[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-382-g82fe97d43
Thu Jan 27 09:19:35 PST 2022
the project "PostGIS".
       via  82fe97d436ab8a5ad726fba5464c341295c1ef8a (commit)
       via  193f0510f3b516d77a0cdd4549dcf681dbcc9ed9 (commit)
       via  e9bb35128b80fe9b2f29229ffc390dbad7810958 (commit)
       via  286625d4807fe44f5bf0a5334f6eeba08685a35f (commit)
      from  0cfdff58c3de7266d8b799350fdff4fb3d61a4d5 (commit)
revisions in full, below.
commit 82fe97d436ab8a5ad726fba5464c341295c1ef8a
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jan 27 17:59:06 2022 +0100
    Fix `make images` in out-of-tree builds
diff --git a/doc/html/image_src/Makefile.in b/doc/html/image_src/Makefile.in
index aa71d19d9..2f535e01a 100644
--- a/doc/html/image_src/Makefile.in
+++ b/doc/html/image_src/Makefile.in
@@ -2,6 +2,8 @@
 # * PostGIS - Spatial Types for PostgreSQL
 # * http://postgis.net
+# * Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
 # * Copyright 2008 Kevin Neufeld
 # * This is free software; you can redistribute and/or modify it under
@@ -181,6 +183,9 @@ OBJS=styles.o generator.o
 # Build the generator
 all: generator
+images_dir:
+	mkdir -p ../images
 # generate the images
 images: $(IMAGES) $(IMAGES_RESIZED)
@@ -189,12 +194,12 @@ $(OBJS): %.o: %.c
 	$(CC) $(CPPFLAGS) $(CFLAGS) -c -o $@ $<
 # Command to build each of the .wkt files
-$(IMAGES): ../images/%.png: %.wkt generator styles.conf
-	@./generator $<
+$(IMAGES): ../images/%.png: %.wkt generator styles.conf | images_dir
+	@./generator $< $@
 # Command to resize each of the images
-$(IMAGES_RESIZED): ../images/%.png: %.wkt generator styles.conf
-	@./generator $<
+$(IMAGES_RESIZED): ../images/%.png: %.wkt generator styles.conf | images_dir
 	convert $@ -resize 100x100 $@
 # Build the main executable
commit 193f0510f3b516d77a0cdd4549dcf681dbcc9ed9
Date:   Thu Jan 27 17:50:32 2022 +0100
    [generator] look for styles.conf in the dir containing image source
diff --git a/doc/html/image_src/generator.c b/doc/html/image_src/generator.c
index 0732acb99..d53d9cd30 100644
--- a/doc/html/image_src/generator.c
+++ b/doc/html/image_src/generator.c
@@ -336,7 +336,10 @@ int main( int argc, const char* argv[] )
 	char *filename;
 	int layerCount;
 	LAYERSTYLE *styles;
+	char *stylefile_path;
 	const char *image_src;
+	char *ptr;
+	const char *stylefilename = "styles.conf";
 	if ( argc < 2 || strlen(argv[1]) < 3)
@@ -352,7 +355,23 @@ int main( int argc, const char* argv[] )
 		return -1;
-	getStyles(&styles);
+	/* Get style */
+	ptr = rindex( image_src, '/' );
+	if ( ptr ) /* source image file has a slash */
+		size_t dirname_len = (ptr - image_src);
+		stylefile_path = malloc( strlen(stylefilename) + dirname_len + 2);
+		/* copy the directory name */
+		memcpy(stylefile_path, image_src, dirname_len);
+		sprintf(stylefile_path + dirname_len, "/%s", stylefilename);
+	else /* source image file has no slash, use CWD */
+		stylefile_path = strdup(stylefilename);
+	printf("reading styles from %s\n", stylefile_path);
+	getStyles(stylefile_path, &styles);
+	free(stylefile_path);
 	if ( argc > 2 )
diff --git a/doc/html/image_src/styles.c b/doc/html/image_src/styles.c
index 35fdfb676..d22c0ae12 100644
--- a/doc/html/image_src/styles.c
+++ b/doc/html/image_src/styles.c
@@ -20,7 +20,7 @@
 void
-getStyles( LAYERSTYLE **headRef )
+getStyles( const char *filename, LAYERSTYLE **headRef )
 	char line [128];
 	FILE* pFile;
@@ -28,9 +28,9 @@ getStyles( LAYERSTYLE **headRef )
 	*headRef = NULL;
-	if ((pFile = fopen("styles.conf", "r")) == NULL)
+	if ((pFile = fopen(filename, "r")) == NULL)
-		perror ( "styles.conf: No such file or directory" );
+		perror ( filename );
