[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta1-21-g2f915e1e9
Mon Jul 11 09:22:23 PDT 2022
the project "PostGIS".
       via  2f915e1e9813789062d4d87c7a080986514815b7 (commit)
      from  1db19735711247aa69b74e75add07d47d3ea35ab (commit)
revisions in full, below.
commit 2f915e1e9813789062d4d87c7a080986514815b7
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 8 13:04:50 2022 +0200
    Implement topology.RemoveUnusedPrimitives
    Closes #5183
    Includes tests, docs and NEWS entry
diff --git a/.editorconfig b/.editorconfig
index 8c724db4d..e8c970e3e 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -55,6 +55,10 @@ indent_style = space
 [topology/**.{sql,sql.in}]
+# topology/clean SQL files want 2-space indentation
+[topology/sql/cleanup/**.{sql,sql.in}]
+indent_size = 2
 # postgis/sfcgal.sql.in wants space indentation
 [postgis/sfcgal.sql.in]
diff --git a/NEWS b/NEWS
index b5f1a2174..0e04e26c0 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,8 @@ Changes since PostGIS 3.3.0beta1
 * Bug fixes *
   - #5179, pgsql2shp syntax error on big-endian (Bas Couwenberg)
+* New features *
+  - #5183, topology.RemoveUnusedPrimitives (Sandro Santilli)
 PostGIS 3.3.0beta1
 2022/07/03
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 3f7c3897c..dcbf4a425 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -3157,6 +3157,49 @@ faceid
 		  </refsection>
 	</refentry>
+	<refentry id="TP_RemoveUnusedPrimitives">
+	  <refnamediv>
+		<refname>RemoveUnusedPrimitives</refname>
+		<refpurpose>Removes topology primitives which not needed to define existing TopoGeometry objects.</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>int <function>RemoveUnusedPrimitives</function></funcdef>
+			<paramdef><type>text</type> <parameter>topology_name</parameter></paramdef>
+			<paramdef><type>geometry</type> <parameter>bbox</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>
+Finds all primitives (nodes, edges, faces) that are not
+strictly needed to represent existing TopoGeometry objects and removes
+them, maintaining topology validity (edge linking, face labeling)
+and TopoGeometry space occupation.
+        </para>
+        <para>
+No new primitive identifiers are created, but rather existing primitives
+are expanded to include merged faces (upon removing edges) or healed edges
+(upon removing nodes).
+        </para>
+		<para>Availability: 3.3.0</para>
+	  </refsection>
+		  <refsection>
+			<title>See Also</title>
+			<para>
+<xref linkend="ST_ModEdgeHeal" />,
+<xref linkend="ST_RemEdgeModFace" />
+            </para>
+		  </refsection>
+	</refentry>
 	</sect1>
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 041855dcb..9b53bf98f 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -115,6 +115,7 @@ topology_upgrade.sql: topology_before_upgrade.sql topology_upgrade.sql.in topolo
 	cat $^ > $@
 topology.sql: \
+	sql/cleanup/RemoveUnusedPrimitives.sql.in \
 	sql/sqlmm.sql.in \
 	sql/populate.sql.in \
 	sql/polygonize.sql.in \
diff --git a/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in b/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in
new file mode 100644
index 000000000..fba82fbdc
--- /dev/null
+++ b/topology/sql/cleanup/RemoveUnusedPrimitives.sql.in
@@ -0,0 +1,674 @@
+-- This function finds primitives intersecting a bounding box
+-- that are not used in the definition of TopoGeometry objects
+-- and remove them all.
