[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-29-g4834a9f11
Fri Feb 11 00:44:48 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  4834a9f11fbfc3e58b4ab5300dc8298e668a9da1 (commit)
      from  4443d6989cb93e63f9dd5c21735768afb8a20b1b (commit)
revisions in full, below.
commit 4834a9f11fbfc3e58b4ab5300dc8298e668a9da1
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Feb 11 03:44:04 2022 -0500
    search_path vulnerability during install/upgrade.
    References #5069 for PostGIS 3.2.1
diff --git a/NEWS b/NEWS
index 946b842f9..81b0045d2 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.2.1dev
-YYYY/MM/DD
+2022/02/DD
 * Bug Fixes *
   - #5033, #5035, allow upgrades in presence of views using deprecated
@@ -10,6 +10,8 @@ YYYY/MM/DD
   - #5041, postgis_tiger_geocoder: loader_generate_script
            generates script with invalid syntax (Regna Obe)
   - #5076, stop install when pgaudit is active (Paul Ramsey)
+  - #5069, search_path vulnerabilty during install/upgrade
+           (Regina Obe)
 PostGIS 3.2.0 (Olivier Courtin Edition)
diff --git a/extensions/postgis/unpackage_raster_if_needed.sql b/extensions/postgis/unpackage_raster_if_needed.sql
index 9d48244f1..bee2a83f9 100644
--- a/extensions/postgis/unpackage_raster_if_needed.sql
+++ b/extensions/postgis/unpackage_raster_if_needed.sql
@@ -1,10 +1,10 @@
 DO $unpackage_if_needed$
 BEGIN
 	IF EXISTS (
-		select t.typname from pg_depend d, pg_extension e, pg_type t where
+		select t.typname from pg_catalog.pg_depend d, pg_catalog.pg_extension e, pg_catalog.pg_type t where
 		e.extname = 'postgis' and d.refclassid =
 		'pg_catalog.pg_extension'::pg_catalog.regclass and d.refobjid = e.oid
-		and d.classid = 'pg_type'::regclass and d.objid = t.oid
+		and d.classid = 'pg_catalog.pg_type'::pg_catalog.regclass and d.objid = t.oid
 		and t.typname = 'raster'
 	) THEN
diff --git a/loader/postgis.pl b/loader/postgis.pl
index 5ef24574d..a6858d963 100644
--- a/loader/postgis.pl
+++ b/loader/postgis.pl
@@ -63,7 +63,7 @@ sub status
     my $sql = "
 SELECT n.nspname
-  FROM pg_namespace n, pg_proc p
+  FROM pg_catalog.pg_namespace n, pg_catalog.pg_proc p
   WHERE n.oid = p.pronamespace
     AND p.proname = 'postgis_full_version'
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 4ec82c396..c214abeb2 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -29,15 +29,15 @@ DO $$
 DECLARE
 	pgver text;
 BEGIN
-	SELECT substring(version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
+	SELECT pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
 	IF POSTGIS_PGSQL_VERSION::text != ( SELECT CASE
-		WHEN split_part(s,'.',1)::integer > 9
-			THEN split_part(s,'.',1) || '0'
+		WHEN pg_catalog.split_part(s,'.',1)::integer > 9
+			THEN pg_catalog.split_part(s,'.',1) || '0'
 		ELSE
-			split_part(s,'.', 1) || split_part(s,'.', 2)
+			pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2)
 		END
-		FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s )
+		FROM pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') AS s )
 	THEN
 		RAISE EXCEPTION 'PostGIS built for PostgreSQL % cannot be loaded in PostgreSQL %',
 			POSTGIS_PGSQL_HR_VERSION, pgver;
@@ -52,7 +52,7 @@ DECLARE
   rec RECORD;
 BEGIN
   FOR rec IN
-	SELECT n.nspname, p.proname FROM pg_proc p, pg_namespace n
+	SELECT n.nspname, p.proname FROM pg_catalog.pg_proc p, pg_catalog.pg_namespace n
 	WHERE p.proname = 'postgis_version'
 	AND p.pronamespace = n.oid
   LOOP
@@ -71,7 +71,7 @@ DECLARE
 BEGIN
 	SHOW pgaudit.log INTO pgalog;
 	RAISE DEBUG 'pgaudit is installed, pgaudit.log is set to ''%''', pgalog;
-	IF lower(pgalog) != 'none'
+	IF pg_catalog.lower(pgalog) != 'none'
 	THEN
 		RAISE EXCEPTION 'PostGIS installation stopped: pgaudit.log is set to ''%''. Set pgaudit.log to ''none'' before installing PostGIS. You may re-enable pgaudit after installation is complete.', pgalog;
 	END IF;
@@ -2942,8 +2942,8 @@ CREATE OR REPLACE FUNCTION _postgis_scripts_pgsql_version() RETURNS text
