[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.6-5-g7e6980e41
Sun Jul 17 14:32:19 PDT 2022
the project "PostGIS".
The branch, stable-2.5 has been updated
       via  7e6980e41bc978875cbfd884cfb851c7cbd458a2 (commit)
       via  5399ba84ef89e21f176844522081c1a2743eeb1c (commit)
      from  fdd03bcbe1543bf780fdae361c274d782b3320a8 (commit)
revisions in full, below.
commit 7e6980e41bc978875cbfd884cfb851c7cbd458a2
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jul 17 16:53:58 2022 -0400
    References #5150 - Change signature of AddToSearchPath
    References #5155, More schema qual fixes
    for PostGIS 2.5.7
diff --git a/NEWS b/NEWS
index 669d85b89..2beceb682 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 2.5.7dev
   - #5151, ST_SetPoint with empty geometries (Regina Obe)
   - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
+  - #5150, Change signature of AddToSearchPath (Regina Obe)
+  - #5155, More schema qual fixes (Regina Obe)
 PostGIS 2.5.6
 2022/04/20
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index ce961ba69..c0803c95d 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -18,7 +18,7 @@
 -- this is needed because there is no ALTER EXTENSION DROP FUNCTION/AGGREGATE command
 -- and we can't CREATE OR REPALCe functions whose signatures have changed and we can drop them if they are part of an extention
 -- So we use this to remove it from extension first before we drop
-CREATE OR REPLACE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
+CREATE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
   RETURNS boolean AS
 DECLARE
@@ -28,50 +28,50 @@ DECLARE
 	var_class text := '';
 	var_is_aggregate boolean := false;
 	var_sql_list text := '';
-	var_pgsql_version integer := current_setting('server_version_num');
+	var_pgsql_version integer := pg_catalog.current_setting('server_version_num');
 BEGIN
-		var_class := CASE WHEN pg_catalog.lower(param_type) = 'function' OR pg_catalog.lower(param_type) = 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
-		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) = 'aggregate' THEN true ELSE false END;
+		var_class := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'function' OR pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
+		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN true ELSE false END;
-		IF var_pgsql_version < 110000 THEN
-			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) || ')' ,typ.typname, cd.relname, op.oprname,
-					cs.typname || ' AS ' || ct.typname || ') ', opcname, opfname) || ';' AS remove_command
+		IF var_pgsql_version OPERATOR(pg_catalog.<) 110000 THEN
+			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' OPERATOR(pg_catalog.||)  e.extname OPERATOR(pg_catalog.||) ' DROP ' OPERATOR(pg_catalog.||) $3 OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) COALESCE(proc.proname OPERATOR(pg_catalog.||) '(' OPERATOR(pg_catalog.||) oidvectortypes(proc.proargtypes) OPERATOR(pg_catalog.||) ')' ,typ.typname, cd.relname, op.oprname,
+					cs.typname OPERATOR(pg_catalog.||) ' AS ' OPERATOR(pg_catalog.||) ct.typname OPERATOR(pg_catalog.||) ') ', opcname, opfname) OPERATOR(pg_catalog.||) ';' AS remove_command
 			FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
-				ON d.refobjid = e.oid INNER JOIN pg_catalog.pg_class As c ON
-					c.oid = d.classid
-					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid = d.objid
-					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid = d.objid
-					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid = d.objid
-					LEFT JOIN pg_operator As op ON op.oid = d.objid
-					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid = d.objid
-					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource = cs.oid
-					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget = ct.oid
-					LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
-					LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
-			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;$sql$;
+				ON d.refobjid OPERATOR(pg_catalog.=) e.oid INNER JOIN pg_catalog.pg_class As c ON
+					c.oid OPERATOR(pg_catalog.=) d.classid
+					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_operator As op ON op.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource OPERATOR(pg_catalog.=) cs.oid
+					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget OPERATOR(pg_catalog.=) ct.oid
+					LEFT JOIN pg_catalog.pg_opclass As oc ON oc.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_opfamily As ofa ON ofa.oid OPERATOR(pg_catalog.=) d.objid
