[postgis-tickets] [SCM] postgis.net branch hugo updated. fbaa2a3118c415775f5c6ba37b823120edf7959a
Sat Feb 26 08:24:49 PST 2022
the project "postgis.net".
The branch, hugo has been updated
       via  fbaa2a3118c415775f5c6ba37b823120edf7959a (commit)
      from  da252ecdf82b8e006927607eef592b1bc9961f85 (commit)
revisions in full, below.
commit fbaa2a3118c415775f5c6ba37b823120edf7959a
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Feb 26 11:24:41 2022 -0500
    more messing with colors.  Underline hyperlinks.  Fix obsolete info oninstall page
diff --git a/assets/sass/_custom.sass b/assets/sass/_custom.sass
new file mode 100644
index 0000000..a1112fa
--- /dev/null
+++ b/assets/sass/_custom.sass
@@ -0,0 +1,16 @@
+// add customs styles and general overrides here
+// due to the cascading nature of css, if you try to override theme css variables in this file, those changes will not apply. Instead, override css variables in the `override.sass` file
+// we recommend not editing this file directly. Instead, create an `assets/sass/_custom.sass` file at the root level of your site.
+// if you edit this file directly, you will have to resolve git conflicts when and if you decide to pull changes we make on the theme
+a
+  display: inline-flex
+  position: relative
+  border: none
+  vertical-align: middle
+  text-decoration: underline
+  &:hover
+    cursor: pointer
+a.nav_item
+  text-decoration: none
diff --git a/assets/sass/_override.sass b/assets/sass/_override.sass
index a1075c0..11fdd10 100644
--- a/assets/sass/_override.sass
+++ b/assets/sass/_override.sass
@@ -1,14 +1,4 @@
 // override clarity theme's  _variables.sass file.
 // we recommend not editing this file directly. Instead, create an `assets/sass/_override.sass` file at the root level of your site.
-body, html
-  scroll-behavior: smooth
-  -webkit-text-size-adjust: 95%
-  font-kerning: normal
-  -webkit-font-feature-settings: "kern" 1
-  text-rendering: optimizeLegibility
-  text-rendering: geometricPrecision
-  font-size: 95%
-  &::-webkit-scrollbar-corner
-    background-color: transparen
+//Sass color variables
diff --git a/assets/sass/_variables.sass b/assets/sass/_variables.sass
index 7c90b64..cc57e5e 100644
--- a/assets/sass/_variables.sass
+++ b/assets/sass/_variables.sass
@@ -29,16 +29,16 @@ html
   --color-mode: 'lit'
   --light: #fff
   --dark: #000
-  --bg: #002538
+  --bg: #011d2b
   --haze: #f2f2f2
-  --gray: #020202
+  --gray: #161010
   --accent: var(--gray)
-  --text: #575757
+  --text: #000
   --header-text: var(--dark)
   --font: Metropolis, sans-serif
   --theme: #0077b8
   --ease: cubic-bezier(.19,1,.22,1)
-  --code-bg: var(--bg)
+  --code-bg: var(--dark)
   --table-bg: var(--light)
   --table-haze: var(--haze)
   --table-border: #dedede
diff --git a/content/pages/install.md b/content/pages/install.md
index fe79f8f..ed3b73e 100644
--- a/content/pages/install.md
+++ b/content/pages/install.md
@@ -17,9 +17,26 @@ instructions:
 # Binary Installers
 Binary distributions of PostGIS are available for various operating systems.
+## Docker
+PostGIS has a community [docker-postgis](https://github.com/postgis/docker-postgis) project.
+Production ready PostGIS Docker builds can be pulled from <a href="https://registry.hub.docker.com/r/postgis/postgis/" target="_blank">PostGIS docker hub</a>
 ## Windows
-* More details about getting up and running with windows can be found on [Windows Downloads](/windows_downloads) page.
+* More details about getting up and running with windows can be found on [Windows Downloads]({{ pcurl('windows_downloads') }}) page.
+## Red Hat / Centos / Scientific Linux
+* The best place to get the latest binaries for both PostgreSQL and PostGIS is the [PostgreSQL Yum repository](http://yum.postgresql.org/)
+Refer to [Installing PostGIS 3.1 and PostgreSQL 13 on CentOS 8](https://people.planetpostgresql.org/devrim/index.php?/archives/107-Installing-PostGIS-3.1-and-PostgreSQL-13-on-CentOS-8.html)
+ [repository RPM](http://yum.postgresql.org/repopackages.php) for your distribution, download and install it.
+## Ubuntu / Debian
+* [UbuntuGIS](https://wiki.ubuntu.com/UbuntuGIS) project has PostGIS and other OSGeo project offerings
+* The PostgreSQL build team has packages for Debian and Ubuntu for several versions of PostgreSQL and PostGIS [APT repository](https://wiki.postgresql.org/wiki/Apt) for PostgreSQL builds. [PostgreSQL Apt Repo PostGIS 2.4 install covers 10](http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS24UbuntuPGSQL10Apt)
+* The [Debian GIS](https://pkg-grass.alioth.debian.org/) project maintains [PostGIS packaging](https://tracker.debian.org/postgis) for Debian also used by Ubuntu and UbuntuGIS.
