[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.5-10-gd5d3dfe8f
Sun Jul 17 15:42:47 PDT 2022
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  d5d3dfe8f558485cf63037601a5dc114ca21f4e1 (commit)
       via  05eb430e0b2a9483e1aa850523b2584dcf08baa1 (commit)
       via  e7dae9e51b539d3dc3fa80dece35a1512660e36a (commit)
      from  d8786601e26fc67747dc2acbfe3cdc78c96883fc (commit)
revisions in full, below.
commit d5d3dfe8f558485cf63037601a5dc114ca21f4e1
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Jul 17 18:33:12 2022 -0400
    Search path and schema qual changes.  Closes #5150 Closes #5155 for PostGIS 3.0.6
diff --git a/NEWS b/NEWS
index 8e00d0c0a..1149e19fb 100644
--- a/NEWS
+++ b/NEWS
@@ -1,4 +1,4 @@
-PostGIS 3.0.6dev
+PostGIS 3.0.6
 2022/XX/XX
 * Bug Fixes and Enhancements *
@@ -11,6 +11,8 @@ PostGIS 3.0.6dev
   - #5120, Fix not-null result from ST_EstimatedExtent against
            truncated tables with spatial index (Sandro Santilli)
 	- #5151, garden crash ST_SetPoint with empty geometries (Regina Obe)
+  - #5150, Change signature of AddToSearchPath (Regina Obe)
+  - #5155, More schema qual fixes (Regina Obe)
 PostGIS 3.0.5
 2022/02/02
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index 60af72748..3f90683e8 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -28,50 +28,50 @@ DECLARE
 	var_class text := '';
 	var_is_aggregate boolean := false;
 	var_sql_list text := '';
-	var_pgsql_version integer := current_setting('server_version_num');
+	var_pgsql_version integer := pg_catalog.current_setting('server_version_num');
 BEGIN
-		var_class := CASE WHEN pg_catalog.lower(param_type) = 'function' OR pg_catalog.lower(param_type) = 'aggregate' THEN 'pg_proc' ELSE '' END;
-		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) = 'aggregate' THEN true ELSE false END;
+		var_class := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'function' OR pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
+		var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN true ELSE false END;
-		IF var_pgsql_version < 110000 THEN
-			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) || ')' ,typ.typname, cd.relname, op.oprname,
-					cs.typname || ' AS ' || ct.typname || ') ', opcname, opfname) || ';' AS remove_command
+		IF var_pgsql_version OPERATOR(pg_catalog.<) 110000 THEN
+			var_sql_list := $sql$SELECT 'ALTER EXTENSION ' OPERATOR(pg_catalog.||)  e.extname OPERATOR(pg_catalog.||) ' DROP ' OPERATOR(pg_catalog.||) $3 OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) COALESCE(proc.proname OPERATOR(pg_catalog.||) '(' OPERATOR(pg_catalog.||) oidvectortypes(proc.proargtypes) OPERATOR(pg_catalog.||) ')' ,typ.typname, cd.relname, op.oprname,
+					cs.typname OPERATOR(pg_catalog.||) ' AS ' OPERATOR(pg_catalog.||) ct.typname OPERATOR(pg_catalog.||) ') ', opcname, opfname) OPERATOR(pg_catalog.||) ';' AS remove_command
 			FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
-				ON d.refobjid = e.oid INNER JOIN pg_catalog.pg_class As c ON
-					c.oid = d.classid
-					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid = d.objid
-					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid = d.objid
-					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid = d.objid
-					LEFT JOIN pg_operator As op ON op.oid = d.objid
-					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid = d.objid
-					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource = cs.oid
-					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget = ct.oid
-					LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
-					LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
-			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;$sql$;
+				ON d.refobjid OPERATOR(pg_catalog.=) e.oid INNER JOIN pg_catalog.pg_class As c ON
+					c.oid OPERATOR(pg_catalog.=) d.classid
+					LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_class As cd ON cd.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_operator As op ON op.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource OPERATOR(pg_catalog.=) cs.oid
+					LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget OPERATOR(pg_catalog.=) ct.oid
+					LEFT JOIN pg_catalog.pg_opclass As oc ON oc.oid OPERATOR(pg_catalog.=) d.objid
+					LEFT JOIN pg_catalog.pg_opfamily As ofa ON ofa.oid OPERATOR(pg_catalog.=) d.objid
+			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND COALESCE(proc.proisagg, false) OPERATOR(pg_catalog.=) $4;$sql$;
 		ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
-					c.oid = d.classid
-			WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND (proc.prokind = 'a')  = $4;$sql$;
+			WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND (proc.prokind OPERATOR(pg_catalog.=) 'a')  OPERATOR(pg_catalog.=) $4;$sql$;
 		END IF;
 		FOR var_r IN EXECUTE var_sql_list  USING param_extension, var_class, param_type, var_is_aggregate
 		LOOP
-			var_sql := var_sql || var_r.remove_command || ';';
+			var_sql := var_sql OPERATOR(pg_catalog.||) var_r.remove_command OPERATOR(pg_catalog.||) ';';
 		END LOOP;
-		IF var_sql > '' THEN
+		IF var_sql OPERATOR(pg_catalog.>) '' THEN
 			EXECUTE var_sql;
 			var_result := true;
 		END IF;
@@ -81,11 +81,11 @@ END;
 LANGUAGE plpgsql VOLATILE;
-CREATE OR REPLACE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
+CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
   RETURNS boolean AS
 DECLARE
-	var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || pg_catalog.replace(param_statement, 'IF EXISTS', '');
+	var_sql_ext text := 'ALTER EXTENSION ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(param_extension) OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) pg_catalog.replace(param_statement, 'IF EXISTS', '');
 	var_result boolean := false;
 BEGIN
 	BEGIN
@@ -101,7 +101,7 @@ END;
-CREATE OR REPLACE FUNCTION postgis_extension_AddToSearchPath(a_schema_name varchar)
+CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
 RETURNS text
 AS
@@ -110,17 +110,17 @@ DECLARE
 	var_cur_search_path text;
 BEGIN
 	SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
-	IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
-		var_result := a_schema_name || ' already in database search_path';
+	IF var_cur_search_path LIKE '%'  OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name)  OPERATOR(pg_catalog.||) '%' THEN
+		var_result := a_schema_name  OPERATOR(pg_catalog.||) ' already in database search_path';
 	ELSE
-		var_cur_search_path := var_cur_search_path || ', '
-                        || pg_catalog.quote_ident(a_schema_name);
-		EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
-                              || ' SET search_path = ' || var_cur_search_path;
-		var_result := a_schema_name || ' has been added to end of database search_path ';
+		var_cur_search_path := var_cur_search_path OPERATOR(pg_catalog.||) ', '
+                       OPERATOR(pg_catalog.||) pg_catalog.quote_ident(a_schema_name);
+		EXECUTE 'ALTER DATABASE ' OPERATOR(pg_catalog.||) pg_catalog.quote_ident(pg_catalog.current_database())
+                             OPERATOR(pg_catalog.||) ' SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
+		var_result := a_schema_name OPERATOR(pg_catalog.||) ' has been added to end of database search_path ';
 	END IF;
-	EXECUTE 'SET search_path = ' || var_cur_search_path;
+	EXECUTE 'SET search_path = ' OPERATOR(pg_catalog.||) var_cur_search_path;
   RETURN var_result;
 END
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index b08048fd9..2fb1d1756 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -15,4 +15,5 @@
 -- and should be called at the end of the extension upgrade file
 DROP FUNCTION postgis_extension_remove_objects(text, text);
 DROP FUNCTION postgis_extension_drop_if_exists(text, text);
-DROP FUNCTION postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
+DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
commit 05eb430e0b2a9483e1aa850523b2584dcf08baa1
Date:   Sun Jul 17 18:22:39 2022 -0400
    Generate md5 hash.  References #5159 for PostGIS 3.0.6
diff --git a/ci/debbie/postgis_make_dist.sh b/ci/debbie/postgis_make_dist.sh
index 0344b11f0..4e76253cf 100644
--- a/ci/debbie/postgis_make_dist.sh
+++ b/ci/debbie/postgis_make_dist.sh
@@ -31,7 +31,9 @@ export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${PO
 sh make_dist.sh
 export package=${newoutdir}.tar.gz
+md5sum ${package} > ${package}.md5
 echo "The package name is $package"
 cp $package $WEB_DIR
+cp ${package}.md5 $WEB_DIR
 bash ci/debbie/postgis_release_docs.sh
commit e7dae9e51b539d3dc3fa80dece35a1512660e36a
Date:   Sun Jul 17 18:20:36 2022 -0400
    crash on ST_SetPoint with empty geoms. Closes #5151 for PostGIS 3.0.6
index 30cf30a3f..8e00d0c0a 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,7 @@ PostGIS 3.0.6dev
   - #5115, Allow dropping topologies with pending constraints (Sandro Santilli)
+	- #5151, garden crash ST_SetPoint with empty geometries (Regina Obe)
 PostGIS 3.0.5
 2022/02/02
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index f76fb3ea5..83ec8aa0b 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2325,6 +2325,10 @@ Datum LWGEOM_setpoint_linestring(PG_FUNCTION_ARGS)
 		elog(ERROR, "First argument must be a LINESTRING");
 		PG_RETURN_NULL();
+	if ( line->points->npoints < 1 ) 	{
+		elog(ERROR, "Line has no points");
+		PG_RETURN_NULL();
 	if (which < 0)
 		/* Use backward indexing for negative values */
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index ef2ffb8c8..cfc731e05 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1385,3 +1385,6 @@ WITH w AS (
 SELECT '#4770.c', ST_AsText(g), s FROM w;
+-- https://trac.osgeo.org/postgis/ticket/5151
+SELECT '#5151', ST_SetPoint(ST_GeomFromText('LINESTRING EMPTY',4326), 1, ST_GeomFromText('POINT(40 50)',4326)) As result;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index fe50d4d5f..7c6e6b5d5 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -454,3 +454,4 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4770.b|POINT(1 1)|302
 #4770.c|POINT(0 0)|300
 #4770.c|MULTIPOINT(0 0,1 1)|602
+ERROR:  Line has no points
Summary of changes:
 NEWS                                              |  5 +-
 ci/debbie/postgis_make_dist.sh                    |  2 +
 extensions/postgis_extension_helper.sql           | 90 +++++++++++------------
 extensions/postgis_extension_helper_uninstall.sql |  3 +-
 postgis/lwgeom_functions_basic.c                  |  4 +
 regress/core/tickets.sql                          |  3 +
 regress/core/tickets_expected                     |  1 +
 7 files changed, 61 insertions(+), 47 deletions(-)
hooks/post-receive
