[postgis-tickets] [PostGIS] #5104: winnie failing on marc21_out
PostGIS trac at osgeo.org
Fri Feb 25 11:57:20 PST 2022
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.3.0
Component:  postgis  |    Version:  3.2.x
 Keywords:           |
  ./regress/core/out_marc21 .. failed (diff expected obtained:
 /projects/postgis/tmp/3.3.0dev_pg11_geos3.11_gdal3.3.3w64/test_27_diff)
 --- ./regress/core/out_marc21_expected  2022-02-17 19:39:49.495811700
 -0500
 +++ /projects/postgis/tmp/3.3.0dev_pg11_geos3.11_gdal3.3.3w64/test_27_out
 2022-02-25 11:51:05.676040100 -0500
 @@ -781,7 +781,7 @@
  polygon_14|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield
 code="d">E126.416667</subfield><subfield
 code="e">E129.258333</subfield><subfield
 code="f">N036.127222</subfield><subfield
 code="g">N035.033333</subfield></datafield></record>
  polygon_15|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">E12625.000000</subfield><subfield
 code="e">E12915.500000</subfield><subfield
 code="f">N03607.633333</subfield><subfield
 code="g">N03503.000000</subfield></datafield></record>
  polygon_16|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">E1262500.000000</subfield><subfield
 code="e">E1291530.000000</subfield><subfield
 code="f">N0360738.000000</subfield><subfield
 code="g">N0350200.000000</subfield></datafield></record>
 -polygon_17|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">E126.416666666666671403618238400667905807495117</subfield><subfield
 code="e">E129.258333333333325754210818558931350708007812</subfield><subfield
 code="f">N036.127222222222222569598670816048979759216309</subfield><subfield
 code="g">N035.033333333333331438552704639732837677001953</subfield></datafield></record>
 +polygon_17|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="e">E129.258333333333325754210818558931350708007813</subfield><subfield
  polygon_18|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">E12625.000000000000284217094304040074348449707031250</subfield><subfield
 code="e">E12915.499999999999545252649113535881042480468750000</subfield><subfield
 code="f">N03607.633333333333354175920248962938785552978515625</subfield><subfield
 code="g">N03502.999999999999886313162278383970260620117187500</subfield></datafield></record>
  polygon_19|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">E1262500.0000000000170530256582424044609069824218750</subfield><subfield
 code="e">E1291529.9999999999727151589468121528625488281250000</subfield><subfield
 code="f">N0360738.0000000000012505552149377763271331787109375</subfield><subfield
 code="g">N0350200.0000000000068212102632969617843627929687500</subfield></datafield></record>
  polygon_20|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield
 code="d">1262500</subfield><subfield code="e">1291530</subfield><subfield
 code="f">0360738</subfield><subfield
 code="g">0350200</subfield></datafield></record>
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5104>