 CREATE OR REPLACE FUNCTION _postgis_pgsql_version() RETURNS text
 AS $$
-	SELECT CASE WHEN split_part(s,'.',1)::integer > 9 THEN split_part(s,'.',1) || '0' ELSE split_part(s,'.', 1) || split_part(s,'.', 2) END AS v
-	FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
+	SELECT CASE WHEN pg_catalog.split_part(s,'.',1)::integer > 9 THEN pg_catalog.split_part(s,'.',1) || '0' ELSE pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2) END AS v
+	FROM pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') AS s;
 $$ LANGUAGE 'sql' STABLE;
 -- Availability: 2.5.0
@@ -3008,12 +3008,12 @@ BEGIN
 				  LIMIT 1;
 				IF rec.name NOT IN('postgis_topology', 'postgis_tiger_geocoder')
 				THEN
-					sql := format(
+					sql := pg_catalog.format(
 							  'CREATE EXTENSION %1$I SCHEMA %2$I VERSION unpackaged;'
 							  'ALTER EXTENSION %1$I UPDATE TO %3$I',
 							  rec.name, var_schema, rec.default_version);
 				ELSE
-					sql := format(
 							 'CREATE EXTENSION %1$I VERSION unpackaged;'
 							 'ALTER EXTENSION %1$I UPDATE TO %2$I',
 							 rec.name, rec.default_version);
@@ -3027,7 +3027,7 @@ BEGIN
 		ELSIF rec.default_version != rec.installed_version
 		THEN
 			sql = 'ALTER EXTENSION ' || rec.name || ' UPDATE TO ' ||
-						quote_ident(rec.default_version)   || ';';
+						pg_catalog.quote_ident(rec.default_version)   || ';';
 			RAISE NOTICE 'Updating extension % from % to %',
 				rec.name, rec.installed_version, rec.default_version;
 			RAISE DEBUG '%', sql;
@@ -3039,11 +3039,11 @@ BEGIN
 			RAISE NOTICE 'Updating extension % %',
 				rec.name, rec.installed_version;
-						quote_ident(rec.default_version || 'next')   || ';';
+						pg_catalog.quote_ident(rec.default_version || 'next')   || ';';
 			EXECUTE sql;
 			EXECUTE sql;
 		END IF;
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index d02bdc42e..11a599d8d 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -30,15 +30,15 @@
 --         FROM pg_catalog.pg_proc p
 --         LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
 --         WHERE
---                 LOWER(n.nspname) = LOWER('public') AND
---                 LOWER(p.proname) = LOWER('ST_AsGeoJson')
+--                 pg_catalog.LOWER(n.nspname) = pg_catalog.LOWER('public') AND
+--                 pg_catalog.LOWER(p.proname) = pg_catalog.LOWER('ST_AsGeoJson')
 --         ORDER BY 1, 2, 3, 4;
 CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
-	function_name text,
-	function_arguments text) RETURNS void AS $$
+	function_name pg_catalog.text,
+	function_arguments pg_catalog.text) RETURNS void AS $$
 DECLARE
-	sql_drop text;
-	postgis_namespace OID;
+	sql_drop pg_catalog.text;
+	postgis_namespace pg_catalog.OID;
 	matching_function REGPROCEDURE;
 BEGIN
@@ -53,9 +53,9 @@ BEGIN
 	SELECT oid
 	WHERE pronamespace = postgis_namespace
-	AND LOWER(p.proname) = LOWER(function_name)
+	AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
 	AND pg_catalog.pg_function_is_visible(p.oid)
-	AND LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ LOWER(function_arguments)
+	AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
 	INTO matching_function;
 	IF matching_function IS NOT NULL THEN
@@ -108,7 +108,7 @@ SELECT _postgis_drop_function_if_needed
 DO  language 'plpgsql' $$
 BEGIN
 	-- fix geometry ops --
-	IF EXISTS(SELECT oprname from pg_operator where oprname = '&&' AND oprrest::text = 'geometry_gist_sel_2d') THEN
+	IF EXISTS(SELECT oprname from pg_operator where oprname = '&&' AND oprrest::pg_catalog.text = 'geometry_gist_sel_2d') THEN
 	--it is bound to old name, drop new, rename old to new, install will fix body of code
 		DROP FUNCTION IF EXISTS gserialized_gist_sel_2d(internal, oid, internal, int4) ;
 		ALTER FUNCTION geometry_gist_sel_2d(internal, oid, internal, int4) RENAME TO gserialized_gist_sel_2d;
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index baac9d676..f0084873d 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -47,7 +47,7 @@ DECLARE
   rec RECORD;
 BEGIN
