[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta1-15-g070fbec8b
Wed Jul 6 10:59:41 PDT 2022
the project "PostGIS".
       via  070fbec8b683060386df02faf5e442fa52386683 (commit)
      from  1543d3792bf12862bf30da5607e1d871fd5ce6de (commit)
revisions in full, below.
commit 070fbec8b683060386df02faf5e442fa52386683
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Jul 6 10:59:35 2022 -0700
    Improve doc for Linear Ref functions
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 421a739f1..40d0e803d 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -456,15 +456,16 @@ CROSS JOIN LATERAL (
 	  <refsection>
 		<title>Description</title>
-		<para>Returns the locations along a measured geometry (as a Point or MultiPoint)
-		that match a measure value.
-        Polygonal elements are not supported.</para>
+		<para>Returns the location(s) along a measured geometry
+		that have the given measure values.
+        The result is a Point or MultiPoint.
+        Polygonal inputs are not supported.</para>
-		<para>If the <varname>offset</varname> is provided, the result
+		<para>If <varname>offset</varname> is provided, the result
         is offset to the left or right of the input line by the specified distance.
         A positive offset will be to the left, and a negative one to the right.</para>
-		<note><para>Use this function only for geometries with an M component</para></note>
+		<note><para>Use this function only for linear geometries with an M component</para></note>
 		<para>The semantic is specified by the <emphasis>ISO/IEC 13249-3 SQL/MM Spatial</emphasis> standard.</para>
@@ -483,17 +484,15 @@ SELECT ST_AsText(
     'MULTILINESTRINGM((1 2 3, 3 4 2, 9 4 3),(1 2 3, 5 4 5))'::geometry,
     3 ));
-            st_astext
  MULTIPOINT M ((1 2 3),(9 4 3),(1 2 3))
 </programlisting>
 	  </refsection>
-	  <!-- Optionally add a "See Also" section -->
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="ST_LocateBetween" />, <xref linkend="ST_LocateBetweenElevations" /></para>
+		<para><xref linkend="ST_LocateBetween" />, <xref linkend="ST_LocateBetweenElevations" />, <xref linkend="ST_InterpolatePoint" /> </para>
 	  </refsection>
 	</refentry>
@@ -571,7 +570,6 @@ MULTILINESTRING((54.49835019899045 104.53426957938231,58.70056060327303 82.12248
 	  </refsection>
 	  <refsection>
@@ -603,7 +601,7 @@ MULTILINESTRING((54.49835019899045 104.53426957938231,58.70056060327303 82.12248
 		<para>Returns a geometry (collection) with the portions of a geometry
-		that lie in an elevations (Z) range.</para>
+		that lie in an elevation (Z) range.</para>
 		<para>Clipping a non-convex POLYGON may produce invalid geometry.</para>
@@ -636,7 +634,6 @@ SELECT ST_AsText(
 </programlisting>
 	  </refsection>
 	  <refsection>
@@ -645,51 +642,53 @@ SELECT ST_AsText(
 	</refentry>
-		<refentry id="ST_InterpolatePoint">
-		  <refnamediv>
-			<refname>ST_InterpolatePoint</refname>
+    <refentry id="ST_InterpolatePoint">
+        <refnamediv>
+        <refname>ST_InterpolatePoint</refname>
-			<refpurpose>Returns the interpolated measure of a geometry closest to a point.</refpurpose>
-		  </refnamediv>
+        <refpurpose>Returns the interpolated measure of a geometry closest to a point.</refpurpose>
+        </refnamediv>
-		  <refsynopsisdiv>
-			<funcsynopsis>
-			  <funcprototype>
-				<funcdef>float8 <function>ST_InterpolatePoint</function></funcdef>
-				<paramdef><type>geometry </type> <parameter>line</parameter></paramdef>
-				<paramdef><type>geometry </type> <parameter>point</parameter></paramdef>
-			  </funcprototype>
+        <refsynopsisdiv>
+        <funcsynopsis>
+            <funcprototype>
+            <funcdef>float8 <function>ST_InterpolatePoint</function></funcdef>
+            <paramdef><type>geometry </type> <parameter>linear_geom_with_measure</parameter></paramdef>
+            <paramdef><type>geometry </type> <parameter>point</parameter></paramdef>
+            </funcprototype>
-			</funcsynopsis>
-		  </refsynopsisdiv>
+        </funcsynopsis>
+        </refsynopsisdiv>
-		  <refsection>
-			<title>Description</title>
+        <refsection>
+        <title>Description</title>
-			   <para>Returns the value of the measure dimension of a geometry at the point closed to the provided point.</para>
+            <para>Returns an interpolated measure value of a linear measured geometry
+            at the location closest to the given point.</para>
-				<para>Availability: 2.0.0</para>
-			<para>&Z_support;</para>
-		  </refsection>
+            <para>Availability: 2.0.0</para>
-		  <refsection>
-			<title>Examples</title>
+        <para>&Z_support;</para>
+        </refsection>
+        <refsection>
+        <title>Examples</title>
-			<programlisting>SELECT ST_InterpolatePoint('LINESTRING M (0 0 0, 10 0 20)', 'POINT(5 5)');
- st_interpolatepoint
+        <programlisting>SELECT ST_InterpolatePoint('LINESTRING M (0 0 0, 10 0 20)', 'POINT(5 5)');
          10
 	</programlisting>
-		  </refsection>
+        </refsection>
-		  <refsection>
-			<title>See Also</title>
+        <refsection>
+        <title>See Also</title>
-			<para><xref linkend="ST_AddMeasure" />, <xref linkend="ST_LocateAlong" />, <xref linkend="ST_LocateBetween" /></para>
-		  </refsection>
+        <para><xref linkend="ST_AddMeasure" />, <xref linkend="ST_LocateAlong" />, <xref linkend="ST_LocateBetween" /></para>
+        </refsection>
-		</refentry>
+    </refentry>
 	<refentry id="ST_AddMeasure">
Summary of changes:
 doc/reference_lrs.xml | 81 +++++++++++++++++++++++++--------------------------
 1 file changed, 40 insertions(+), 41 deletions(-)
hooks/post-receive