+-- Returns number of deleted primitives
+CREATE OR REPLACE FUNCTION topology.RemoveUnusedPrimitives(
+  atopology text,
+  bbox GEOMETRY DEFAULT NULL
+RETURNS INT AS
+$BODY$
+DECLARE
+  topo topology.topology;
+  deletedNodes INT := 0;
+  deletedEdges INT := 0;
+  deletedNodesDeg2 INT := 0;
+  sql TEXT;
+  rec RECORD;
+  edgeMap JSONB := '{}';
+  edge1 INT;
+  edge2 INT;
+  removedNode INT;
+  ok BOOLEAN;
+  fixedLinks INT := 0;
+  mergedFaces INT[];
+  moreMergedFaces INT[];
+BEGIN
+  topo := findTopology(atopology);
+  IF topo.id IS NULL THEN
+    RAISE EXCEPTION 'Could not find topology "%"', atopology;
+  END IF;
+  RAISE NOTICE 'Removing unused edges';
+  RAISE DEBUG 'Determining edges not referenced by linear TopoGeoms';
+  -- Delete edges not used in non-hierarchical TopoGeometry
+  -- from linear typed layers
+  sql := format(
+      CREATE TEMPORARY TABLE deleted_edges AS
+      SELECT
+        edge_id,
+        next_right_edge,
+        next_left_edge,
+        left_face,
+        right_face,
+        start_node,
+        end_node
+      FROM %1$I.edge_data e
+      WHERE ( $1 IS NULL OR ST_Intersects(geom, $1) )
+      AND NOT EXISTS (
+        SELECT 1
+        FROM %1$I.relation r, topology.layer l
+        WHERE r.layer_id = l.layer_id
+        AND l.topology_id = $2
+        AND l.child_id IS NULL
+        AND l.feature_type IN (2, 4)
+        AND r.element_id in ( e.edge_id, -e.edge_id )
+    topo.name
+  --RAISE DEBUG 'SQL: %', sql;
+  EXECUTE sql USING bbox, topo.id;
+  GET DIAGNOSTICS fixedLinks = ROW_COUNT;
+  RAISE DEBUG 'Found % edges not referenced by linear TopoGeoms', fixedLinks;
+  -- remove from deleted_edges the edges binding
+  -- faces that individually (not both) take part
+  -- of the definition of an areal TopoGeometry
+  RAISE DEBUG 'Determining edges not binding areal TopoGeoms';
+  sql := format(
+      WITH breaking_merges AS (
+        SELECT
+          DISTINCT
+          de.edge_id
+          --, ARRAY[r.layer_id, r.topogeo_id] topogeo
+          --, array_agg(r.element_id) faces
+        FROM
+          topology.layer l,
+          %1$I.relation r,
+          pg_temp.deleted_edges de
+        WHERE l.topology_id = %2$L
+        AND l.child_id IS NULL -- non-hierarchical layer
+        AND l.feature_type IN (3, 4) -- areal or mixed layer
+        AND r.layer_id = l.layer_id
+        AND r.element_type = 3 -- face primitive
+        AND de.left_face != de.right_face -- non-dangling edges
+        AND ( r.element_id = de.left_face OR r.element_id = de.right_face )
+        GROUP BY de.edge_id, r.layer_id, r.topogeo_id
+        HAVING count(DISTINCT r.element_id) != 2
+      --SELECT * FROM breaking_merges
+      DELETE FROM pg_temp.deleted_edges de
+      WHERE edge_id IN (
+        SELECT edge_id FROM breaking_merges
+    topo.name,
+    topo.id
+  EXECUTE sql;
+  RAISE DEBUG 'Retained % edges binding areal TopoGeoms', fixedLinks;
+  --FOR rec IN EXECUTE sql LOOP
+    --RAISE NOTICE 'Should retain edges % binding areal TopoGeom % in layer %', rec.edge_id, rec.topogeo_id, rec.layer_id;
+  --END LOOP;
+  RAISE DEBUG 'Deleting unused edges';
+  sql := format(
+      DELETE FROM %1$I.edge_data e
+      WHERE e.edge_id IN (
+        SELECT edge_id FROM pg_temp.deleted_edges
+    topo.name
+  EXECUTE sql;
+  GET DIAGNOSTICS deletedEdges = ROW_COUNT;
+  RAISE DEBUG 'Deleted % unused edges', deletedEdges;
+  RAISE DEBUG 'Fixing broken next_right_edge links';
