[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-515-g4053205b0
Sat Feb 12 15:44:59 PST 2022
the project "PostGIS".
       via  4053205b04d25d5d7e30328cac29e7ce2958c1ac (commit)
      from  1e76b00013f979c52c3b2e639b77018290dfb1e0 (commit)
revisions in full, below.
commit 4053205b04d25d5d7e30328cac29e7ce2958c1ac
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Feb 12 18:44:10 2022 -0500
    Patches from Tobias Bussmann
    References #5090 for PostGIS 3.3.0
    Closes https://github.com/postgis/postgis/pull/662, Closes
    https://github.com/postgis/postgis/pull/663atches from Tobias Bussmann
    Closes https://github.com/postgis/postgis/pull/662, Closes https://github.com/postgis/postgis/pull/663
diff --git a/configure.ac b/configure.ac
index 07307a46f..fe9de0bcb 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1028,7 +1028,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
 			if test "x$withval" = "xyes"; then
 				AC_MSG_ERROR([you must specify a parameter to --with-protobufdir, e.g. --with-protobufdir=/usr/local])
 			else
-				PROTOBUF_LDFLAGS="-L$withval/lib";
+				PROTOBUF_LDFLAGS="-L$withval/lib -lprotobuf-c";
 				PROTOBUF_CPPFLAGS="-I$withval/include"
 			fi
@@ -1040,7 +1040,7 @@ if test "$CHECK_PROTOBUF" != "no"; then
 	AC_ARG_WITH([protobuf-lib],
 		[AS_HELP_STRING([--with-protobuf-lib=PATH], [libprotobuf-c.so/dll/dylib library installation directory])], [
-			PROTOBUF_LDFLAGS="-L$withval"
+			PROTOBUF_LDFLAGS="-L$withval -lprotobuf-c"
 	if test -n "$PROTOBUF_CPPFLAGS"; then
@@ -1058,8 +1058,11 @@ if test "$CHECK_PROTOBUF" != "no"; then
 	dnl confirm that discovered/configured library path works
-	AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init],
+	AC_CHECK_LIB([protobuf-c], [protobuf_c_message_init],[
+			if test "x$PROTOBUF_LDFLAGS" = "x"; then
+				PROTOBUF_LDFLAGS="-lprotobuf-c"
+			fi
 		AC_MSG_ERROR([unable to link protobuf-c using $LDFLAGS. You can disable MVT and Geobuf support using --without-protobuf])
 		HAVE_PROTOBUF=no
Summary of changes:
 configure.ac | 11 +++++++----
 1 file changed, 7 insertions(+), 4 deletions(-)
hooks/post-receive
