[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-394-ge156a2a7f
Fri Jan 28 00:37:01 PST 2022
the project "PostGIS".
       via  e156a2a7f97095e1fbca82820a665fc584b9cc98 (commit)
       via  69c64a57459fe06359c5257c2065459bdda3edf1 (commit)
      from  3f5cdbc4362424d948f78be7a9663bd0c2c1b9d4 (commit)
revisions in full, below.
commit e156a2a7f97095e1fbca82820a665fc584b9cc98
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jan 28 09:25:36 2022 +0100
    Drop cloud.drone badge from README.md
    it's redundant
diff --git a/README.md b/README.md
index 103250597..148fb3e0d 100644
--- a/README.md
+++ b/README.md
@@ -1,13 +1,13 @@
-| **GitHub** | **GitLab** | **Drone.io** ||
-| [![CI](https://github.com/postgis/postgis/workflows/CI/badge.svg?branch=master)](https://github.com/postgis/postgis/actions?query=branch%3Amaster) |  [![Gitlab-CI](https://gitlab.com/postgis/postgis/badges/master/pipeline.svg)](https://gitlab.com/postgis/postgis/commits/master) |  [![Build Status](https://cloud.drone.io/api/badges/postgis/postgis/status.svg?branch=master)](https://cloud.drone.io/postgis/postgis?branch=master) ||
 | **Debbie** | **Winnie** | **Dronie** ||
 | [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_trunk)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_trunk/) | [![Build Status](https://winnie.postgis.net/buildStatus/icon?job=PostGIS_trunk)](https://winnie.postgis.net/view/PostGIS/job/PostGIS_trunk/) | [![Build Status](https://dronie.osgeo.org/api/badges/postgis/postgis/status.svg?branch=master)](https://dronie.osgeo.org/postgis/postgis?branch=master) ||
-| **Bessie** | **Bessie32** | **Cirrus-ci** |  |
-|  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run%2Flabel%3Dbessie)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/) |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run%2Flabel%3Dbessie32)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/) |  [![Build Status](https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=master)](http://cirrus-ci.com/github/postgis/postgis) |  |
-| **Berrie** | **Berrie64** | | |
-|  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:${params.reference=refs/heads/master})](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/) |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:${params.reference=refs/heads/master})](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/) | | |
+| **Bessie** | **Bessie32** | **Cirrus-ci** ||
+|  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run%2Flabel%3Dbessie)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie/) |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run%2Flabel%3Dbessie32)](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32/) |  [![Build Status](https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=master)](http://cirrus-ci.com/github/postgis/postgis) ||
+| **Berrie** | **Berrie64** | ||
+|  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:${params.reference=refs/heads/master})](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie/) |  [![Build Status](https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:${params.reference=refs/heads/master})](https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64/) | ||
+| **GitHub** | **GitLab** ||
+| [![CI](https://github.com/postgis/postgis/workflows/CI/badge.svg?branch=master)](https://github.com/postgis/postgis/actions?query=branch%3Amaster) | [![Gitlab-CI](https://gitlab.com/postgis/postgis/badges/master/pipeline.svg)](https://gitlab.com/postgis/postgis/commits/master) ||
 This file is here to play nicely with modern code repository facilities.
 Actual readme is [here](README.postgis).
commit 69c64a57459fe06359c5257c2065459bdda3edf1
Date:   Fri Jan 28 09:07:17 2022 +0100
    Drop cloud-drone specific config
diff --git a/.cloud-drone.yml b/.cloud-drone.yml
deleted file mode 100644
index c4c990b74..000000000
--- a/.cloud-drone.yml
+++ /dev/null
@@ -1,38 +0,0 @@
-# This is for the drone 1.0 agent
-# https://docs.drone.io/user-guide/pipeline/steps/
-# https://cloud.drone.io/postgis/ #1.0 server #this is a reduced test
-# See https://git.osgeo.org/gitea/postgis/postgis-docker
-# todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
-test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel2
-kind: pipeline
-name: build
-clone:
-    image: plugins/git
-    depth: 1
-    recursive: false
-steps:
-  - name: autogen
-    image: *test-image
-    pull: always
-    commands:
-      - ./autogen.sh
-    depends_on: [ clone ]
-  - name: build-11
-    pull: never
-    commands:
-      - PGVER=11 sh ci/dronie/postgis_regress.sh
-    depends_on: [ autogen ]
-trigger:
-  branch:
-    exclude:
-      - main
Summary of changes:
 .cloud-drone.yml | 38 --------------------------------------
 README.md        | 14 +++++++-------
 2 files changed, 7 insertions(+), 45 deletions(-)
 delete mode 100644 .cloud-drone.yml
hooks/post-receive