+  sql := format(
+      UPDATE %1$I.edge_data e
+      SET
+        next_right_edge =
+          CASE
+          WHEN e.next_right_edge = ne.edge_id THEN
+            ne.next_right_edge
+          ELSE
+            ne.next_left_edge
+          END,
+        abs_next_right_edge =
+          CASE
+            abs(ne.next_right_edge)
+          ELSE
+            abs(ne.next_left_edge)
+          END
+      FROM pg_temp.deleted_edges ne
+      WHERE e.abs_next_right_edge = ne.edge_id
+        AND e.next_right_edge !=
+        CASE
+        ELSE
+          ne.next_left_edge
+        END
+      RETURNING e.*
+    topo.name
+  LOOP
+    EXECUTE sql;
+--    fixedLinks := 0;
+--    FOR rec IN EXECUTE sql LOOP
+--      fixedLinks := fixedLinks + 1;
+--      RAISE DEBUG 'Updated next_right_edge link for edge %, now having next_right_edge=% and abs_next_right_edge=%', rec.edge_id, rec.next_right_edge, rec.abs_next_right_edge;
+--    END LOOP;
+    IF fixedLinks = 0 THEN
+      RAISE DEBUG 'No (more) broken next_right_edge links';
+      EXIT;
+    END IF;
+    RAISE DEBUG 'Updated % broken next_right_edge links', fixedLinks;
+  END LOOP;
+  RAISE DEBUG 'Fixing broken next_left_edge links';
+  sql := format(
+      SET
+        next_left_edge =
+          CASE
+          WHEN e.next_left_edge = ne.edge_id THEN
+          ELSE
+            ne.next_left_edge
+          END,
+        abs_next_left_edge =
+          CASE
+          ELSE
+          END
+      WHERE e.abs_next_left_edge = ne.edge_id
+        -- Avoid updating records which do not need
+        -- to be updated (alternatively we could DELETE
+        -- those records from deleted_edges before next iteration)
+        AND e.next_left_edge !=
+        CASE
+        ELSE
+          ne.next_left_edge
+        END
+      RETURNING e.*
+    topo.name
+  LOOP
+    EXECUTE sql;
+--      RAISE DEBUG 'Updated next_left_edge link for edge %, now having next_left_edge=% and abs_next_left_edge=%', rec.edge_id, rec.next_left_edge, rec.abs_next_left_edge;
+--    END LOOP;
+      RAISE DEBUG 'No (more) broken next_left_edge links found';
+      EXIT;
+    END IF;
+    RAISE DEBUG 'Updated % broken next_left_edge links', fixedLinks;
+  END LOOP;
+  -- Build arrays of faces to be merged
+  RAISE DEBUG 'Building face merge sets';
+  CREATE TEMPORARY TABLE mergeable_faces AS
+  WITH merges AS (
+    SELECT
+      DISTINCT
+      ARRAY[
+        LEAST(left_face, right_face),
+        GREATEST(left_face, right_face)
+      ] faceset
+    FROM deleted_edges
+    WHERE left_face != right_face
+  SELECT faceset
+  FROM merges;
+  CREATE TEMPORARY TABLE merged_faces (keep INT, merge INT[]);
+  LOOP -- {
+    -- Fetch next merge
+    DELETE FROM mergeable_faces
+    WHERE ctid = (SELECT ctid FROM mergeable_faces LIMIT 1)
+    RETURNING faceset
+    INTO mergedFaces;
+    IF mergedFaces IS NULL THEN
+      EXIT;
+    END IF;
+    RAISE DEBUG 'Next merged faces start with: %', mergedFaces;
+    LOOP --{
+      WITH deleted AS (
+        WHERE faceset && mergedFaces
+        RETURNING faceset
+      ), flood_faces AS (
+        SELECT DISTINCT unnest(faceset) merged
+        FROM deleted
+      SELECT array_agg(merged)
+      FROM flood_faces
+      INTO moreMergedFaces;
+      IF moreMergedFaces IS NULL THEN
+        EXIT;
+      END IF;
+      RAISE DEBUG 'There is more merged faces: %', moreMergedFaces;
+      SELECT array_agg(x) FROM (
+        SELECT unnest(mergedFaces) x
