[postgis-tickets] [PostGIS] #5171: SELECT st_length(st_geomfromtext gives error when running on Proj 6.3 when points input are the same (was: SELECT st_length(st_geomfromtext gives error when running on ARM processor when points input are the same)
PostGIS trac at osgeo.org
Wed Jul 20 01:04:12 PDT 2022
  Reporter:  arnghosb  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.1.7
 Component:  postgis   |    Version:  3.2.x
Resolution:            |   Keywords:
Changes (by robe):
 * summary:
 * milestone:  PostGIS 3.1.6 => PostGIS 3.1.7
Comment:
 I think this is a bug with Proj as it's only replicable on proj 6.3.2 and
 so probably doesn't have anything to do with ARM.  arnghosb suggested
 maybe we go thru the same path as we do for lower geometry.  Anyway
 pushing this off.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5171#comment:9>
