[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.5-29-g33b01c1a3
Mon Jul 18 02:51:07 PDT 2022
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  33b01c1a307730caf1c7405fda618836922e7149 (commit)
       via  3a62765c9b66ee38007a5c564331feece6528130 (commit)
      from  3360dbe6faf1ae6af0982cfd49f849c7cd977a4a (commit)
revisions in full, below.
commit 33b01c1a307730caf1c7405fda618836922e7149
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 18 05:51:02 2022 -0400
    Fix bessie32 build
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
index 10c838ea9..0d721ca43 100644
--- a/ci/bessie32/postgis_regress.sh
+++ b/ci/bessie32/postgis_regress.sh
@@ -1,11 +1,16 @@
+#!/usr/bin/env bash
+set -e
 #export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
+export CC=gcc11
+export CXX=g++11
+export CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc11  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc11"
+export CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc"
+export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-CC=gcc8   \
-CXX=g++8 \
-CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc8" \
-CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
- ./configure --with-libiconv=/usr/local --without-interrupt-tests
-make clean
+./configure PKG_CONFIG=/usr/local/bin/pkgconf LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --with-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf --with-wagyu
 make
 export PGUSER=postgres
 export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${BRANCH}
commit 3a62765c9b66ee38007a5c564331feece6528130
Date:   Mon Jul 18 05:43:45 2022 -0400
    revert accidental commit of deleted file.
    References #5154 for PostGIS 3.1.6
diff --git a/raster/rt_pg/rtpostgis_proc_set_search_path.sql b/raster/rt_pg/rtpostgis_proc_set_search_path.sql
deleted file mode 100644
index c947525f4..000000000
--- a/raster/rt_pg/rtpostgis_proc_set_search_path.sql
+++ /dev/null
@@ -1,686 +0,0 @@
-DO language plpgsql $$DECLARE param_postgis_schema text;
-BEGIN
--- check if PostGIS is already installed
-param_postgis_schema = (SELECT n.nspname from pg_extension e join pg_namespace n on e.extnamespace = n.oid WHERE extname = 'postgis');
--- if in middle install, it will be the current_schema or what was there already
-param_postgis_schema = COALESCE(param_postgis_schema, current_schema());
-IF param_postgis_schema != current_schema() THEN
-	EXECUTE 'set search_path TO ' || quote_ident(param_postgis_schema);
-END IF;
--- PostGIS set search path of functions
--- ALTER FUNCTION script
-EXECUTE 'ALTER FUNCTION  box3d(raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_summary(rast raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_makeemptyraster(width int, height int, upperleftx float8, upperlefty float8, pixelsize float8 ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_makeemptyraster(rast raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_band(rast raster, nband int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_band(rast raster, nbands text, delimiter char  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_summarystats(
-	rast raster,
-	nband int ,
-	exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
- ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxsummarystats(
-	rast raster,
-	nband int ,
-	exclude_nodata_value boolean ,
-	sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-	nband int,
-	rast raster,
-	exclude_nodata_value boolean,
-	rast raster,
-EXECUTE 'ALTER FUNCTION  _st_summarystats(
-	rastertable text,
-	rastercolumn text,
-	nband integer ,
-	rastertable text,
-	nband integer ,
-	rastertable text,
-	rastertable text,
-	nband integer ,
-	rastertable text,
-	nband integer,
-	rastertable text,
-	rastertable text,
-EXECUTE 'ALTER FUNCTION  _st_count(rast raster, nband int , exclude_nodata_value boolean , sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_count(rast raster, nband int , exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_count(rast raster, exclude_nodata_value boolean ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rast raster, nband int , exclude_nodata_value boolean , sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rast raster, nband int, sample_percent double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rast raster, exclude_nodata_value boolean, sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rast raster, sample_percent double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_countagg_finalfn(agg agg_count ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  __st_countagg_transfn(
-	agg agg_count,
-	rast raster,
- 	nband integer , exclude_nodata_value boolean ,
-EXECUTE 'ALTER FUNCTION  _st_countagg_transfn(
-	agg agg_count,
-	rast raster,
- 	nband integer, exclude_nodata_value boolean,
-	agg agg_count,
-	rast raster,
-	agg agg_count,
-	rast raster,
-EXECUTE 'ALTER FUNCTION  _st_count(rastertable text, rastercolumn text, nband integer , exclude_nodata_value boolean , sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_count(rastertable text, rastercolumn text, nband int , exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_count(rastertable text, rastercolumn text, exclude_nodata_value boolean ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rastertable text, rastercolumn text, nband int , exclude_nodata_value boolean , sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rastertable text, rastercolumn text, nband int, sample_percent double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rastertable text, rastercolumn text, exclude_nodata_value boolean, sample_percent double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxcount(rastertable text, rastercolumn text, sample_percent double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_histogram(
-	rast raster, nband int,
-	bins int,
-	right boolean,
-	OUT min double precision,
-	OUT max double precision,
-	OUT count bigint,
-	OUT percent double precision
-	bins int,
-	right boolean,
-	OUT count bigint,
-EXECUTE 'ALTER FUNCTION  st_approxhistogram(
-	sample_percent double precision,