+          UNION
+        SELECT unnest(moreMergedFaces)
+      ) foo
+      INTO mergedFaces;
+      RAISE DEBUG 'Merged faces grows to: %', mergedFaces;
+    END LOOP; --}
+    mergedFaces := array_agg(distinct x ORDER BY x) FROM unnest(mergedFaces) x;
+    RAISE DEBUG 'Storing merged faceset: %', mergedFaces;
+    INSERT INTO pg_temp.merged_faces VALUES (
+      mergedFaces[1],
+      array_remove(mergedFaces, mergedFaces[1])
+  END LOOP; --}
+  DROP TABLE pg_temp.mergeable_faces;
+  -- Fix face labels
+  RAISE DEBUG 'Fixing broken left_face labels';
+  sql := format(
+      SET left_face = mf.keep
+      FROM pg_temp.merged_faces mf
+      WHERE e.left_face != mf.keep
+        AND e.left_face = ANY(mf.merge)
+    topo.name
+  EXECUTE sql;
+  RAISE DEBUG 'Updated % broken left_face links', fixedLinks;
+  RAISE DEBUG 'Fixing broken right_face labels';
+  sql := format(
+      SET right_face = mf.keep
+      WHERE e.right_face != mf.keep
+        AND e.right_face = ANY(mf.merge)
+    topo.name
+  EXECUTE sql;
+  RAISE DEBUG 'Updated % broken right_face links', fixedLinks;
+  RAISE DEBUG 'Updating containing_face labels for merged faces';
+  sql := format(
+      UPDATE %1$I.node n
+      SET containing_face = mf.keep
+      WHERE n.containing_face != mf.keep
+      AND n.containing_face = ANY(mf.merge)
+    topo.name
+  EXECUTE sql;
+  RAISE DEBUG 'Updated % containing_face labels for nodes', fixedLinks;
+  -- Fix face table (delete/update mbr)
+  RAISE DEBUG 'Updating merged faces MBR';
+  sql := format(
+      WITH merged_mbr AS (
+        SELECT
+          mf.keep,
+          ST_Envelope(
+            ST_Collect(
+              f.mbr
+          ) mbr
+        JOIN %1$I.face f ON (
+          f.face_id = mf.keep OR
+          f.face_id = ANY( mf.merge )
+        WHERE mf.keep != 0
+        GROUP by mf.keep
+      UPDATE %1$I.face f
+      SET mbr = m.mbr
+      FROM merged_mbr m
+      WHERE f.face_id = m.keep
+    topo.name
+  EXECUTE sql;
+  RAISE DEBUG 'Updated % merged faces MBR', fixedLinks;
+  RAISE DEBUG 'Deleting removed faces';
+  sql := format(
+      DELETE FROM %1$I.face
+      USING pg_temp.merged_faces mf
+      WHERE face_id = ANY (mf.merge)
+    topo.name
+  EXECUTE sql;
+  RAISE DEBUG 'Deleted % merged faces', fixedLinks;
+  -- Fix TopoGeometry
+  RAISE DEBUG 'Updating areal TopoGeometry definitions';
+  -- We remove the merged faces from the definition
+  -- of areal TopoGeometry objects
+  sql := format(
+      WITH deleted AS (
+        DELETE FROM %1$I.relation r
+        USING topology.layer l, pg_temp.merged_faces mf
+        AND r.element_id = ANY (mf.merge)
+        RETURNING
+          r.topogeo_id,
+          r.layer_id,
+          l.schema_name,
+          l.table_name,
+          l.feature_column,
+          mf.merge,
+          mf.keep,
+          r.element_id
+      SELECT
+        topogeo_id,
+        layer_id,
+        schema_name,
+        table_name,
+        feature_column,
+        merge,
+        keep,
+        array_agg(element_id) lost_faces
+      FROM deleted
+      GROUP BY 1,2,3,4,5,6,7
+    topo.name,
+    topo.id
+  --RAISE NOTICE 'SQL: %', sql;
+  FOR rec IN EXECUTE sql
+  LOOP
+    RAISE DEBUG 'Areal TopoGeometry % in layer %.%.% '
+      'lost faces % (kept %) in its composition',
+      rec.topogeo_id, rec.schema_name,
+      rec.table_name, rec.feature_column,
+      rec.lost_faces, rec.keep
+  END LOOP;
+  -- Mark newly isolated nodes as such
