[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-615-g1d5778cdf
Sat Feb 26 20:58:28 PST 2022
the project "PostGIS".
       via  1d5778cdfadfbc02725b77cb2563737766de66d1 (commit)
      from  efb9ad2bc47aff6ca8164d086d5e06230e1d0f66 (commit)
revisions in full, below.
commit 1d5778cdfadfbc02725b77cb2563737766de66d1
Author: Jim Jones <jim.jones at uni-muenster.de>
Date:   Sat Feb 26 23:38:16 2022 -0500
    Regress fix for marc21 on windows
    Closes #5104
    Closes https://github.com/postgis/postgis/pull/673
diff --git a/regress/core/out_marc21.sql b/regress/core/out_marc21.sql
index f3d11533b..0849aada4 100644
--- a/regress/core/out_marc21.sql
+++ b/regress/core/out_marc21.sql
@@ -485,7 +485,7 @@ SELECT 'polygon_17',
 			  <subfield code="g">N0350200</subfield>
 			</datafield>
 		  </record>'),
-	  4326),'hddd.dddddddddddddddddddddddddddddddddddddddddd');
+	  4326),'hddd.ddddd');
 SELECT 'polygon_18',
   ST_AsMARC21(
@@ -500,7 +500,7 @@ SELECT 'polygon_18',
 			</datafield>
 		  </record>'),
-	  4326),'hdddmm.mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm');
+	  4326),'hdddmm.mmmmm');
 SELECT 'polygon_19',
   ST_AsMARC21(
@@ -515,7 +515,7 @@ SELECT 'polygon_19',
 			</datafield>
 		  </record>'),
-	  4326),'hdddmmss.sssssssssssssssssssssssssssssssssssssssssss');
+	  4326),'hdddmmss.sssss');
 SELECT 'polygon_20',
   ST_AsMARC21(
@@ -682,7 +682,7 @@ SELECT 'polygon_30',
 			  <subfield code="g">S0514450</subfield>
 			</datafield>
 		  </record>'),
-	  4326),'hdddmmss.ssssssssssssssssssss');
 SELECT 'polygon_31',
@@ -698,7 +698,7 @@ SELECT 'polygon_31',
 			</datafield>
 		  </record>'),
 -- ERROR: invalid format
@@ -716,7 +716,7 @@ SELECT 'error_1',
 			</datafield>
 		  </record>'),
-	4326),'h.dddmmss.ssssssssssssssssssss');
+	4326),'h.dddmmss.sssss');
 SELECT 'error_2',
   ST_AsMARC21(
diff --git a/regress/core/out_marc21_expected b/regress/core/out_marc21_expected
index 812e793a5..5487b8205 100644
--- a/regress/core/out_marc21_expected
+++ b/regress/core/out_marc21_expected
@@ -781,9 +781,9 @@ polygon_13|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" i
 polygon_14|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E126.416667</subfield><subfield code="e">E129.258333</subfield><subfield code="f">N036.127222</subfield><subfield code="g">N035.033333</subfield></datafield></record>
 polygon_15|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E12625.000000</subfield><subfield code="e">E12915.500000</subfield><subfield code="f">N03607.633333</subfield><subfield code="g">N03503.000000</subfield></datafield></record>
 polygon_16|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E1262500.000000</subfield><subfield code="e">E1291530.000000</subfield><subfield code="f">N0360738.000000</subfield><subfield code="g">N0350200.000000</subfield></datafield></record>
-polygon_17|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E126.416666666666671403618238400667905807495117</subfield><subfield code="e">E129.258333333333325754210818558931350708007812</subfield><subfield code="f">N036.127222222222222569598670816048979759216309</subfield><subfield code="g">N035.033333333333331438552704639732837677001953</subfield></datafield></record>
-polygon_18|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E12625.000000000000284217094304040074348449707031250</subfield><subfield code="e">E12915.499999999999545252649113535881042480468750000</subfield><subfield code="f">N03607.633333333333354175920248962938785552978515625</subfield><subfield code="g">N03502.999999999999886313162278383970260620117187500</subfield></datafield></record>
-polygon_19|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E1262500.0000000000170530256582424044609069824218750</subfield><subfield code="e">E1291529.9999999999727151589468121528625488281250000</subfield><subfield code="f">N0360738.0000000000012505552149377763271331787109375</subfield><subfield code="g">N0350200.0000000000068212102632969617843627929687500</subfield></datafield></record>
