[postgis-tickets] [SCM] PostGIS branch out-of-build-docs updated. 3.2.0-379-g99809f9f1
Thu Jan 27 08:32:25 PST 2022
the project "PostGIS".
The branch, out-of-build-docs has been updated
       via  99809f9f1a0391b2dc44b4eaff94a2bbf3cf2852 (commit)
      from  146820e013003c0c2a19a322ae0a1cdf4fcc22ce (commit)
revisions in full, below.
commit 99809f9f1a0391b2dc44b4eaff94a2bbf3cf2852
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 27 17:31:36 2022 +0100
    [generator] Add support for taking output in commandline
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index b9eb57487..0732acb99 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -2,6 +2,8 @@
  * PostGIS - Spatial Types for PostgreSQL
  * http://postgis.net
+ * Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
  * Copyright 2008 Kevin Neufeld
  * This is free software; you can redistribute and/or modify it under
@@ -334,26 +336,33 @@ int main( int argc, const char* argv[] )
 	char *filename;
 	int layerCount;
 	LAYERSTYLE *styles;
-	char *image_path = "../images/";
-	getStyles(&styles);
+	const char *image_src;
-	if ( argc != 2 || strlen(argv[1]) < 3)
+	if ( argc < 2 || strlen(argv[1]) < 3)
-		lwerror("You must specify a wkt filename to convert, and it must be 3 or more characters long.\n");
+		lwerror("Usage: %s <source_wktfile> [<output_pngfile>]", argv[0]);
 		return -1;
-	if ( (pfile = fopen(argv[1], "r")) == NULL)
+	image_src = argv[1];
+	if ( (pfile = fopen(image_src, "r")) == NULL)
-		perror ( argv[1] );
+		perror ( image_src );
 		return -1;
-	filename = malloc( strlen(argv[1]) + strlen(image_path) + 1 );
-	strcpy( filename, image_path );
-	strncat( filename, argv[1], strlen(argv[1])-3 );
-	strncat( filename, "png", 3 );
+	getStyles(&styles);
+	if ( argc > 2 )
+		filename = strdup(argv[2]);
+	else
+		filename = strdup(image_src);
+		sprintf(filename + strlen(image_src) - 3, "png" );
 	printf( "generating %s\n", filename );
@@ -390,7 +399,7 @@ int main( int argc, const char* argv[] )
 		ptr += sprintf( ptr, "-flip tmp%d.png", layerCount );
-		lwfree( lwgeom );
+		lwgeom_free( lwgeom );
 		LWDEBUGF( 4, "%s", output );
 		checked_system(output);
Summary of changes:
 doc/html/image_src/generator.c | 33 +++++++++++++++++++++------------
 1 file changed, 21 insertions(+), 12 deletions(-)
hooks/post-receive
