[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-508-g2fb152052
Tue Feb 8 11:00:55 PST 2022
the project "PostGIS".
       via  2fb15205263248249b1f1dd09abc117e8f67807c (commit)
      from  1052dfb9f689a8cca8ba038a00bf9377846df1cb (commit)
revisions in full, below.
commit 2fb15205263248249b1f1dd09abc117e8f67807c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 8 11:00:51 2022 -0800
    Make lwproj_is_latlong available in lwgeom_transform.h, references GH-659
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index fd2401272..3972b914c 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -534,7 +534,7 @@ DeleteFromPROJSRSCache(PROJSRSCache *PROJCache, uint32_t position)
 int
-GetLWPROJ(int32_t srid_from, int32_t srid_to, LWPROJ **pj)
+lwproj_lookup(int32_t srid_from, int32_t srid_to, LWPROJ **pj)
 	/* get or initialize the cache for this round */
 	PROJSRSCache* proj_cache = GetPROJSRSCache();
@@ -552,8 +552,8 @@ GetLWPROJ(int32_t srid_from, int32_t srid_to, LWPROJ **pj)
 	return pj != NULL;
-static int
-proj_pj_is_latlong(const LWPROJ *pj)
+int
+lwproj_is_latlong(const LWPROJ *pj)
 #if POSTGIS_PROJ_VERSION < 61
 	return pj_is_latlong(pj->pj_from);
@@ -566,9 +566,9 @@ static int
 srid_is_latlong(int32_t srid)
 	LWPROJ *pj;
-	if ( GetLWPROJ(srid, srid, &pj) == LW_FAILURE)
+	if ( lwproj_lookup(srid, srid, &pj) == LW_FAILURE)
 		return LW_FALSE;
-	return proj_pj_is_latlong(pj);
+	return lwproj_is_latlong(pj);
 void
@@ -613,7 +613,7 @@ spheroid_init_from_srid(int32_t srid, SPHEROID *s)
 	double major_axis, minor_axis, eccentricity_squared;
 #endif
 		return LW_FAILURE;
 #if POSTGIS_PROJ_VERSION >= 61
diff --git a/libpgcommon/lwgeom_transform.h b/libpgcommon/lwgeom_transform.h
index db58c6431..51e71de8a 100644
--- a/libpgcommon/lwgeom_transform.h
+++ b/libpgcommon/lwgeom_transform.h
@@ -64,7 +64,8 @@ char *GetProj4String(int32_t srid);
 /* Prototypes */
 PROJSRSCache* GetPROJSRSCache();
-int GetLWPROJ(int32_t srid_from, int32_t srid_to, LWPROJ **pj);
+int lwproj_lookup(int32_t srid_from, int32_t srid_to, LWPROJ **pj);
+int lwproj_is_latlong(const LWPROJ *pj);
 int spheroid_init_from_srid(int32_t srid, SPHEROID *s);
 void srid_check_latlong(int32_t srid);
 srs_precision srid_axis_precision(int32_t srid, int precision);
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 80f7b258f..758e7996c 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -74,7 +74,7 @@ Datum transform(PG_FUNCTION_ARGS)
 		PG_RETURN_POINTER(geom);
 	postgis_initialize_cache();
-	if ( GetLWPROJ(srid_from, srid_to, &pj) == LW_FAILURE )
+	if ( lwproj_lookup(srid_from, srid_to, &pj) == LW_FAILURE )
 		PG_FREE_IF_COPY(geom, 0);
 		elog(ERROR, "ST_Transform: Failure reading projections from spatial_ref_sys.");
@@ -211,7 +211,7 @@ Datum LWGEOM_asKML(PG_FUNCTION_ARGS)
 	if (srid_from != srid_to)
 		LWPROJ *pj;
-		if (GetLWPROJ(srid_from, srid_to, &pj) == LW_FAILURE)
+		if (lwproj_lookup(srid_from, srid_to, &pj) == LW_FAILURE)
 			elog(ERROR, "ST_AsKML: Failure reading projections from spatial_ref_sys.");
Summary of changes:
 libpgcommon/lwgeom_transform.c | 12 ++++++------
 libpgcommon/lwgeom_transform.h |  3 ++-
 postgis/lwgeom_transform.c     |  4 ++--
 3 files changed, 10 insertions(+), 9 deletions(-)
hooks/post-receive
