[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta1-17-gafeaf233e
Fri Jul 8 20:00:02 PDT 2022
the project "PostGIS".
       via  afeaf233e28483768c79243b9345cc33ef625532 (commit)
      from  0a0e35f8fdd4111fda2fa728960767bda0b9f848 (commit)
revisions in full, below.
commit afeaf233e28483768c79243b9345cc33ef625532
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jul 8 22:59:46 2022 -0400
    Remove latest as pg master has now flipped to PG 16.  Replace with pg15.  Also remove pg13 coverage, now replaced with a pg15 coverage
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 5abf48302..455204ae8 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -17,16 +17,17 @@ jobs:
       matrix:
         ci:
         # Use the last stable releases to run more tests
+        - { tag: pg15-geos311-gdal35-proj90, mode: coverage }
+        - { tag: pg15-clang-geos311-gdal35-proj90, mode: usan_clang }
         # - { tag: pg13-geos39-gdal31-proj71, mode: garden }
         - { tag: pg14-geos39-gdal33-proj71, mode: tests }
         - { tag: pg14-clang-geosmain-gdal34-proj71, mode: usan_clang }
         #- { tag: pg13-geos39-gdal31-proj71, mode: tests }
-        - { tag: pg13-geos39-gdal31-proj71, mode: coverage }
+        #- { tag: pg13-geos39-gdal31-proj71, mode: coverage }
         - { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
         - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
         # Run tests with different dependency combinations
-        - { tag: latest, mode: tests }
-        #- { tag: pgmaster-geosmain-gdalmaster-proj90, mode: tests }
+        # - { tag: latest, mode: tests }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
         - { tag: pg12-geos37-gdal30-proj611, mode: tests }
         - { tag: pg11-geos37-gdal24-proj52, mode: tests }
Summary of changes:
 .github/workflows/ci.yml | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
