[postgis-tickets] [PostGIS] #5103: Bessies are failing
PostGIS trac at osgeo.org
Thu Feb 24 20:23:23 PST 2022
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.3.0
Component:  buildbots  |    Version:  master
 Keywords:             |
 Seems to be recent shuffling of build tooling.  I tried to fix by first
 taking out the make clean and then putting in make distclean.  Then I took
 that out cause that was erroring too.
 I'm not sure what triggers them to start doing out of tree builds.
 Here is the error which both bessie and bessie32 are showing
 22:59:47 configure: WARNING:
 22:59:47 configure: WARNING:  | You are building using --with-projdir.
 This option isn't standard and    |
 22:59:47 configure: WARNING:  | might be incompatible with future releases
 of PROJ.                      |
 22:59:47 configure: WARNING:  | You can instead adjust the PKG_CONFIG_PATH
 environment variable if you   |
 22:59:47 configure: WARNING:  | installed software in a non-standard
 prefix.                             |
 22:59:47 configure: WARNING:  | Alternatively, you may set the environment
 variables PROJ_CFLAGS and     |
 22:59:47 configure: WARNING:  | PROJ_LIBS to avoid the need to call pkg-
 config.                          |
 22:59:47 + make
 22:59:47 mkdir -p build
 22:59:47 cd build && ../configure
 22:59:47 configure: error: source directory already configured; run "make
 distclean" there first
 22:59:47 *** Error code 1
 22:59:47
 22:59:47 Stop.
 22:59:47 make: stopped in
 /usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie/e3d6a2357286acb4cc5e52c77b1e7e82e00bc00c
 22:59:47 Build step 'Execute shell' marked build as failure
 22:59:47 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5103>
