[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-582-g9e14b1d65
Fri Feb 18 11:32:26 PST 2022
the project "PostGIS".
       via  9e14b1d6556caaad41f9326f75a887c427137403 (commit)
      from  9cf58181c69f961edd6976594bbecae55d8f6e80 (commit)
revisions in full, below.
commit 9e14b1d6556caaad41f9326f75a887c427137403
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Fri Feb 18 11:32:22 2022 -0800
    Fix doc typos
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 577115939..47d15b05a 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -926,13 +926,14 @@ The smaller densifyFrac we specify, the more acurate Fréchet distance we get. B
             <imageobject>
                 <imagedata fileref="images/st_hausdorffdistance01.png" />
             </imageobject>
-            <caption><para>Hausdorff distance (red) and closest distance yellow)
+            <caption><para>Hausdorff distance (red) and distance (yellow)
             between two lines </para></caption>
             </mediaobject>
         </informalfigure>
 <programlisting>
-SELECT ST_HausdorffDistance(geomA, geomB), ST_Distance(geomA, geomB)
+SELECT ST_HausdorffDistance(geomA, geomB),
+       ST_Distance(geomA, geomB)
     FROM (SELECT 'LINESTRING (20 70, 70 60, 110 70, 170 70)'::geometry AS geomA,
                  'LINESTRING (20 90, 130 90, 60 100, 190 100)'::geometry AS geomB) AS t;
  st_hausdorffdistance | st_distance
Summary of changes:
 doc/reference_measure.xml | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
