[postgis-tickets] [PostGIS] #5077: Upgrading from PostGIS 2.4.9 to master (3.3.0dev) on PG12 results in error
PostGIS trac at osgeo.org
Mon Jan 31 23:29:05 PST 2022
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.4.10
 Component:  topology  |    Version:  2.4.x
Resolution:            |   Keywords:
Description changed by robe:
Old description:
> It seems on dronie, we managed to get a PostGIS with 2.4.9 installed in
> PG12.
> Now that we made PG12 live, it is trying to upgrade from PG 12 2.4.9 to
> 3.3.0dev
> and failing on topology.  This looks like issue with changes made in PG12
> they took out.  I think we had fixed the views for geography_columns and
> geometry_columns.  So I suspect a similar change can be made on topology.
> CREATE FUNCTION
> 2147s
> 28875psql:/usr/share/postgresql/12/contrib/postgis-2.4/topology.sql:822:
> NOTICE:  function topology.populate_topology_layer() does not exist,
> skipping
> 2147s
> 28876DROP FUNCTION
> 2147s
> 28877psql:/usr/share/postgresql/12/contrib/postgis-2.4/topology.sql:856:
> ERROR:  column c.consrc does not exist
> 2147s
> 28878LINE 11:     regexp_matches(c.consrc,
> 2147s
> 28879                            ^
> 2147s
> 28880HINT:  Perhaps you meant to reference the column "c.conkey" or the
> column "c.conbin".
> 2147s
> 28881NOTICE:  schema "public" already exists, skipping
> 2147s
> 28882CREATE SCHEMA
> 2147s
> 28883SET
> 2147s
> 28884psql:/usr/share/postgresql/12/contrib/postgis-2.4/topology_comments.sql:2:
> ERROR:  type "topology.getfaceedges_returntype" does not exist
> 2147s
> 28885NOTICE:  schema "public" already exists, skipping
> 2147s
> 28886CREATE SCHEMA
> 2147s
> 28887SET
> 2147s
> 28888psql:/drone/src/topology/test/regress/hooks/hook-before-upgrade-
> topology.sql:1: ERROR:  function topology.createtopology(unknown) does
> not exist
> 2147s
> 28889LINE 1: SELECT topology.createTopology('upgrade_test');
> 2147s
> 28890               ^
> 2147s
> 28891HINT:  No function matches the given name and argument types. You
> might need to add explicit type casts.
> 2147s
> 28892-----------------------------------------------------------------------------
> 2147s
> 28893/drone/src/regress/runtest.mk:22: recipe for target 'check-regress'
> failed
> 2147s
> 28894make: Leaving directory '/tmp/postgis-build/12/topology/test'
> 2147s
> 28895FAIL: postgis_topology upgrade unpackaged2.4--3.3.0dev!
New description:
 PG12.  https://dronie.osgeo.org/postgis/postgis/2702/1/6
 3.3.0dev
 CREATE FUNCTION
 2147s
 skipping
 2147s
 28876DROP FUNCTION
 2147s
 2147s
 2147s
 28879                            ^
 2147s
 column "c.conbin".
 2147s
 2147s
 28882CREATE SCHEMA
 2147s
 28883SET
 2147s
 2147s
 2147s
 28886CREATE SCHEMA
 2147s
 28887SET
 2147s
 topology.sql:1: ERROR:  function topology.createtopology(unknown) does not
 exist
 2147s
 2147s
 28890               ^
 2147s
 2147s
 2147s
 failed
 2147s
 2147s
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5077#comment:1>
