfn.c:443:88: warning: passing argument 2 of
   443 |                                         if
 *expr,
 gserialized_supportfn.c:443:46: error: too few arguments to function
   443 |                                         if
 here
 *expr,
 make[2]: *** [<builtin>: gserialized_supportfn.o] Error 1
 make[2]: Leaving directory
 '/home/devrim/Documents/Devrim/Projects/repo/pgrpms/rpm/redhat/main/non-
 common/postgis30/main/postgis-3.0.5/postgis'
 make[1]: *** [GNUmakefile:20: all] Error 1
 make[1]: Leaving directory
 common/postgis30/main/postgis-3.0.5'
 error: Bad exit status from /var/tmp/rpm-tmp.tbL3wj (%build)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5087>
