[postgis-tickets] [PostGIS] #5090: configure --with-protobuf-lib / --with-protobufdir broken
PostGIS trac at osgeo.org
Sat Feb 12 16:20:37 PST 2022
  Reporter:  tbussmann              |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.2.1
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"ecad675f3c102771ea930ce9bad5ca91d220d076/git" ecad675/git]:
 #!CommitTicketReference repository="git"
 revision="ecad675f3c102771ea930ce9bad5ca91d220d076"
 Closes #5090 for PostGIS 3.2.1
 Closes #5091 for PostGIS 3.2.1
 Fix --with-protobuf-lib / --with-protobufdir broken
 References https://github.com/postgis/postgis/pull/662
 References https://github.com/postgis/postgis/pull/663
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5090#comment:5>
