[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.1-36-ge174cec94
Mon Jul 18 03:42:57 PDT 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  e174cec94394d862f1afb4bf1d447b459e9d7b94 (commit)
       via  af6414bf61efc20b8a621d29758c77515cef3315 (commit)
       via  715e0d2fa1c5ecc185e1e07affb9bdd23726e0b9 (commit)
      from  ab58faa8bf7b95187d74179e78946e2284fb8b85 (commit)
revisions in full, below.
commit e174cec94394d862f1afb4bf1d447b459e9d7b94
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 18 06:11:14 2022 -0400
    raster ST_Value is undercosted References #5154 for PostGIS 3.2.2
diff --git a/NEWS b/NEWS
index 71851600f..29484ee66 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.2.2dev
-2022/MM/DD
+PostGIS 3.2.2
+2022/07/DD
 * Bug Fixes *
   - #5182, Fix loading topology.sql in new database (Sandro Santilli)
@@ -24,6 +24,7 @@ PostGIS 3.2.2dev
   - #5152, Fix infinite loop with ST_Split (Sandro Santilli)
   - #5173, Crash creating flatgeobuf on row without geometry (Julien Rouhaud)
   - #4541, ST_ConcaveHull returns a "geometrycollection" type instead of the expected "polygon"
+- - #5154, raster ST_Value is undercosted (Regina Obe)
 PostGIS 3.2.1
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index f0084873d..76890bd85 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -4609,23 +4609,23 @@ CREATE OR REPLACE FUNCTION St_BandFileTimestamp(rast raster, band integer DEFAUL
 CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, x integer, y integer, exclude_nodata_value boolean DEFAULT TRUE)
     RETURNS float8
     AS 'MODULE_PATHNAME','RASTER_getPixelValue'
-    LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+    LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 -- Changed: 3.2.0 added resample arg
 CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'RASTER_getPixelValueResample'
 CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_nodata_value boolean DEFAULT TRUE)
     RETURNS float8
     AS $$ SELECT st_value($1, 1::integer, $2, $3, $4) $$
-    LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+    LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 CREATE OR REPLACE FUNCTION st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
     RETURNS float8
     AS $$ SELECT @extschema at .ST_value($1, 1::integer, $2, $3, 'nearest'::text) $$
 -- Availability: 3.2.0 added resample arg
 CREATE OR REPLACE FUNCTION st_setz(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
commit af6414bf61efc20b8a621d29758c77515cef3315
Date:   Mon Jul 18 06:06:22 2022 -0400
    Fix bessie32 build, now using gcc11
diff --git a/ci/bessie32/postgis_regress.sh b/ci/bessie32/postgis_regress.sh
index 10c838ea9..0d721ca43 100644
--- a/ci/bessie32/postgis_regress.sh
+++ b/ci/bessie32/postgis_regress.sh
@@ -1,11 +1,16 @@
+#!/usr/bin/env bash
+set -e
 #export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
+export CC=gcc11
+export CXX=g++11
+export CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc11  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc11"
+export CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc"
+export PATH=${PATH}:/usr/local:/usr/local/lib:/usr/local/bin
 sh autogen.sh
-CC=gcc8   \
-CXX=g++8 \
-CXXFLAGS="-O2 -pipe  -fstack-protector-strong -Wl,-rpath=/usr/local/lib/gcc8  -nostdinc++ -isystem /usr/include/c++/v1 -Wl,-rpath=/usr/local/lib/gcc8" \
-CFLAGS="-Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-trunc" \
- ./configure --with-libiconv=/usr/local --without-interrupt-tests
-make clean
+./configure PKG_CONFIG=/usr/local/bin/pkgconf LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --without-interrupt-tests --with-topology --with-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-address-standardizer --with-protobuf --with-wagyu
 make
 export PGUSER=postgres
 export PGIS_REG_TMPDIR=~/tmp/pgis_reg_${BRANCH}
commit 715e0d2fa1c5ecc185e1e07affb9bdd23726e0b9
Date:   Sun Jul 17 18:59:59 2022 -0400
    Generate md5 hash. Closes #5159 for PostGIS 3.2.2
diff --git a/ci/debbie/postgis_make_dist.sh b/ci/debbie/postgis_make_dist.sh
index c07091c2f..085ff20fa 100644
--- a/ci/debbie/postgis_make_dist.sh
+++ b/ci/debbie/postgis_make_dist.sh
@@ -31,7 +31,9 @@ export newoutdir="postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${PO
 sh make_dist.sh
 export package=${newoutdir}.tar.gz
+md5sum ${package} > ${package}.md5
 echo "The package name is $package"
 cp $package $WEB_DIR
+cp ${package}.md5 $WEB_DIR
 bash ci/debbie/postgis_release_docs.sh
Summary of changes:
 NEWS                           |  5 +++--
 ci/bessie32/postgis_regress.sh | 17 +++++++++++------
 ci/debbie/postgis_make_dist.sh |  2 ++
 raster/rt_pg/rtpostgis.sql.in  |  8 ++++----
 4 files changed, 20 insertions(+), 12 deletions(-)
hooks/post-receive
