[postgis-tickets] [SCM] postgis.net branch website updated. fa1d48da64e59044615ee40dc579385838ea03ac
Wed Jul 20 12:25:42 PDT 2022
the project "postgis.net".
The branch, website has been updated
       via  fa1d48da64e59044615ee40dc579385838ea03ac (commit)
      from  355a7ded31d06f6fafcb5b767bdbe7313ea8fe0f (commit)
revisions in full, below.
commit fa1d48da64e59044615ee40dc579385838ea03ac
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Jul 20 15:25:36 2022 -0400
    PostGIS 3.1.6 release
diff --git a/config/_default/params.toml b/config/_default/params.toml
index 8ad80bc..167f571 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -145,8 +145,8 @@ dev_download = "/stuff"
     tag = "3.2.1"
   [postgis.releases.31]
     minor = "3.1"
-    dev = "3.1.6dev"
-    tag = "3.1.5"
+    dev = "3.1.7dev"
+    tag = "3.1.6"
   [postgis.releases.30]
     minor = "3.0"
     dev = "3.0.7dev"
diff --git a/content/post/2022/07-20_postgis-3.1.6.md b/content/post/2022/07-20_postgis-3.1.6.md
new file mode 100644
index 0000000..203ef55
--- /dev/null
+++ b/content/post/2022/07-20_postgis-3.1.6.md
@@ -0,0 +1,70 @@
+title: PostGIS 3.1.6
+layout: post
+category: news
+tags: [release, 3.1]
+author: Regina Obe
+date: "2022-07-20T12:50:40"
+thumbnail:
+The PostGIS Team is pleased to release PostGIS 3.1.6!
+This release works for PostgreSQL 9.6-14.
+**3.1.6**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.1.6.tar.gz) [md5]({{< loc "postgis.dev_download">}}/postgis-3.1.6.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.6/NEWS)
+* [PDF docs en]({{< loc "postgis.release_docs">}}/postgis-3.1.6.pdf)
+This release is a bug fix release, addressing issues found in the previous 3.1 releases.
+<!--more-->
+*Bug Fixes*
+- [#4835](https://trac.osgeo.org/postgis/ticket/4835), Occasional distance errors in polar area (Paul Ramsey)
+- [#5152](https://trac.osgeo.org/postgis/ticket/5152), Fix infinite loop with ST_Split (Sandro Santilli)
+- [#5120](https://trac.osgeo.org/postgis/ticket/5120), Fix not-null result from ST_EstimatedExtent against
+         truncated tables with spatial index (Sandro Santilli)
+- [#5076](https://trac.osgeo.org/postgis/ticket/5076), Avoid log storm installed with pgaudit enabled (Paul Ramsey)
+- [#5100](https://trac.osgeo.org/postgis/ticket/5100), Stop using pg_atoi, removed in PG 15 (Laurenz Albe)
+- [#5115](https://trac.osgeo.org/postgis/ticket/5115), Allow dropping topologies with pending constraints (Sandro Santilli)
+- [#5151](https://trac.osgeo.org/postgis/ticket/5151), ST_SetPoint with empty geometries (Regina Obe)
+- [#5150](https://trac.osgeo.org/postgis/ticket/5150), Change signature of AddToSearchPath (Regina Obe)
+- [#5125](https://trac.osgeo.org/postgis/ticket/5125), Fix search path function (Sandro Santilli)
+- [#5155](https://trac.osgeo.org/postgis/ticket/5155), More schema qual fixes (Regina Obe)
+- [#5114](https://trac.osgeo.org/postgis/ticket/5114), Crash with long column names in pgsql2shp (Paul Ramsey)
+- [#4541](https://trac.osgeo.org/postgis/ticket/4541), ST_ConcaveHull returns a "geometrycollection" type
+         instead of the expected "polygon" (Regina Obe)
+- [#5154](https://trac.osgeo.org/postgis/ticket/5154), raster ST_Value is undercosted (Regina Obe)
+**Upgrading**
+After installing the binaries or after running pg_upgrade:
+For PostGIS 3.1, 3.0
+do below which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+For PostGIS 2.5 and below do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+If you come across any issues, feel free to report via our [ticket tracker](https://trac.osgeo.org/postgis)
+or [mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
+View all [tickets for 3.1.6 milestone][1].
+[1]: https://trac.osgeo.org/postgis/query?status=assigned&status=closed&milestone=PostGIS+3.1.6
Summary of changes:
 config/_default/params.toml              |  4 +-
 content/post/2022/07-20_postgis-3.1.6.md | 70 ++++++++++++++++++++++++++++++++
 2 files changed, 72 insertions(+), 2 deletions(-)
 create mode 100644 content/post/2022/07-20_postgis-3.1.6.md
hooks/post-receive
postgis.net