   FOR rec IN
     WHERE p.proname = 'postgis_raster_lib_version'
   LOOP
@@ -63,11 +63,11 @@ DECLARE
   nsp TEXT;
 BEGIN
   SELECT n.nspname
-	INTO nsp FROM pg_proc p, pg_namespace n
+	INTO nsp FROM pg_catalog.pg_proc p, pg_catalog.pg_namespace n
   WHERE p.proname = 'postgis_lib_version'
   AND p.pronamespace = n.oid;
-	IF nsp != current_schema() THEN
+	IF nsp != pg_catalog.current_schema() THEN
     RAISE EXCEPTION
 			'PostGIS Raster must be in the same schema as PostGIS (%)',
 			nsp;
diff --git a/utils/create_undef.pl b/utils/create_undef.pl
index 4036801dc..a5f88fc1b 100755
--- a/utils/create_undef.pl
+++ b/utils/create_undef.pl
@@ -287,10 +287,10 @@ DECLARE
 BEGIN
 	FOR rec IN
 		SELECT n.nspname, c.relname, a.attname, t.typname
-		FROM pg_attribute a
-		JOIN pg_class c ON a.attrelid = c.oid
-		JOIN pg_namespace n ON c.relnamespace = n.oid
-		JOIN pg_type t ON a.atttypid = t.oid
+		FROM pg_catalog.pg_attribute a
+		JOIN pg_catalog.pg_class c ON a.attrelid = c.oid
+		JOIN pg_catalog.pg_namespace n ON c.relnamespace = n.oid
+		JOIN pg_catalog.pg_type t ON a.atttypid = t.oid
 		WHERE t.typname = '$type'
 		  AND NOT (
 				-- we exclude complexes defined as types
@@ -398,15 +398,15 @@ DECLARE
 	var_result text;
 	var_search_path text;
 BEGIN
-	SELECT reset_val INTO var_search_path FROM pg_settings WHERE name = 'search_path';
-	IF var_search_path NOT LIKE '%' || quote_ident(a_schema_name) || '%' THEN
+	SELECT reset_val INTO var_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
+	IF var_search_path NOT LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
 		var_result := a_schema_name || ' not in database search_path';
 	ELSE
-    var_search_path := btrim( regexp_replace(
-        replace(var_search_path, a_schema_name, ''), ', *,', ','),
+    var_search_path := pg_catalog.btrim( pg_catalog.regexp_replace(
+        pg_catalog.replace(var_search_path, a_schema_name, ''), ', *,', ','),
     RAISE NOTICE 'New search_path: %', var_search_path;
-		EXECUTE 'ALTER DATABASE ' || quote_ident(current_database()) || ' SET search_path = ' || var_search_path;
+		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database()) || ' SET search_path = ' || var_search_path;
 		var_result := a_schema_name || ' has been stripped off database search_path ';
 	END IF;
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 5071c0f0e..6173af8e2 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -253,7 +253,7 @@ BEGIN
             d.objid = replaced_proc::oid
     LOOP
         RAISE DEBUG 'Unpackaging ${renamed} from extension %', rec.extname;
-        sql := format('ALTER EXTENSION %I DROP FUNCTION ${renamed}(${args})', rec.extname);
+        sql := pg_catalog.format('ALTER EXTENSION %I DROP FUNCTION ${renamed}(${args})', rec.extname);
         EXECUTE sql;
     END LOOP;
@@ -622,8 +622,8 @@ BEGIN
 --    FOR rec IN
 --        SELECT n.nspname AS schemaname,
 --            c.relname AS viewname,
---            pg_get_userbyid(c.relowner) AS viewowner,
---            pg_get_viewdef(c.oid) AS definition,
+--            pg_catalog.pg_get_userbyid(c.relowner) AS viewowner,
+--            pg_catalog.pg_get_viewdef(c.oid) AS definition,
 --            CASE
 --                WHEN 'check_option=cascaded' = ANY (c.reloptions) THEN 'WITH CASCADED CHECK OPTION'
 --                WHEN 'check_option=local' = ANY (c.reloptions) THEN 'WITH LOCAL CHECK OPTION'
@@ -632,12 +632,12 @@ BEGIN
 --        FROM pg_class c
 --        LEFT JOIN pg_namespace n ON n.oid = c.relnamespace
 --        WHERE c.relkind = 'v'
---        AND pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
+--        AND pg_catalog.pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
 --    LOOP
---        sql := format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
+--        sql := pg_catalog.format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
 --            rec.schemaname,
 --            rec.viewname,
