[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0beta2-4-g2c221417c
Mon Jul 18 15:01:31 PDT 2022
the project "PostGIS".
       via  2c221417ce749663b904f42dba0f7293b5747898 (commit)
      from  2d342e6c6a0ee3d7c807dcb1b0284e1363bef698 (commit)
revisions in full, below.
commit 2c221417ce749663b904f42dba0f7293b5747898
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Jul 18 18:00:03 2022 -0400
    raster ST_Value is undercosted Closes #5154 for PostGIS 3.3.0
diff --git a/NEWS b/NEWS
index 2b44731f7..3d1fb4f92 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Requires SFCGAL 1.4.1+ for ST_AlphaShape and ST_OptimalAlphaShape.
 Changes since PostGIS 3.3.0beta2:
 * Bug fixes *
+  - #5154, raster ST_Value is undercosted (Regina Obe)
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 02de3390a..0726acf51 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -4615,17 +4615,17 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, x integer, y inte
 CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, exclude_nodata_value boolean DEFAULT TRUE, resample text DEFAULT 'nearest')
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'RASTER_getPixelValueResample'
-	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_nodata_value boolean DEFAULT TRUE)
     RETURNS float8
     AS $$ SELECT st_value($1, 1::integer, $2, $3, $4) $$
-    LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
+    LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 CREATE OR REPLACE FUNCTION st_value(rast raster, pt geometry, exclude_nodata_value boolean DEFAULT TRUE)
     RETURNS float8
     AS $$ SELECT @extschema at .ST_value($1, 1::integer, $2, $3, 'nearest'::text) $$
 -- Availability: 3.2.0 added resample arg
 CREATE OR REPLACE FUNCTION st_setz(rast raster, geom geometry, resample text DEFAULT 'nearest', band integer default 1)
Summary of changes:
 NEWS                          | 1 +
 raster/rt_pg/rtpostgis.sql.in | 6 +++---
 2 files changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
