[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-591-g4cd780c1b
Wed Feb 23 00:07:59 PST 2022
the project "PostGIS".
       via  4cd780c1b40aac54a036c700dd3876d24be557c8 (commit)
       via  f5b476bf5d7a6c4c8e1fe0866eaad5549b1bb96c (commit)
       via  a0e25ba2f8a054120d6e3a3a0011554e4f09d7e0 (commit)
      from  356a0ae05519717ac1f7e6a4bee123df0aced7c1 (commit)
revisions in full, below.
commit 4cd780c1b40aac54a036c700dd3876d24be557c8
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Feb 22 14:35:51 2022 +0100
    Add test for CopyTopology backward compatibility
diff --git a/topology/test/regress/hooks/hook-after-upgrade-topology.sql b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
index c7e2e9ce8..248b6206f 100644
--- a/topology/test/regress/hooks/hook-after-upgrade-topology.sql
+++ b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
@@ -1,2 +1,6 @@
+-- See https://trac.osgeo.org/postgis/ticket/5102
+SELECT topology.CopyTopology('upgrade_test', 'upgrade_test_copy');
 SELECT topology.DropTopology('upgrade_test');
+SELECT topology.DropTopology('upgrade_test_copy');
commit f5b476bf5d7a6c4c8e1fe0866eaad5549b1bb96c
Date:   Tue Feb 22 14:31:31 2022 +0100
    Restore backward compatible order of fields in topology node table
    Closes #5102
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index 0f9f8c433..0d92c8f39 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1496,8 +1496,8 @@ BEGIN
       CREATE TABLE %1$I.node(
         node_id SERIAL,
-        geom GEOMETRY(point%3$s, %2$L),
         containing_face INTEGER,
+        geom GEOMETRY(point%3$s, %2$L),
         CONSTRAINT node_primary_key
           PRIMARY KEY(node_id),
         CONSTRAINT face_exists
commit a0e25ba2f8a054120d6e3a3a0011554e4f09d7e0
Date:   Tue Feb 22 14:30:24 2022 +0100
    Use format() for CopyTopology body
diff --git a/topology/sql/manage/CopyTopology.sql.in b/topology/sql/manage/CopyTopology.sql.in
index 700af6c38..6f938836d 100644
--- a/topology/sql/manage/CopyTopology.sql.in
+++ b/topology/sql/manage/CopyTopology.sql.in
@@ -19,7 +19,7 @@
 CREATE OR REPLACE FUNCTION topology.CopyTopology(atopology varchar, newtopo varchar)
 RETURNS int
 AS
+$BODY$
 DECLARE
   rec RECORD;
   rec2 RECORD;
@@ -27,6 +27,7 @@ DECLARE
   newtopo_id integer;
   n int4;
   ret text;
+  sql text;
 BEGIN
   SELECT * FROM topology.topology where name = atopology
@@ -37,35 +38,43 @@ BEGIN
   SELECT topology.CreateTopology(newtopo, rec.SRID, rec.precision, rec.hasZ)
   INTO strict newtopo_id;
-  -- Copy faces
-  EXECUTE 'INSERT INTO ' || quote_ident(newtopo)
-    || '.face SELECT * FROM ' || quote_ident(atopology)
-    || '.face WHERE face_id != 0';
-  -- Update faces sequence
-  EXECUTE 'SELECT setval(' || quote_literal(
-      quote_ident(newtopo) || '.face_face_id_seq'
-    ) || ', (SELECT last_value FROM '
-    || quote_ident(atopology) || '.face_face_id_seq))';
+  sql := format(
+      -- Copy faces
+      INSERT INTO %1$I.face
+      SELECT * FROM %2$I.face
+      WHERE face_id != 0;
-  -- Copy nodes
-    || '.node SELECT * FROM ' || quote_ident(atopology)
-    || '.node';
-  -- Update node sequence
-      quote_ident(newtopo) || '.node_node_id_seq'
-    || quote_ident(atopology) || '.node_node_id_seq))';
+      -- Update face sequence
+      SELECT setval(
+        '%1$I.face_face_id_seq',
+        (SELECT last_value FROM %2$I.face_face_id_seq)
-  -- Copy edges
-    || '.edge_data SELECT * FROM ' || quote_ident(atopology)
-    || '.edge_data';
-  -- Update edge sequence
-      quote_ident(newtopo) || '.edge_data_edge_id_seq'
-    || quote_ident(atopology) || '.edge_data_edge_id_seq))';
+      -- Copy nodes
+      INSERT INTO %1$I.node
+      SELECT * FROM %2$I.node;
+      -- Update node sequence
+      SELECT setval(
+        '%1$I.node_node_id_seq',
+        (SELECT last_value FROM %2$I.node_node_id_seq)
+      -- Copy edges
+      INSERT INTO %1$I.edge_data
+      SELECT * FROM %2$I.edge_data;
+      -- Update edge sequence
+      SELECT setval(
+        '%1$I.edge_data_edge_id_seq',
+        (SELECT last_value FROM %2$I.edge_data_edge_id_seq)
+    newtopo,
+    atopology
+  EXECUTE sql;
   -- Copy layers and their TopoGeometry sequences
   FOR rec IN SELECT * FROM topology.layer WHERE topology_id = oldtopo_id
@@ -75,25 +84,35 @@ BEGIN
       VALUES (newtopo_id, rec.layer_id, rec.feature_type,
               rec.level, rec.child_id, newtopo,
               'LAYER' ||  rec.layer_id, '');
     -- Create layer's TopoGeometry sequences
-    EXECUTE 'SELECT last_value FROM '
-      || quote_ident(atopology) || '.topogeo_s_' || rec.layer_id
-      INTO STRICT n;
-    EXECUTE 'CREATE SEQUENCE ' || quote_ident(newtopo)
-      || '.topogeo_s_' || rec.layer_id;
-      quote_ident(newtopo) || '.topogeo_s_' || rec.layer_id
-      ) || ', ' || n || ')';
+    EXECUTE format(
+        CREATE SEQUENCE %1$I.topogeo_s_%2$s;
+        SELECT setval(
+          '%1$I.topogeo_s_%2$s',
+          (SELECT last_value FROM %3$I.topogeo_s_%2$s)
+      newtopo,
+      rec.layer_id,
+      atopology
   END LOOP;
   -- Copy TopoGeometry definitions
-    || '.relation SELECT * FROM ' || quote_ident(atopology)
-    || '.relation';
+  EXECUTE format(
+      INSERT INTO %1$I.relation
+      SELECT * FROM %2$I.relation
+    newtopo,
+    atopology
   RETURN newtopo_id;
 END
+$BODY$
 LANGUAGE 'plpgsql' VOLATILE STRICT;
 --} TopologySummary
Summary of changes:
 topology/sql/manage/CopyTopology.sql.in            | 99 +++++++++++++---------
 .../regress/hooks/hook-after-upgrade-topology.sql  |  4 +
 topology/topology.sql.in                           |  2 +-
 3 files changed, 64 insertions(+), 41 deletions(-)
hooks/post-receive
