[postgis-tickets] [SCM] postgis.net branch hugo updated. d5cefbd7045905e7540d96deb4439a1e1616a882
Mon Feb 28 00:05:30 PST 2022
the project "postgis.net".
The branch, hugo has been updated
       via  d5cefbd7045905e7540d96deb4439a1e1616a882 (commit)
      from  ceb3203ccad7daeead3d8d12c0b8548357b40a98 (commit)
revisions in full, below.
commit d5cefbd7045905e7540d96deb4439a1e1616a882
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Feb 28 03:05:25 2022 -0500
    More cleanup
diff --git a/content/post/2017/06-05_postgis-backend-is-already-set.html b/content/post/2017/06-05_postgis-backend-is-already-set.md
similarity index 93%
rename from content/post/2017/06-05_postgis-backend-is-already-set.html
rename to content/post/2017/06-05_postgis-backend-is-already-set.md
index 492bce4..08daaf7 100644
--- a/content/post/2017/06-05_postgis-backend-is-already-set.html
+++ b/content/post/2017/06-05_postgis-backend-is-already-set.md
@@ -4,9 +4,9 @@ layout: post
 category: tips
 tags: [newbie, upgrade]
 author: Regina Obe
+date: "2017-06-05"
 thumbnail: postgis.png
-<--markdown-->
 The error 'postgis.backend' is already set comes up every so often in PostGIS mailing list.
 The issue arises often during or after an upgrade. I'll go over causes for this I am aware of and how to fix.
@@ -33,11 +33,11 @@ The fix for this is to run the old **legacy_uninstall.sql** and reinstall the ne
 So for example, if I had 2.1 legacy scripts installed and I'm on ubuntu.
 I would connect to by database using psql:
-{% geshi 'sh' %}
+```sh
 \connect gisdb
 \i /usr/share/postgresql/9.4/contrib/postgis-2.1/uninstall_legacy.sql
--- only if you want still need legacy functions
+# only if you want still need legacy functions
 \i /usr/share/postgresql/9.4/contrib/postgis-2.3/legacy.sql
@@ -91,22 +91,21 @@ ORDER BY probin;
 In a good, install, you should have only one row that looks something like
 this.  Your version number might be different.
-<pre>
-		probin       | count
- $libdir/postgis-2.4 |   446
-(1 row)
-</pre>
+	|   probin            | count |
+	|$libdir/postgis-2.4  |   446 |
 If you have more than one row, such as:
-<pre>
-		probin       | count
+| probin               | count
   $libdir/postgis-2.1 |   4
 (1 row)
-</pre>
 then run this query to list the offending functions
Summary of changes:
 ...tml => 06-05_postgis-backend-is-already-set.md} | 23 +++++++++++-----------
 1 file changed, 11 insertions(+), 12 deletions(-)
 rename content/post/2017/{06-05_postgis-backend-is-already-set.html => 06-05_postgis-backend-is-already-set.md} (93%)
hooks/post-receive
postgis.net
