[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-602-gdb5579a7b
Thu Feb 24 11:18:33 PST 2022
the project "PostGIS".
       via  db5579a7ba6c5858a291f92a386f550c3c4f123c (commit)
      from  a8c777aede568c65dd147420c6622fdc9aa3c411 (commit)
revisions in full, below.
commit db5579a7ba6c5858a291f92a386f550c3c4f123c
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Feb 24 14:17:05 2022 -0500
    make clean does not work after configure
    Change bessies to run make distclean instead of make clean.
diff --git a/ci/bessie/postgis_regress.sh b/ci/bessie/postgis_regress.sh
index 425fe868f..76853cb68 100644
--- a/ci/bessie/postgis_regress.sh
+++ b/ci/bessie/postgis_regress.sh
@@ -6,7 +6,7 @@ set -e
 export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
 ./configure --with-projdir=/usr/local --with-libiconv=/usr/local --without-interrupt-tests
-make clean
+make distclean
 make
 export PGUSER=postgres
 export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${BRANCH}
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
index c373611e5..5e1f5b6ed 100644
--- a/ci/bessie32/postgis_regress.sh
+++ b/ci/bessie32/postgis_regress.sh
@@ -9,7 +9,7 @@ CXX=g++8 \
 CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc8" \
 CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
  ./configure --with-libiconv=/usr/local --without-interrupt-tests
-make clean
+make distclean
 make
Summary of changes:
 ci/bessie/postgis_regress.sh   | 2 +-
 ci/bessie32/postgis_regress.sh | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