+  RAISE DEBUG 'Determining newly isolated nodes';
+  sql := format(
+      WITH unlinked_nodes AS (
+        SELECT start_node node_id FROM pg_temp.deleted_edges
+          UNION
+        SELECT end_node FROM pg_temp.deleted_edges
+      ), isolated AS (
+        SELECT node_id FROM unlinked_nodes
+        EXCEPT SELECT start_node FROM %1$I.edge_data
+        EXCEPT  SELECT end_node FROM %1$I.edge_data
+      ), incident_faces AS (
+        SELECT
+          node_id,
+          array_agg(DISTINCT face_id) incident_faces
+        FROM (
+          SELECT DISTINCT node_id, unnest(face_id) face_id
+          FROM (
+            SELECT
+              i.node_id,
+              ARRAY[e.left_face, e.right_face] face_id
+            FROM isolated i, deleted_edges e
+            WHERE e.start_node = i.node_id
+              UNION
+            SELECT
+              i.node_id,
+            WHERE e.end_node = i.node_id
+          ) foo
+        ) bar
+        GROUP BY node_id
+      ), containing_faces AS (
+        SELECT
+          inc.node_id,
+          COALESCE(mf.keep, incident_faces[1]) face_id
+        FROM incident_faces inc
+        LEFT JOIN pg_temp.merged_faces mf
+          ON ( inc.incident_faces && mf.merge )
+      SET containing_face = cf.face_id
+      FROM containing_faces cf
+      WHERE n.node_id = cf.node_id
+      AND n.containing_face IS DISTINCT FROM cf.face_id
+    topo.name
+  EXECUTE sql;
+  RAISE DEBUG 'Isolated % nodes', fixedLinks;
+  RAISE NOTICE 'Removed % unused edges', deletedEdges;
+  -- Clean isolated nodes
+  -- Cleanup isolated nodes
+  -- (non-isolated ones would have become isolated by now)
+  sql := format(
+      SELECT
+        n.node_id
+      FROM
+        %1$I.node n
+      WHERE ( $1 IS NULL OR ST_Intersects(n.geom, $1) )
+      AND n.containing_face IS NOT NULL
+      AND NOT EXISTS (
+        SELECT 1
+        AND l.feature_type = 1
+        AND r.element_id = n.node_id
+    topo.name
+  RAISE NOTICE 'Removing isolated nodes';
+  FOR rec in EXECUTE sql USING bbox, topo.id
+  LOOP --{
+    BEGIN
+      PERFORM topology.ST_RemIsoNode(topo.name, rec.node_id);
+      RAISE DEBUG 'Removed isolated node %', rec.node_id;
+      deletedNodes := deletedNodes + 1;
+    EXCEPTION WHEN OTHERS
+    THEN
+      RAISE WARNING 'Isolated node % could not be removed: %', rec.node_id, SQLERRM;
+    END;
+  END LOOP; --}
+  RAISE NOTICE 'Removed % isolated nodes', deletedNodes;
+  -- Remove nodes connecting only 2 edges if
+  -- no lineal TopoGeometry exists that is defined
+  -- by only one of them
+  sql := format(
+      WITH
+      unused_connected_nodes_in_bbox AS (
+        SELECT
+          n.node_id
+        FROM %1$I.node n
+        WHERE
+          ( $1 IS NULL OR ST_Intersects(n.geom, $1) )
+          AND n.containing_face IS NULL
+          EXCEPT
+        SELECT r.element_id
+        JOIN topology.layer l ON ( r.layer_id = l.layer_id )
+        WHERE l.child_id IS NULL
+        AND l.feature_type IN ( 1, 4 ) -- puntual or mixed layer
+        AND r.element_type = 1 -- node primitive
+      removable_nodes_of_degree_2_in_bbox AS (
+        SELECT
+          n.node_id,
+          array_agg(e.edge_id) edges
+        FROM
+          unused_connected_nodes_in_bbox n,
+          %1$I.edge e
+        WHERE (
+            n.node_id = e.start_node
+            OR n.node_id = e.end_node
+        GROUP BY n.node_id
+        HAVING count(e.edge_id) = 2
+      breaking_heals AS (