---            regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
+--            pg_catalog.regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
 --            rec.check_option
 --        RAISE NOTICE 'Updating view % to not use deprecated signatures', rec.viewname;
@@ -647,17 +647,17 @@ BEGIN
 --        WHEN OTHERS THEN
 --                GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
 --                RAISE WARNING 'Could not rewrite view % using deprecated functions', rec.viewname
---                        USING DETAIL = format('%s: %s', SQLERRM, detail);
+--                        USING DETAIL = pg_catalog.format('%s: %s', SQLERRM, detail);
 --        END;
 --    END LOOP;
     -- Try to drop all deprecated functions, raising a warning
     -- for each one which cannot be drop
-    FOR rec IN SELECT unnest(deprecated_functions) as proc
+    FOR rec IN SELECT pg_catalog.unnest(deprecated_functions) as proc
     LOOP --{
-        sql := format('DROP FUNCTION %s', rec.proc);
+        sql := pg_catalog.format('DROP FUNCTION %s', rec.proc);
         --RAISE DEBUG 'SQL: %', sql;
         BEGIN
             EXECUTE sql;
@@ -666,10 +666,10 @@ BEGIN
             hint = 'Resolve the issue';
             IF detail LIKE '%view % depends%' THEN
-                hint = format(
+                hint = pg_catalog.format(
                     'Replace the view changing all occurrences of %s in its definition with %s',
                     rec.proc,
-                    regexp_replace(rec.proc::text, '_deprecated_by_postgis[^(]*', '')
+                    pg_catalog.regexp_replace(rec.proc::text, '_deprecated_by_postgis[^(]*', '')
             END IF;
             hint = hint || ' and upgrade again';
@@ -719,8 +719,8 @@ BEGIN
         SELECT into old_scripts MODULE_scripts_installed();
     END;
     SELECT into new_scripts 'NEWVERSION';
-    SELECT into old_maj substring(old_scripts from 1 for 1);
-    SELECT into new_maj substring(new_scripts from 1 for 1);
+    SELECT into old_maj pg_catalog.substring(old_scripts,1, 1);
+    SELECT into new_maj pg_catalog.substring(new_scripts,1, 1);
     -- 2.x to 3.x was upgrade-compatible, see
     -- https://trac.osgeo.org/postgis/ticket/4170#comment:1
@@ -738,18 +738,18 @@ BEGIN
     ) SELECT
       upgraded as scripts_upgraded,
       installed as scripts_installed,
-      substring(upgraded from '([0-9]+)\.')::int * 100 +
-      substring(upgraded from '[0-9]+\.([0-9]+)(\.|$)')::int
+      pg_catalog.substring(upgraded, '([0-9]+)\.')::int * 100 +
+      pg_catalog.substring(upgraded, '[0-9]+\.([0-9]+)(\.|$)')::int
         as version_to_num,
-      substring(installed from '([0-9]+)\.')::int * 100 +
-      substring(installed from '[0-9]+\.([0-9]+)(\.|$)')::int
+      pg_catalog.substring(installed, '([0-9]+)\.')::int * 100 +
+      pg_catalog.substring(installed, '[0-9]+\.([0-9]+)(\.|$)')::int
         as version_from_num,
       installed ~ 'dev|alpha|beta'
         as version_from_isdev
       FROM versions INTO postgis_upgrade_info
-    postgis_upgrade_info_func_code := format($func_code$
+    postgis_upgrade_info_func_code := pg_catalog.format($func_code$
         CREATE FUNCTION _postgis_upgrade_info(OUT scripts_upgraded TEXT,
                                               OUT scripts_installed TEXT,
                                               OUT version_to_num INT,
Summary of changes:
 NEWS                                              |  4 ++-
 extensions/postgis/unpackage_raster_if_needed.sql |  4 +--
 loader/postgis.pl                                 |  2 +-
 postgis/postgis.sql.in                            | 28 +++++++++---------
 postgis/postgis_before_upgrade.sql                | 18 ++++++------
 raster/rt_pg/rtpostgis.sql.in                     |  6 ++--
 utils/create_undef.pl                             | 18 ++++++------
 utils/postgis_proc_upgrade.pl                     | 36 +++++++++++------------
 8 files changed, 59 insertions(+), 57 deletions(-)
hooks/post-receive
