[postgis-tickets] [PostGIS] #5157: basic_test failure on i386
PostGIS trac at osgeo.org
Thu Jul 21 13:30:14 PDT 2022
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.3.0
 Component:  liblwgeom       |    Version:  master
Resolution:                  |   Keywords:
Comment (by robe):
 Replying to [comment:3 Bas Couwenberg]:
 > Still fails in 3.3.0beta1:
 >   Test: basic_test ...FAILED
 >     1. cu_minimum_bounding_circle.c:35  - CU_ASSERT_TRUE(d <=
 result->radius)
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=i386&ver=3.3.0~beta1%2Bdfsg-1~exp1&stamp=1656873023&file=log
 Full buildlog]
 > Should we consider i386 no longer support and ignore test failures
 there?
 Maybe in PostGIS 3.4.0, but we should fix in 3.3.0 as we still have 32-bit
 bots and never said we wouldn't support.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5157#comment:5>
