[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0alpha1-117-g6fa645cd6
git at osgeo.org
git at osgeo.org
Sun Jul 3 07:48:47 PDT 2022
the project "PostGIS".
via 6fa645cd67fd70ff92e47cb43a74c33558eb6597 (commit)
via 562715efa91b8f5cecedb09cca821fe37d70d4a2 (commit)
from 4e36085450b43f56a172e8e760b7f95e9a5eaa9c (commit)
revisions in full, below.
commit 6fa645cd67fd70ff92e47cb43a74c33558eb6597
Author: Regina Obe <lr at pcorp.us>
Date: Sun Jul 3 10:48:38 2022 -0400
Prep for release
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 848d10828..0d8745185 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -112,14 +112,14 @@ Release procedure
$ git tag -a $rev -m "Tagged release $rev"
$ git push osgeo --tags
- - Take tar ball from http://postgis.net/stuff/
- (You might need to wait a few minutes to see it.
+ - Take tar ball and md5 from http://postgis.net/stuff/
+ (You might need to wait a few minutes to see it)
If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
If it fails, sh make_dist.sh $rev)
- - Documentation should also have been built and should be in http://postgis.net/stuff
+ - Documentation should also have been built and should be in https://postgis.net/stuff
(this sometimes takes sometime so wait 15 minutes)
- Test generated tarball (including extension upgrade)
- - Copy tarball, pdf, doc-html to https://upload.osgeo.org/postgis/ web site.
+ - Copy tarball, md5, pdf, doc-html to https://upload.osgeo.org/postgis/ .
- PostGIS doc release versioned doc - http://postgis.net/documentation/
- On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
diff --git a/NEWS b/NEWS
index 8db49f196..0c3435454 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
PostGIS 3.3.0beta1
-2022/07/02
+2022/07/03
This version requires PostgreSQL 11 or higher, GEOS 3.6 or higher, and Proj 5.2+.
Additional features are enabled if you are running GEOS 3.9+
ST_MakeValid enhancements with 3.10+, numerouse additional enhancements with GEOS 3.11+.
diff --git a/README.postgis b/README.postgis
index d827c7614..66a1e8612 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.3.0alpha1
-:Date: 2022-05-21
+:Version: 3.3.0beta1
+:Date: 2022-07-03
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
@@ -41,7 +41,7 @@ PostGIS is compatible with PostgreSQL 11 and above.
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
-* PROJ4 (Required, Version 4.9.0 or higher):
+* PROJ4 (Required, Version 5.2.0 or higher):
The PROJ4 catographic projection library is required if you want to use the
ST_Transform() function to reproject features within the database.
@@ -49,7 +49,9 @@ this to work.
https://proj.org
* GEOS (Required, Version 3.6 or higher)
- - 3/10+ for ST_MakeValid enhancements
+ - 3.11+ for imporved ST_ConcaveHull, ST_lineMerge,
+ and new functions ST_SimplifyPolygonHull, ST_TriangulatePolygon
+ - 3.10+ for ST_MakeValid enhancements
- 3.9+ is needed to take advantage of
fixed precision enhancements in overlay functions
- 3.7+ is needed just for the ST_FrechetDistance function
@@ -90,6 +92,8 @@ this to work.
must ``./configure --without-raster``
* CGAL 4.1+ and SFCGAL 1.3.2+ (Optional) needed for advanced 3D support
+* SFCGAL 1.4.1+ is requires for additional functionality ST_AlphaShape, ST_OptimalAlphaShape,
+ and ST_3DConvexhull
https://gitlab.com/Oslandia/SFCGAL
@@ -135,6 +139,8 @@ If ``pg_config`` can't be found in your ``$PATH`` configure will complain
and refuse to proceed. You can specify it using the
``--with-pgconfig=/path/to/pg_config`` flag.
+PostGIS supports pkg-config for most dependencies.
If PROJ4 has been installed but cannot be found, configure will complain and
refuse to proceed. You can specify an alternative installation directory using
the ``--with-projdir=DIR`` option.
commit 562715efa91b8f5cecedb09cca821fe37d70d4a2
Date: Sun Jul 3 10:36:29 2022 -0400
Add step in debbie's packaging to generate md5
diff --git a/ci/debbie/postgis_make_dist.sh b/ci/debbie/postgis_make_dist.sh
index 3ad963cb9..4ada3c6fe 100644
--- a/ci/debbie/postgis_make_dist.sh
+++ b/ci/debbie/postgis_make_dist.sh
@@ -31,7 +31,9 @@ export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${PO
sh make_dist.sh
export package=${newoutdir}.tar.gz
+md5sum ${package} > ${package}.md5
echo "The package name is $package"
cp $package $WEB_DIR
+cp ${package}.md5 $WEB_DIR
bash ci/debbie/postgis_release_docs.sh
Summary of changes:
HOWTO_RELEASE | 8 ++++----
NEWS | 2 +-
README.postgis | 14 ++++++++++----
ci/debbie/postgis_make_dist.sh | 2 ++
4 files changed, 17 insertions(+), 9 deletions(-)
hooks/post-receive
