[postgis-tickets] [PostGIS] #5188: heads-up: PROJ_LIB is now deprecated (use PROJ_DATA instead)
PostGIS trac at osgeo.org
Thu Jul 14 08:10:11 PDT 2022
 Reporter:  jmckenna     |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.2.2
Component:  postgis      |    Version:  3.2.x
 Keywords:               |
 - PROJ_LIB will now be deprecated, and PROJ_DATA should be used instead
 - see PROJ changes at https://github.com/OSGeo/PROJ/pull/3253
 - I believe some builds of PostGIS point to PROJ_LIB
 - likely both PROJ_LIB and PROJ_DATA should be checked, for now (similar
 to how MapServer will handle this, see
 https://github.com/MapServer/MapServer/pull/6573 )
 - the big change will be part of the upcoming PROJ 9.1 release, but it's
 good for all projects to be ready for this
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5188>
