[postgis-tickets] [PostGIS] #5099: Running make twice compiles again under postgis
PostGIS trac at osgeo.org
Wed Feb 16 16:37:15 PST 2022
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Running `make` a second time after the first `make`, in top-level dir,
 results in some files being built again. This should NOT happen, in a sane
 system. Files that are built again are under the postgis/ directory.
 I was under the impression that I already filed this ticket but upon
 looking I could not find a precedent one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5099>
