[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0-19-g13be039f8
Wed Jan 5 16:12:11 PST 2022
the project "PostGIS".
The branch, main has been updated
       via  13be039f8b0a4816458a3562b4070f87e1950aa9 (commit)
      from  9647b4667cdc49e0c4ea5e18c0dbe61589f2ed56 (commit)
revisions in full, below.
commit 13be039f8b0a4816458a3562b4070f87e1950aa9
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 6 01:11:51 2022 +0100
    Cleanup imagemagick's convert checking
diff --git a/configure.ac b/configure.ac
index c85bdd73d..7aa6b8117 100644
--- a/configure.ac
+++ b/configure.ac
@@ -199,8 +199,8 @@ fi
 CAN_BUILD_PDF=${CAN_BUILD_COMMENTS}
-AC_PATH_PROG([IMAGEMAGICK], [convert], [])
-if test "x$IMAGEMAGICK" = "x"; then
+AC_PATH_PROG([CONVERT], [convert], [])
+if test "x$CONVERT" = "x"; then
 	AC_MSG_WARN([ImageMagick does not seem to be installed. Documentation cannot be built])
   CAN_BUILD_PDF=no
 fi
@@ -1808,7 +1808,7 @@ AC_MSG_RESULT([ -------- Documentation Generation -------- ])
 AC_MSG_RESULT([  xsltproc:             ${XSLTPROC}])
 AC_MSG_RESULT([  xsl style sheets:     ${XSLBASE}])
 AC_MSG_RESULT([  dblatex:              ${DBLATEX}])
-AC_MSG_RESULT([  convert:              ${IMAGEMAGICK}])
+AC_MSG_RESULT([  convert:              ${CONVERT}])
 AC_MSG_RESULT([  mathml2.dtd:          ${MATHML2_DTD}])
 AC_MSG_RESULT()
diff --git a/doc/Makefile.in b/doc/Makefile.in
index fbb93c118..f46dbc414 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -79,9 +79,6 @@ CHUNK_HTML_DOCBOOK_XSL=$(XSLBASE)/html/chunk.xsl
 # DBLatex's dblatex script for PDF generation from DocBook
 DBLATEX=@DBLATEX@
-# Imagemagick's convert utility program for generated images used in the documentation
-IMAGEMAGICK=@IMAGEMAGICK@
 # Gettext for translated documentation
 MSGMERGE=@MSGMERGE@
@@ -482,15 +479,6 @@ requirements_not_met_xslbase:
 	@echo "  http://postgis.net/documentation"
 	@echo
-requirements_not_met_imagemagick:
-	@echo
-	@echo "configure was unable to find the ImageMagick's 'convert' utility program."
-	@echo "To build the documentation, install ImageMagick and then re-run configure. Alternatively "
-	@echo "refer to online manual:"
-	@echo
-	@echo "  http://postgis.net/documentation"
-	@echo
 requirements_not_met_gettext:
 	@echo
 	@echo "configure was unable to find both gettext's 'msgmerge' utility program."
Summary of changes:
 configure.ac    |  6 +++---
 doc/Makefile.in | 12 ------------
 2 files changed, 3 insertions(+), 15 deletions(-)
hooks/post-receive