-	bins int,
-	right boolean,
-	OUT count bigint,
-	OUT count bigint,
-	rast raster,
-	OUT count bigint,
-	bins int, width double precision[] ,
-	right boolean ,
-	OUT count bigint,
-	bins int, right boolean,
-	OUT count bigint,
-	rastertable text, rastercolumn text, nband int,
-	bins int,
-	right boolean,
-	OUT count bigint,
-	bins int,
-	right boolean,
-	OUT count bigint,
-	bins int,
-	right boolean,
-	OUT count bigint,
-	OUT count bigint,
-	OUT count bigint,
-	right boolean ,
-	OUT count bigint,
-	bins int,
-	right boolean,
-	OUT count bigint,
-EXECUTE 'ALTER FUNCTION  st_quantile(
-	rast raster,
-	nband int,
-	quantiles double precision[],
-	OUT quantile double precision,
-	OUT value double precision
-	rast raster,
-EXECUTE 'ALTER FUNCTION  st_quantile(rast raster, nband int, exclude_nodata_value boolean, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_quantile(rast raster, nband int, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_quantile(rast raster, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxquantile(
-	rast raster,
-EXECUTE 'ALTER FUNCTION  st_approxquantile(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxquantile(rast raster, nband int, sample_percent double precision, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxquantile(rast raster, sample_percent double precision, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rastertable text,
-	nband int,
-	rastertable text,
-EXECUTE 'ALTER FUNCTION  st_quantile(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_quantile(rastertable text, rastercolumn text, nband int, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_quantile(rastertable text, rastercolumn text, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rastertable text,
-EXECUTE 'ALTER FUNCTION  st_approxquantile(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxquantile(rastertable text, rastercolumn text, nband int, sample_percent double precision, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_approxquantile(rastertable text, rastercolumn text, sample_percent double precision, quantile double precision ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuecount(rast raster, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuecount(rast raster, nband integer, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuecount(rast raster, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuepercent(rast raster, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuepercent(rast raster, nband integer, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuepercent(rast raster, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuecount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuecount(rastertable text, rastercolumn text, nband integer, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuecount(rastertable text, rastercolumn text, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuepercent(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuepercent(rastertable text, rastercolumn text, nband integer, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_valuepercent(rastertable text, rastercolumn text, searchvalue double precision, roundto double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_reclass(rast raster, VARIADIC reclassargset reclassarg[] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_reclass(rast raster, reclassexpr text, pixeltype text ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_colormap(
-	rast raster, nband int ,
-	colormap text ,
-	method text  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-	colormap text,
-EXECUTE 'ALTER FUNCTION  st_astiff(rast raster, options text[] , srid integer  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_astiff(rast raster, compression text, srid integer  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_asjpeg(rast raster, options text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_asjpeg(rast raster, nbands int[], quality int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_asjpeg(rast raster, nband int, quality int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_aspng(rast raster, options text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_aspng(rast raster, nbands int[], compression int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_aspng(rast raster, nband int, compression int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_asraster(
-	geom geometry,
-	ref raster,
-	pixeltype text[] ,
-	value double precision[] ,
-	nodataval double precision[] ,
-	touched boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_resample(
-	rast raster,
-	ref raster,
-	algorithm text ,
-	maxerr double precision ,
-	usescale boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-	ref raster,
-	usescale boolean,
-	algorithm text ,
-	maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_transform(rast raster, srid integer, algorithm text , maxerr double precision , scalex double precision , scaley double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_transform(rast raster, srid integer, scalex double precision, scaley double precision, algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_transform(rast raster, srid integer, scalexy double precision, algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-	alignto raster,
-	algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_rescale(rast raster, scalex double precision, scaley double precision, algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_rescale(rast raster, scalexy double precision, algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_reskew(rast raster, skewx double precision, skewy double precision, algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_reskew(rast raster, skewxy double precision, algorithm text , maxerr double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_snaptogrid(
-	rast raster,
-	gridx double precision, gridy double precision,
-	algorithm text , maxerr double precision ,
-	scalex double precision , scaley double precision  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-	scalex double precision, scaley double precision,
