[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-557-g67aac2acc
Thu Feb 17 09:16:25 PST 2022
the project "PostGIS".
       via  67aac2acc9af57ed023fc05e87b11ef0b16fa96d (commit)
      from  f7f7c1c5e87a731264a6ab42d67e5d2d1942bf01 (commit)
revisions in full, below.
commit 67aac2acc9af57ed023fc05e87b11ef0b16fa96d
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Feb 17 18:16:11 2022 +0100
    Fix postgis_tiger_geocoder build
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 49189aec5..67284829a 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -170,7 +170,7 @@ sql/tiger_geocoder.sql: sql/tiger_geocoder.sql.in
 	sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;'  $< > $@
 	$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
-sql/add_search_path.sql: sql_bits/add_search_path.sql.in
+sql/add_search_path.sql: sql_bits/add_search_path.sql.in | sql
 	cp $< $@
 ../../doc/tiger_geocoder_comments.sql:
Summary of changes:
 extensions/postgis_tiger_geocoder/Makefile.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