 ## OSX
@@ -33,26 +50,10 @@ Binary distributions of PostGIS are available for various operating systems.
 * The [builds from KyngChaos](http://www.kyngchaos.com/software/postgres) are a little dated but useful for older PostGIS versions. Read the instructions carefully.
   Do not mix with other installations.
-## Red Hat / Centos / Scientific Linux
-* The best place to get the latest binaries for both PostgreSQL and PostGIS is the [PostgreSQL Yum repository](http://yum.postgresql.org/)
-  1. Choose the correct "[repository RPM](http://yum.postgresql.org/repopackages.php)" for your distribution, download and install it.
-  2. Install PostGIS and dependencies by running `yum install postgis2_93`. (where 93 refers to minor version of PostgreSQL you installed.
-  3. Refer to [Install PostgreSQL 9.5, PostGIS 2.2, pgRouting 2.1 with Yum](http://www.postgresonline.com/journal/archives/362-An-almost-idiots-guide-to-install-PostgreSQL-9.5,-PostGIS-2.2-and-pgRouting-2.1.0-with-Yum.html) for more detailed instructions.
-## Ubuntu / Debian
-* [UbuntuGIS](https://wiki.ubuntu.com/UbuntuGIS) project has PostGIS and other OSGeo project offerings
-* The PostgreSQL build team has packages for Debian and Ubuntu for several versions of PostgreSQL and PostGIS [APT repository](https://wiki.postgresql.org/wiki/Apt) for PostgreSQL builds. [PostgreSQL Apt Repo PostGIS 2.4 install covers 10](http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS24UbuntuPGSQL10Apt)
-* The [Debian GIS](https://pkg-grass.alioth.debian.org/) project maintains [PostGIS packaging](https://tracker.debian.org/postgis) for Debian also used by Ubuntu and UbuntuGIS.
-##OpenSUSE and SUSE
-* [OpenSUSE PostGIS 2.1](http://software.opensuse.org/package/postgis21) For OpenSUSE 13.1, 12.3, Tumbleweed, SUSE SLE-11 SP 3
-##Distributions targeting more than one OS (these include PostgreSQL and many other PostgreSQL extensions)
-* [BigSQL](http://www.bigsql.org/postgresql/installers.jsp) - Supports 64-bit for Linux (RedHat, Debian), MacOSX 64-bit, and Windows 64-bit.
-  It generally has latest version of PostGIS and ogrfdw for all OS supported. As such, it’s ideal if you have users on different OS and want a consistent set of PostGIS related features for all.
-  Refer to [BigSQL: PostGIS Install](http://www.bigsql.org/docs/postgis/postgis.jsp) and [BigSQL: How to create a Spatial Database](https://www.openscg.com/2017/02/postgis-how-to-create-a-spatial-database-with-pgc-command-line/) for PostGIS specific install instructions.
+## OpenSUSE and SUSE
+* [OpenSUSE](https://build.opensuse.org/package/show/Application:Geo/postgis) For OpenSUSE
+## Distributions targeting more than one OS (these include PostgreSQL and many other PostgreSQL extensions)
 * [EnterpriseDb PostgreSQL](http://www.enterprisedb.com/products-services-training/pgdownload) - Supports 32-bit/64-bit Linux, MacOSX, Windows
   Note that the MacOSX PostGIS package
   and EDB Windows PostGIS package have different maintainers, so offerings are not equivalent.
@@ -66,8 +67,7 @@ Binary distributions of PostGIS are available for various operating systems.
 # Getting Started
-These instructions are for PostgreSQL 9.1 and higher, PostGIS 2.2 and higher that is compiled with raster support.
-Note: if you have postgis, without raster support, you can not use CREATE EXTENSION. Refer to [PostGIS install](/docs/postgis_installation.html#install_short_version).
+In order to use PostGIS you first need to [install the binaries](#binary-installers).  You can install these via package managers or compile PostGIS yourself.
 ## Enabling PostGIS
@@ -129,9 +129,9 @@ ALTER EXTENSION postgis_tiger_geocoder
 ## Spatial SQL
-See the [documentation]({{ pcurl('documentation') }}) for more guidance.
+See the [documentation](/documentation) for more guidance.
-{{< highlight sql>}}-- Create table with spatial column
+{{< highlight postgres>}}-- Create table with spatial column
 CREATE TABLE mytable (
   id SERIAL PRIMARY KEY,
   geom GEOMETRY(Point, 26910),
Summary of changes:
 .../assets => assets}/sass/_custom.sass            | 12 ++++++
 assets/sass/_override.sass                         | 12 +-----
 assets/sass/_variables.sass                        |  8 ++--
 content/pages/install.md                           | 48 +++++++++++-----------
 4 files changed, 41 insertions(+), 39 deletions(-)
 copy {themes/hugo-clarity/assets => assets}/sass/_custom.sass (73%)
hooks/post-receive
postgis.net