+polygon_17|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E126.41667</subfield><subfield code="e">E129.25833</subfield><subfield code="f">N036.12722</subfield><subfield code="g">N035.03333</subfield></datafield></record>
+polygon_18|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E12625.00000</subfield><subfield code="e">E12915.50000</subfield><subfield code="f">N03607.63333</subfield><subfield code="g">N03503.00000</subfield></datafield></record>
+polygon_19|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E1262500.00000</subfield><subfield code="e">E1291530.00000</subfield><subfield code="f">N0360738.00000</subfield><subfield code="g">N0350200.00000</subfield></datafield></record>
 polygon_20|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">1262500</subfield><subfield code="e">1291530</subfield><subfield code="f">0360738</subfield><subfield code="g">0350200</subfield></datafield></record>
 polygon_21|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">126.41667</subfield><subfield code="e">129.25833</subfield><subfield code="f">036.12722</subfield><subfield code="g">035.03333</subfield></datafield></record>
 polygon_22|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">12625.0000</subfield><subfield code="e">12915.5000</subfield><subfield code="f">03607.6333</subfield><subfield code="g">03503.0000</subfield></datafield></record>
@@ -794,9 +794,9 @@ polygon_26|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" i
 polygon_27|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">-0584745,0000</subfield><subfield code="e">-0582451,0000</subfield><subfield code="f">-0513416,0000</subfield><subfield code="g">-0514450,0000</subfield></datafield></record>
 polygon_28|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">-058,79583</subfield><subfield code="e">-058,41417</subfield><subfield code="f">-051,57111</subfield><subfield code="g">-051,74722</subfield></datafield></record>
 polygon_29|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">126,41667</subfield><subfield code="e">129,25833</subfield><subfield code="f">036,12722</subfield><subfield code="g">035,03333</subfield></datafield></record>
-polygon_30|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">W0584745.00000000000341060513</subfield><subfield code="e">W0582450.99999999999965893949</subfield><subfield code="f">S0513416.00000000001443822839</subfield><subfield code="g">S0514449.99999999999204192136</subfield></datafield></record>
-polygon_31|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E1262500.00000000001705302566</subfield><subfield code="e">E1291529.99999999997271515895</subfield><subfield code="f">N0360738.00000000000125055521</subfield><subfield code="g">N0350200.00000000000682121026</subfield></datafield></record>
-ERROR:  invalid output format: "h.dddmmss.ssssssssssssssssssss"
+polygon_30|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">W0584745.00000</subfield><subfield code="e">W0582451.00000</subfield><subfield code="f">S0513416.00000</subfield><subfield code="g">S0514450.00000</subfield></datafield></record>
+polygon_31|<record xmlns="http://www.loc.gov/MARC21/slim"><datafield tag="034" ind1="1" ind2=" "><subfield code="a">a</subfield><subfield code="d">E1262500.00000</subfield><subfield code="e">E1291530.00000</subfield><subfield code="f">N0360738.00000</subfield><subfield code="g">N0350200.00000</subfield></datafield></record>
+ERROR:  invalid output format: "h.dddmmss.sssss"
 ERROR:  invalid output format: "hddd.mmmm"
 ERROR:  invalid output format: "ddd.mmmm"
 ERROR:  invalid output format: "hdddmmmss"
Summary of changes:
 regress/core/out_marc21.sql      | 12 ++++++------
 regress/core/out_marc21_expected | 12 ++++++------
 2 files changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