+        SELECT
+          DISTINCT
+          n.node_id
+          -- , ARRAY[r.layer_id, r.topogeo_id]
+          -- , array_agg(r.element_id) edges
+        FROM
+          removable_nodes_of_degree_2_in_bbox n,
+          %1$I.relation r,
+          topology.layer l
+        WHERE l.topology_id = $2
+          AND l.feature_type IN ( 2, 4 ) -- lineal or mixed layer
+          AND r.element_type = 2 -- edge primitive
+          AND r.element_id IN (
+            n.edges[1], -n.edges[1],
+            n.edges[2], -n.edges[2]
+          GROUP BY n.node_id, r.layer_id, r.topogeo_id
+          HAVING count(DISTINCT abs(r.element_id)) != 2
+      SELECT
+        node_id,
+        edges[1] edge1,
+        edges[2] edge2
+      FROM removable_nodes_of_degree_2_in_bbox
+      WHERE node_id NOT IN (
+        SELECT node_id FROM breaking_heals
+    topo.name
+  RAISE NOTICE 'Removing unneeded nodes of degree 2';
+  LOOP --{
+    RAISE DEBUG 'edgeMap: %', edgeMap;
+    -- Edges may have changed name
+    edge1 := COALESCE( (edgeMap -> rec.edge1::text)::int, rec.edge1);
+    edge2 := COALESCE( (edgeMap -> rec.edge2::text)::int, rec.edge2);
+    RAISE DEBUG 'Should heal edges % (now %) and % (now %) bound by node %',
+      rec.edge1, edge1, rec.edge2, edge2, rec.node_id;
+    IF edge1 = edge2 THEN
+      -- Nothing to merge here, continue
+      CONTINUE;
+    END IF;
+    ok := false;
+    BEGIN
+      -- TODO: replace ST_ModEdgeHeal loop with a faster direct deletion and healing
+      removedNode := topology.ST_ModEdgeHeal(topo.name, edge1, edge2);
+      IF rec.node_id != removedNode THEN
+        RAISE EXCEPTION 'Healing of edges % and % was reported '
+                        'to remove node % while we expected % instead',
+                        edge1, edge2, removedNode, rec.node_id;
+      END IF;
+      RAISE DEBUG 'Edge % merged into %, dropping node %', edge2, edge1, removedNode;
+      ok := 1;
+    THEN
+      RAISE WARNING 'Edges % and % joined by node % could not be healed: %', edge1, edge2, rec.node_id, SQLERRM;
+    END;
+    IF ok THEN
+      -- edge2 was now renamed to edge1, update map
+      edgeMap := jsonb_set(edgeMap, ARRAY[edge2::text], to_jsonb(edge1));
+      deletedNodesDeg2 := deletedNodesDeg2 + 1;
+    END IF;
+  END LOOP; --}
+  RAISE NOTICE 'Removed % unneeded nodes of degree 2', deletedNodesDeg2;
+  DROP TABLE pg_temp.deleted_edges;
+  DROP TABLE pg_temp.merged_faces;
+  RETURN deletedEdges + deletedNodes + deletedNodesDeg2;
+END;
+$BODY$ LANGUAGE 'plpgsql' VOLATILE;
diff --git a/topology/test/regress/removeunusedprimitives.sql b/topology/test/regress/removeunusedprimitives.sql
index 000000000..cd966cd4d
--- /dev/null
+++ b/topology/test/regress/removeunusedprimitives.sql
@@ -0,0 +1,210 @@
+set client_min_messages to WARNING;
+\i :top_builddir/topology/test/load_topology.sql
+\i ../load_features.sql
+ALTER TABLE features.land_parcels ADD geom geometry;
+UPDATE features.land_parcels SET geom = feature::geometry;
+ALTER TABLE features.city_streets ADD geom geometry;
+UPDATE features.city_streets SET geom = feature::geometry;
+ALTER TABLE features.traffic_signs ADD geom geometry;
+UPDATE features.traffic_signs SET geom = feature::geometry;
+CREATE FUNCTION features.check_changed_features()
+RETURNS TABLE(typ text, nam text, exp text, obt text, symdiff text) AS
+  SELECT 'areal', feature_name,
+    ST_AsText(geom),
+    ST_AsText(feature::geometry),
