[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-218-g969f4b716
Thu Jan 13 08:53:58 PST 2022
the project "PostGIS".
       via  969f4b71682ce790004328360762d183af221da1 (commit)
      from  41cc0731ea1c5579a92a811c3cd1ffc8f08cdaf7 (commit)
revisions in full, below.
commit 969f4b71682ce790004328360762d183af221da1
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 13 02:28:59 2022 +0100
    Allow passing additional run test flags to check_all_upgrades.sh
    This may be useful to test upgrades while having postgis function
    point to non-existent SO object.
    See https://trac.osgeo.org/postgis/ticket/5046#comment:3
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 80b9231c5..c182569c4 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -88,6 +88,8 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
     echo "SKIP: don't know where to find regress tests for extension ${EXT}"
   fi
+  USERTESTFLAGS=${RUNTESTFLAGS}
   # Check extension->extension upgrades
   files=`'ls' ${EXT}--* | grep -v -- '--.*--' | sed "s/^${EXT}--\(.*\)\.sql/\1/"`
   for fname in $files; do
@@ -102,7 +104,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
     fi
     if test -e ${UPGRADE_FILE}; then
       echo "Testing ${EXT} upgrade $UPGRADE_PATH"
-      export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
+      RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
       make -C ${REGDIR} check && {
         echo "PASS: upgrade $UPGRADE_PATH"
@@ -124,7 +126,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do
       continue
     fi
Summary of changes:
 utils/check_all_upgrades.sh | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
hooks/post-receive