 		return;
diff --git a/doc/html/image_src/styles.h b/doc/html/image_src/styles.h
index 04c4fc260..78144e5d8 100644
--- a/doc/html/image_src/styles.h
+++ b/doc/html/image_src/styles.h
@@ -33,7 +33,7 @@ struct layerStyle
 	LAYERSTYLE *next;
-void getStyles( LAYERSTYLE **headRef );
+void getStyles( const char *filename, LAYERSTYLE **headRef );
 void freeStyles( LAYERSTYLE **headRef );
 void addStyle( LAYERSTYLE **headRef, char* styleName, int pointSize, char* pointColor, int lineWidth, char* lineColor, char* polygonFillColor, char* polygonStrokeColor, int polygonStrokeWidth );
commit e9bb35128b80fe9b2f29229ffc390dbad7810958
Date:   Thu Jan 27 17:31:36 2022 +0100
    [generator] Add support for taking output in commandline
index b9eb57487..0732acb99 100644
@@ -2,6 +2,8 @@
+ * Copyright (C) 2022 Sandro Santilli <strk at kbt.io>
@@ -334,26 +336,33 @@ int main( int argc, const char* argv[] )
 	char *filename;
 	int layerCount;
 	LAYERSTYLE *styles;
-	char *image_path = "../images/";
+	const char *image_src;
-	if ( argc != 2 || strlen(argv[1]) < 3)
+	if ( argc < 2 || strlen(argv[1]) < 3)
-		lwerror("You must specify a wkt filename to convert, and it must be 3 or more characters long.\n");
+		lwerror("Usage: %s <source_wktfile> [<output_pngfile>]", argv[0]);
 		return -1;
-	if ( (pfile = fopen(argv[1], "r")) == NULL)
+	image_src = argv[1];
+	if ( (pfile = fopen(image_src, "r")) == NULL)
-		perror ( argv[1] );
+		perror ( image_src );
 		return -1;
-	filename = malloc( strlen(argv[1]) + strlen(image_path) + 1 );
-	strcpy( filename, image_path );
-	strncat( filename, argv[1], strlen(argv[1])-3 );
-	strncat( filename, "png", 3 );
+	getStyles(&styles);
+	if ( argc > 2 )
+		filename = strdup(argv[2]);
+	else
+		filename = strdup(image_src);
+		sprintf(filename + strlen(image_src) - 3, "png" );
 	printf( "generating %s\n", filename );
@@ -390,7 +399,7 @@ int main( int argc, const char* argv[] )
 		ptr += sprintf( ptr, "-flip tmp%d.png", layerCount );
-		lwfree( lwgeom );
+		lwgeom_free( lwgeom );
 		LWDEBUGF( 4, "%s", output );
 		checked_system(output);
commit 286625d4807fe44f5bf0a5334f6eeba08685a35f
Date:   Thu Jan 27 16:59:19 2022 +0100
    Fix out-of-source build of image generator
index 1add81ce4..aa71d19d9 100644
@@ -9,14 +9,18 @@
+top_builddir = @top_builddir@
+top_srcdir = @top_srcdir@
+srcdir = @srcdir@
 CC=@CC@
 CFLAGS=@CFLAGS@ @PROJ_CPPFLAGS@
-top_builddir = @top_builddir@
+CPPFLAGS = -I$(top_builddir)/liblwgeom -I$(top_srcdir)/liblwgeom @CPPFLAGS@
 SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
+LDFLAGS = @LDFLAGS@ @GEOS_LDFLAGS@ @PROJ_LDFLAGS@
-CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
-CUNIT_CPPFLAGS=-I../../../liblwgeom @CUNIT_CPPFLAGS@
+VPATH = $(srcdir)
 IMAGES= \
 	../images/de9im01.png \
@@ -182,7 +186,7 @@ images: $(IMAGES) $(IMAGES_RESIZED)
 # Command to build each of the .o files
 $(OBJS): %.o: %.c
-	$(CC) $(CUNIT_CPPFLAGS) $(CFLAGS) -c -o $@ $<
+	$(CC) $(CPPFLAGS) $(CFLAGS) -c -o $@ $<
@@ -194,9 +198,9 @@ $(IMAGES_RESIZED): ../images/%.png: %.wkt generator styles.conf
-generator: ../../../liblwgeom/.libs/liblwgeom.a $(OBJS)
+generator: $(OBJS) ../../../liblwgeom/.libs/liblwgeom.a
 	$(LIBTOOL) --mode=link \
-	$(CC) -o $@ $(OBJS) ../../../liblwgeom/liblwgeom.la $(CUNIT_LDFLAGS)
+	$(CC) -o $@ $^ $(LDFLAGS)
 # Build liblwgeom
 ../../../liblwgeom/.libs/liblwgeom.a:
Summary of changes:
 doc/html/image_src/Makefile.in | 29 +++++++++++++++--------
 doc/html/image_src/generator.c | 52 ++++++++++++++++++++++++++++++++----------
 doc/html/image_src/styles.c    |  6 ++---
 doc/html/image_src/styles.h    |  2 +-
 4 files changed, 63 insertions(+), 26 deletions(-)
hooks/post-receive