+			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND COALESCE(proc.proisagg, false) OPERATOR(pg_catalog.=) $4;$sql$;
 		ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
-					c.oid = d.classid
-			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND (proc.prokind = 'a')  = $4;$sql$;
+			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND (proc.prokind OPERATOR(pg_catalog.=) 'a')  OPERATOR(pg_catalog.=) $4;$sql$;
 		END IF;
 		FOR var_r IN EXECUTE var_sql_list  USING param_extension, var_class, param_type, var_is_aggregate
 		LOOP
-			var_sql := var_sql || var_r.remove_command || ';';
+			var_sql := var_sql OPERATOR(pg_catalog.||) var_r.remove_command OPERATOR(pg_catalog.||) ';';
 		END LOOP;
-		IF var_sql > '' THEN
+		IF var_sql OPERATOR(pg_catalog.>) '' THEN
 			EXECUTE var_sql;
 			var_result := true;
 		END IF;
@@ -81,11 +81,11 @@ END;
 LANGUAGE plpgsql VOLATILE;
-CREATE OR REPLACE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
+CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
   RETURNS boolean AS
 DECLARE
-	var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || pg_catalog.replace(param_statement, 'IF EXISTS', '');
+	var_sql_ext text := 'ALTER EXTENSION ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(param_extension) OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) pg_catalog.replace(param_statement, 'IF EXISTS', '');
 	var_result boolean := false;
 BEGIN
 	BEGIN
@@ -101,7 +101,7 @@ END;
-CREATE OR REPLACE FUNCTION postgis_extension_AddToSearchPath(a_schema_name varchar)
+CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
 RETURNS text
 AS
@@ -110,17 +110,17 @@ DECLARE
 	var_cur_search_path text;
 BEGIN
 	SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
-	IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
-		var_result := a_schema_name || ' already in database search_path';
+	IF var_cur_search_path LIKE '%'  OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name)  OPERATOR(pg_catalog.||) '%' THEN
+		var_result := a_schema_name  OPERATOR(pg_catalog.||) ' already in database search_path';
 	ELSE
-		var_cur_search_path := var_cur_search_path || ', '
-                        || pg_catalog.quote_ident(a_schema_name);
-		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
-                              || ' SET search_path = ' || var_cur_search_path;
-		var_result := a_schema_name || ' has been added to end of database search_path ';
+		var_cur_search_path := var_cur_search_path OPERATOR(pg_catalog.||) ', '
+                       OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name);
+		EXECUTE 'ALTER DATABASE ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(pg_catalog.current_database())
+                             OPERATOR(pg_catalog.||) ' SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
+		var_result := a_schema_name OPERATOR(pg_catalog.||) ' has been added to end of database search_path ';
 	END IF;
-	EXECUTE 'SET search_path = ' || var_cur_search_path;
+	EXECUTE 'SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
   RETURN var_result;
 END
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index b08048fd9..2fb1d1756 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -15,4 +15,5 @@
 -- and should be called at the end of the extension upgrade file
 DROP FUNCTION postgis_extension_remove_objects(text, text);
 DROP FUNCTION postgis_extension_drop_if_exists(text, text);
-DROP FUNCTION postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
commit 5399ba84ef89e21f176844522081c1a2743eeb1c
Date:   Sun Jul 17 16:39:06 2022 -0400
    Generate md5 hash
    References #5159 for PostGIS 2.5.7
diff --git a/ci/debbie/postgis_make_dist.sh b/ci/debbie/postgis_make_dist.sh
index f0939e003..5a09e4ec3 100644
--- a/ci/debbie/postgis_make_dist.sh
+++ b/ci/debbie/postgis_make_dist.sh
@@ -29,7 +29,9 @@ export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${PO
 sh make_dist.sh
 export package=${newoutdir}.tar.gz
+md5sum ${package} > ${package}.md5
 echo "The package name is $package"
 cp $package $WEB_DIR
+cp ${package}.md5 $WEB_DIR
 bash ci/debbie/postgis_release_docs.sh
Summary of changes:
 NEWS                                              |  2 +
 ci/debbie/postgis_make_dist.sh                    |  2 +
 extensions/postgis_extension_helper.sql           | 92 +++++++++++------------
 extensions/postgis_extension_helper_uninstall.sql |  3 +-
 4 files changed, 52 insertions(+), 47 deletions(-)
hooks/post-receive
