[postgis-tickets] [SCM] postgis.net branch hugo updated. 3637f4b6b077483970220be07a1db4821f681000
Sun Feb 27 22:02:09 PST 2022
the project "postgis.net".
The branch, hugo has been updated
       via  3637f4b6b077483970220be07a1db4821f681000 (commit)
      from  5d9faf678ce709f07caffa4fdf039eecb2b117ec (commit)
revisions in full, below.
commit 3637f4b6b077483970220be07a1db4821f681000
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Feb 28 01:02:02 2022 -0500
    Get rid of blank lines in smartcodes, they add white space. Change .editorconfig to not force a new line
diff --git a/.editorconfig b/.editorconfig
index fcb5d58..0e41387 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -8,7 +8,7 @@ root = true
 charset = utf-8
 end_of_line = lf
 trim_trailing_whitespace = true
-insert_final_newline = true
+insert_final_newline = false
 # Program files
 [*.{pl,php,html,.md}]
diff --git a/content/pages/documentation.md b/content/pages/documentation.md
index 3cd0f51..56577cb 100644
--- a/content/pages/documentation.md
+++ b/content/pages/documentation.md
@@ -10,6 +10,7 @@ singlecolumn: true
 sidebar: false
+Versions that have reached end of life can still be downloaded from [PostGIS Release docs]({{< loc "postgis.release_docs">}}).
 {{< columns >}}
 ## Stable Branch User Documentation
@@ -27,9 +28,8 @@ translate the manual into your language of choice go to [PostGIS Transifex](http
 ## Can't find your version listed here? it's been EOL'd
 Refer to our [Version compatibility and EOL Policy](/eol_policy) for details.
-Versions that have reached end of life can still be downloaded from [PostGIS Release docs]({{< loc "postgis.release_docs">}}).
----column---
+</div>
+<div>
 ## Search Docs
 Type search criteria here and enter:
@@ -67,6 +67,7 @@ window.location.href=url;
 * [Planet PostGIS](http://planet.postgis.net) - keep a pulse on what people are saying about PostGIS and learn how to take advantage of new features as they are added.
 * [GIS Stack Exchange](http://gis.stackexchange.com/questions/tagged/postgis) may already have your answer: search before you ask!
-{{< / columns >}}
+</div>
+</div>
diff --git a/content/pages/install.md b/content/pages/install.md
index 2320c47..d5ad47b 100644
--- a/content/pages/install.md
+++ b/content/pages/install.md
@@ -24,7 +24,7 @@ Production ready PostGIS Docker builds can be pulled from <a href="https://regis
 ## Windows
-* More details about getting up and running with windows can be found on [Windows Downloads]({{ pcurl('windows_downloads') }}) page.
+* More details about getting up and running with windows can be found on [Windows Downloads](/windows_downloads) page.
 ## Red Hat / Centos / Scientific Linux
diff --git a/layouts/shortcodes/columns.html b/layouts/shortcodes/columns.html
index 91a0b7b..507842b 100644
--- a/layouts/shortcodes/columns.html
+++ b/layouts/shortcodes/columns.html
@@ -1,7 +1,2 @@
-<div class="grid-container">
-	{{ range $index, $value := split .Inner "---column---" }}
-	<!-- start column -->
-			<div>{{ . | $.Page.RenderString }}</div>
-	<!-- end column -->
-	{{ end }}
+<div class="grid-container">{{ range $index, $value := split .Inner "---column---" }}<!-- start column --><div>{{ . | $.Page.RenderString }}</div><!-- end column -->{{ end }}
 </div>
diff --git a/layouts/shortcodes/loc.html b/layouts/shortcodes/loc.html
index cf2f4dd..060b368 100644
--- a/layouts/shortcodes/loc.html
+++ b/layouts/shortcodes/loc.html
@@ -1,11 +1 @@
-{{ $var :=  (.Get 0)  }}
-{{- if eq $var "postgis.version" }}{{ site.Params.postgis.version}}{{- end }}
-{{- if eq $var "postgis.release_docs" }}
-{{ site.Params.postgis.release_docs}}{{- print "" -}}
-{{- end }}
-{{- if eq $var "postgis.release_source" }}
-{{ site.Params.postgis.release_source}}{{- print "" -}}
-{{- end }}
-{{- if eq $var "postgis.release_notes" }}{{ site.Params.postgis.release_notes}}{{- print "" -}}{{- end }}
-{{- if eq $var "site.root" }}{{ site.BaseURL}}{{- print "" -}}{{- end }}
+{{- $var :=  (.Get 0)  }}{{- $data := newScratch }}{{- $data.Set $var "" }}{{- if eq $var "postgis.version" }}{{ $data.Set $var site.Params.postgis.version}}{{- end }}{{- if eq $var "postgis.release_docs" }}{{$data.Set $var site.Params.postgis.release_docs}}{{end }}{{- if eq $var "postgis.release_source" }}{{- $data.Set $var site.Params.postgis.release_source}}{{- end }}{{- if eq $var "postgis.release_notes" }}{{ $data.Set $var site.Params.postgis.release_notes}}{{end }}{{- if eq $var "site.root" }}{{  $data.Set $var site.BaseURL}}{{- end }}{{- $data.Get $var}}
\ No newline at end of file
Summary of changes:
 .editorconfig                   |  2 +-
 content/pages/documentation.md  |  9 +++++----
 content/pages/install.md        |  2 +-
 layouts/shortcodes/columns.html |  7 +------
 layouts/shortcodes/loc.html     | 12 +-----------
 5 files changed, 9 insertions(+), 23 deletions(-)
hooks/post-receive
postgis.net
