[postgis-tickets] [PostGIS] #5187: Upgrade failures on 2.5 to 3.3.0
PostGIS trac at osgeo.org
Wed Jul 13 15:21:23 PDT 2022
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  critical               |  Milestone:  PostGIS 3.3.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 Noticed on master that dronie is failing on upgrades from
 NOTICE:  schema "public" already exists, skipping
 CREATE SCHEMA
 SET
 CREATE TABLE
 INSERT 0 2
 DO
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 CREATE VIEW
 UPDATE 479
 ERROR:  Trying to add OPERATOR CLASS spgist_geometry_ops_nd USING SPGIST
 to postgis, got operator class "spgist_geometry_ops_nd" does not exist for
 access method "spgist" (42704)
 CONTEXT:  PL/pgSQL function inline_code_block line 25 at RAISE
 /drone/src/regress/runtest.mk:22: recipe for target 'check-regress' failed
 make: Leaving directory '/tmp/postgis-build/11/regress'
 FAIL: postgis extension upgrade unpackaged2.5--3.3.0beta2!
 As noted in https://dronie.osgeo.org/postgis/postgis/3240/1/3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5187>