+    ST_AsText(ST_SymDifference(feature::geometry, geom))
+    FROM features.land_parcels
+    WHERE NOT ST_Equals(feature::geometry, geom)
+  UNION ALL
+  SELECT 'lineal', feature_name,
+    ST_AsText(geom),
+    FROM features.city_streets
+  UNION ALL
+  SELECT 'puntual', feature_name,
+    ST_AsText(geom),
+    FROM features.traffic_signs
+    WHERE NOT ST_Equals(feature::geometry, geom);
+$$ LANGUAGE 'sql';
+-- Error calls
+SELECT 'e1', topology.RemoveUnusedPrimitives('non-existent'::text);
+SELECT 'e2', topology.RemoveUnusedPrimitives(NULL::text);
+-- Valid calls
+-- T0 -- bbox limited
+--set client_min_messages to DEBUG;
+SELECT 't0', 'clean', topology.RemoveUnusedPrimitives('city_data',
+  ST_MakeEnvelope(8,5,10,23)
+SELECT 't0', 'changed', * FROM features.check_changed_features();
+SELECT 't0', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- T1
+SELECT 't1', 'clean', topology.RemoveUnusedPrimitives('city_data');
+SELECT 't1', 'changed', * FROM features.check_changed_features();
+SELECT 't1', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- T2
+WITH deleted AS (
+  DELETE FROM features.city_streets WHERE feature_name IN ( 'R1' )
+  RETURNING feature
+), clear AS (
+  SELECT clearTopoGeom(feature) FROM deleted
+) SELECT NULL FROM clear;
+SELECT 't2', 'clean', topology.RemoveUnusedPrimitives('city_data');
+SELECT 't2', 'changed', * FROM features.check_changed_features();
+SELECT 't2', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- T3
+WITH deleted AS (
+  DELETE FROM features.traffic_signs WHERE feature_name IN ( 'S3' )
+  RETURNING feature
+), clear AS (
+SELECT 't3', 'clean', topology.RemoveUnusedPrimitives('city_data');
+SELECT 't3', 'changed', * FROM features.check_changed_features();
+SELECT 't3', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- T4 -- test removal of isolated node
+WITH deleted AS (
+  DELETE FROM features.traffic_signs WHERE feature_name IN ( 'S4' )
+  RETURNING feature
+), clear AS (
+SELECT 't4', 'clean', topology.RemoveUnusedPrimitives('city_data');
+SELECT 't4', 'changed', * FROM features.check_changed_features();
+SELECT 't4', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- T5 -- test removal of isolated edge leaving a used and an unused endpoint
+-- Drop lineal feature R3 turning isolated edge (25) unused
+-- Add a puntual feature TS1 using one (21) of the two unlinked
+-- nodes (21 and 22)
+WITH deleted AS (
+  DELETE FROM features.city_streets WHERE feature_name IN ( 'R3' )
+  RETURNING feature
+start_point AS (
+  SELECT ST_StartPoint(feature::geometry) sp, feature
+  FROM deleted
+clear AS (
+  SELECT sp, clearTopoGeom(feature)
+  FROM start_point
+INSERT INTO features.traffic_signs ( feature_name, feature )
+SELECT
+  'TS1',
+  toTopoGeom(
+    sp,
+    'city_data',
+    layer_id(findLayer('features', 'traffic_signs', 'feature')),
+    0
+FROM clear;
+WHERE feature_name = 'TS1';
+SELECT 't5', 'clean', topology.RemoveUnusedPrimitives('city_data');
+SELECT 't5', 'changed', * FROM features.check_changed_features();
+SELECT 't5', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- T6 -- test removal in presence of node incident to 2 closed edges
+--       and 2 non-closed edges
+-- Add closed edge starting and ending on the node used by S1
+CREATE FUNCTION features.triangle(point geometry, offx float8, offy float8)
+RETURNS geometry AS $xx$
+  WITH point AS (
+    SELECT ST_X($1) x, ST_Y($1) y
+  SELECT ST_MakeLine(p order by id) l FROM (