-	rast raster,
-	scalexy double precision,
-EXECUTE 'ALTER FUNCTION  st_resize(
-	rast raster,
-	width text, height text,
-	rast raster,
-	width integer, height integer,
-	rast raster,
-	percentwidth double precision, percentheight double precision,
-EXECUTE 'ALTER FUNCTION  st_max4ma(matrix float[][], nodatamode text, variadic args text[] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_min4ma(matrix float[][], nodatamode text, variadic args text[] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_sum4ma(matrix float[][], nodatamode text, variadic args text[] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_mean4ma(matrix float[][], nodatamode text, variadic args text[] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_range4ma(matrix float[][], nodatamode text, variadic args text[] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_mapalgebra(
-	rast raster, nband int[],
-	callbackfunc regprocedure,
-	pixeltype text ,
-	extenttype text , customextent raster ,
-	distancex integer , distancey integer ,
-	VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_convertarray4ma(value double precision[][] ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_max4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_min4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_sum4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_mean4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_range4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_invdistweight4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_mindist4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_slope4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_slope(
-	rast raster, nband integer,
-	customextent raster,
-	pixeltype text , units text ,
-	scale double precision ,	interpolate_nodata boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_aspect4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_aspect(
-	interpolate_nodata boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_hillshade4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_hillshade(
-	pixeltype text ,
-	azimuth double precision , altitude double precision ,
-	max_bright double precision , scale double precision ,
-EXECUTE 'ALTER FUNCTION  _st_tpi4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_tpi(
-	pixeltype text , interpolate_nodata boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_roughness4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_roughness(
-EXECUTE 'ALTER FUNCTION  _st_tri4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_tri(
-EXECUTE 'ALTER FUNCTION  _st_grayscale4ma(value double precision[][][], pos integer[][], VARIADIC userargs text[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_grayscale(
-	rastbandargset rastbandarg[],
-	extenttype text  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
- 	redband integer ,
- 	greenband integer ,
- 	blueband integer ,
-EXECUTE 'ALTER FUNCTION  st_bandisnodata(rast raster, forceChecking boolean ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_BandMetaData(
-	rast raster,
-	band int ,
-	OUT pixeltype text,
-	OUT nodatavalue double precision,
-	OUT isoutdb boolean,
-	OUT path text,
-	OUT outdbbandnum integer,
-	OUT filesize bigint,
-	OUT filetimestamp bigint
-EXECUTE 'ALTER FUNCTION  st_value(rast raster, x integer, y integer, exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_Value(rast raster, pt geometry, exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_PixelofValue(
-	rast raster,
-	search double precision[],
-	OUT val double precision,
-	OUT x integer,
-	OUT y integer
-EXECUTE 'ALTER FUNCTION  st_pixelofvalue(
-	rast raster,
-	nband integer,
-	search double precision,
-	OUT x integer,
-	OUT y integer
-	rast raster,
-	OUT x integer,
-	OUT y integer
-EXECUTE 'ALTER FUNCTION  st_georeference(rast raster, format text  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_setgeoreference(rast raster, georef text, format text  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-	upperleftx double precision, upperlefty double precision,
-	skewx double precision, skewy double precision
-EXECUTE 'ALTER FUNCTION  st_setbandindex(rast raster, band integer, outdbindex integer, force boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_SetValues(
-	x integer, y integer,
-	newvalue double precision,
-	keepnodata boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast raster,
-EXECUTE 'ALTER FUNCTION  st_dumpvalues(rast raster, nband integer, exclude_nodata_value boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_pixelaspolygons(
-	rast raster,
-	band integer ,
-	OUT geom geometry,
-	OUT x int,
-	OUT y int
-EXECUTE 'ALTER FUNCTION  st_pixelaspolygon(rast raster, x integer, y integer ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_pixelaspoints(
-	rast raster,
-	band integer ,
-	OUT x int,
-	OUT y int
-EXECUTE 'ALTER FUNCTION  st_pixelaspoint(rast raster, x integer, y integer ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_pixelascentroids(
-	rast raster,
-	band integer ,
-	OUT x int,
-	OUT y int
-EXECUTE 'ALTER FUNCTION  st_pixelascentroid(rast raster, x integer, y integer ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoord(
-	rast raster,
-	longitude double precision, latitude double precision,
-	OUT columnx integer,
-	OUT rowy integer
-	rast raster, pt geometry,
-	OUT rowy integer
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoordx(rast raster, xw float8, yw float8 ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoordx(rast raster, xw float8 ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoordx(rast raster, pt geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoordy(rast raster, xw float8, yw float8 ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoordy(rast raster, yw float8 ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_worldtorastercoordy(rast raster, pt geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_rastertoworldcoord(
-	rast raster,
-	columnx integer, rowy integer,
-	OUT longitude double precision,
-	OUT latitude double precision
