[postgis-tickets] [PostGIS] #5108: postgis30_11 rpm packages missing signatures
PostGIS trac at osgeo.org
Mon Feb 28 20:37:26 PST 2022
 Reporter:  rchowson  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.0.6
Component:  postgis   |    Version:  3.0.x
 Keywords:            |
 Recently I performed a reposync for the postgresql yum repo
 (https://yum.postgresql.org/11/redhat/rhel-8-x86_64/).
 On completing, it was found that new packages had been downloaded, but
 closer inspection revealed that they had not been signed with the
 appropriate GPG key:
 postgis30_11-3.0.5-1.rhel8.x86_64.rpm: digests OK
 postgis30_11-client-3.0.5-1.rhel8.x86_64.rpm: digests OK
 postgis30_11-devel-3.0.5-1.rhel8.x86_64.rpm: digests OK
 postgis30_11-docs-3.0.5-1.rhel8.x86_64.rpm: digests OK
 postgis30_11-gui-3.0.5-1.rhel8.x86_64.rpm: digests OK
 postgis30_11-utils-3.0.5-1.rhel8.x86_64.rpm: digests OK
 These packages need to be signed and uploaded to the repo again so that it
 is possible to check the integrity of the packages using rpm and the
 appropriate GPG key.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5108>