+    SELECT
+       s,
+       ST_MakePoint(
+        x + CASE WHEN s > 1 AND s < 4 THEN $2 ELSE 0 END,
+        y + CASE WHEN s > 2 AND s < 4 THEN $3 ELSE 0 END
+    FROM
+      point,
+      generate_series(1,4) s
+  ) foo(id,p)
+$xx$ LANGUAGE 'sql';
+WITH node AS (
+  SELECT ST_GeometryN(feature::geometry, 1) g
+  FROM features.traffic_signs WHERE feature_name = 'S1'
+triangle_right AS (
+  SELECT TopoGeo_addLineString( 'city_data',
+    features.triangle(g, 4, 4)
+  ) FROM node
+triangle_left AS (
+    features.triangle(g, -4, 4)
+  ) FROM node
+SELECT NULL FROM triangle_right UNION
+SELECT NULL FROM triangle_left;
+-- Drop puntual feature S1 turning node 14 unused
+WITH deleted AS (
+  WHERE feature_name = 'S1'
+  RETURNING feature
+clear AS (
+  FROM deleted
+SELECT NULL FROM clear;
+SELECT 't6', 'clean', topology.RemoveUnusedPrimitives('city_data');
+SELECT 't6', 'changed', * FROM features.check_changed_features();
+SELECT 't6', 'invalidity', * FROM topology.ValidateTopology('city_data');
+-- Cleanup
+SELECT NULL FROM DropTopology('city_data');
+DROP SCHEMA features CASCADE;
diff --git a/topology/test/regress/removeunusedprimitives_expected b/topology/test/regress/removeunusedprimitives_expected
index 000000000..afcbe4895
--- /dev/null
+++ b/topology/test/regress/removeunusedprimitives_expected
@@ -0,0 +1,9 @@
+ERROR:  Could not find topology "non-existent"
+ERROR:  Could not find topology "<NULL>"
+t0|clean|2
+t1|clean|4
+t2|clean|3
+t3|clean|1
+t4|clean|1
+t5|clean|2
+t6|clean|3
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 2fbb08541..af09adccd 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -46,6 +46,7 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/legacy_query.sql \
 	$(top_srcdir)/topology/test/regress/legacy_validate.sql \
 	$(top_srcdir)/topology/test/regress/polygonize.sql \
+	$(top_srcdir)/topology/test/regress/removeunusedprimitives.sql \
 	$(top_srcdir)/topology/test/regress/sqlmm.sql \
 	$(top_srcdir)/topology/test/regress/st_addedgemodface.sql \
 	$(top_srcdir)/topology/test/regress/st_addedgenewfaces.sql \
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index a73391687..27ae06595 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1418,6 +1418,9 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 #include "sql/manage/ValidateTopology.sql.in"
 #include "sql/manage/ValidateTopologyRelation.sql.in"
+-- Cleanup functions
+#include "sql/cleanup/RemoveUnusedPrimitives.sql.in"
 CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed() RETURNS text
 	AS _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION
Summary of changes:
 .editorconfig                                      |   4 +
 NEWS                                               |   2 +
 doc/extras_topology.xml                            |  43 ++
 topology/Makefile.in                               |   1 +
 topology/sql/cleanup/RemoveUnusedPrimitives.sql.in | 674 +++++++++++++++++++++
 topology/test/regress/removeunusedprimitives.sql   | 210 +++++++
 .../test/regress/removeunusedprimitives_expected   |   9 +
 topology/test/tests.mk                             |   1 +
 topology/topology.sql.in                           |   3 +
 9 files changed, 947 insertions(+)
 create mode 100644 topology/sql/cleanup/RemoveUnusedPrimitives.sql.in
 create mode 100644 topology/test/regress/removeunusedprimitives.sql
 create mode 100644 topology/test/regress/removeunusedprimitives_expected
hooks/post-receive