-EXECUTE 'ALTER FUNCTION  st_rastertoworldcoordx(rast raster, xr int, yr int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_rastertoworldcoordx(rast raster, xr int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_rastertoworldcoordy(rast raster, xr int, yr int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_rastertoworldcoordy(rast raster, yr int ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_asbinary(raster, outasin boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_hash(raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_eq(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_overleft(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_overright(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_left(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_right(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_overabove(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_overbelow(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_above(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_below(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_same(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_contained(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_contain(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_overlap(raster, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_geometry_contain(raster, geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_contained_by_geometry(raster, geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  raster_geometry_overlap(raster, geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  geometry_raster_contain(geometry, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  geometry_contained_by_raster(geometry, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  geometry_raster_overlap(geometry, raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_samealignment(
-	ulx1 double precision, uly1 double precision, scalex1 double precision, scaley1 double precision, skewx1 double precision, skewy1 double precision,
-	ulx2 double precision, uly2 double precision, scalex2 double precision, scaley2 double precision, skewx2 double precision, skewy2 double precision
-EXECUTE 'ALTER FUNCTION  _st_samealignment_transfn(agg agg_samealignment, rast raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _ST_samealignment_finalfn(agg agg_samealignment ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_iscoveragetile(rast raster, coverage raster, tilewidth integer, tileheight integer ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _st_intersects(geom geometry, rast raster, nband integer  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_Intersection(geomin geometry, rast raster, band integer  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_intersection(rast raster, band integer, geomin geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_Intersection(rast raster, geomin geometry ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-	rast1 raster, band1 int,
-	rast2 raster, band2 int,
-	returnband text ,
-	nodataval double precision[]  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_clip(
-	rast raster, nband integer[],
-	geom geometry,
-	nodataval double precision[] , crop boolean  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_nearestvalue(
-	rast raster,
-	pt geometry,
-	rast raster, band integer,
-	rast raster,
-EXECUTE 'ALTER FUNCTION  st_neighborhood(
-	distancex integer, distancey integer,
-	rast raster,
-	pt geometry,
-	rast raster,
-	pt geometry,
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_srid(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_scale(rastschema name, rasttable name, rastcolumn name, axis char ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_blocksize(rastschema name, rasttable name, rastcolumn name, axis text ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_extent(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_alignment(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_spatially_unique(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_coverage_tile(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_regular_blocking(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_num_bands(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_pixel_types(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_pixel_types(rast raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_nodata_values(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_nodata_values(rast raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_out_db(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_out_db(rast raster ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _raster_constraint_info_index(rastschema name, rasttable name, rastcolumn name ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  _overview_constraint_info(
-	ovschema name, ovtable name, ovcolumn name,
-	OUT refschema name, OUT reftable name, OUT refcolumn name, OUT factor integer
-EXECUTE 'ALTER FUNCTION  _UpdateRasterSRID(
-	schema_name name, table_name name, column_name name,
-	new_srid integer
-EXECUTE 'ALTER FUNCTION  UpdateRasterSRID(
-	new_srid integer
-	table_name name, column_name name,
-	new_srid integer
-EXECUTE 'ALTER FUNCTION  ST_Retile(tab regclass, col name, ext geometry, sfx float8, sfy float8, tw int, th int, algo text  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  ST_CreateOverview(tab regclass, col name, factor int, algo text  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-EXECUTE 'ALTER FUNCTION  st_makeemptycoverage(tilewidth int, tileheight int, width int, height int, upperleftx float8, upperlefty float8, scalex float8, scaley float8, skewx float8, skewy float8, srid int4  ) SET search_path=' || quote_ident(param_postgis_schema) || ',pg_catalog;';
-END;$$;
\ No newline at end of file
Summary of changes:
 ci/bessie32/postgis_regress.sh                  |  17 +-
 raster/rt_pg/rtpostgis_proc_set_search_path.sql | 686 ------------------------
 2 files changed, 11 insertions(+), 692 deletions(-)
 delete mode 100644 raster/rt_pg/rtpostgis_proc_set_search_path.sql
hooks/post-receive
