[postgis-tickets] [PostGIS] #5185: topology.sql: ERROR: type topogeometry does not exist
PostGIS trac at osgeo.org
Tue Jul 12 00:31:50 PDT 2022
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.2.2
Component:  topology  |    Version:  3.2.x
 Keywords:            |
 Loading topology.sql script results in this error:
 The error is due to `topology` schema not being in the search_path while
 unqualified references to it are used in the definition of FindTopology
 and FindLayer.
 I've pushed a fix for this in master branch with
 [b1d2c5f3b9ec1dd7648daa1adb89379cf65b35c6/git] but didn't push any test
 for it and I know stable-3.2 branch is also affected and needs be fixed,
 didn't check older versions.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5185>
