[postgis-tickets] [PostGIS] #5139: PostGIS causes to_jsonb to no longer be parallel safe
PostGIS trac at osgeo.org
Thu Jul 21 21:54:09 PDT 2022
  Reporter:  samuelspurling  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.2
 Component:  postgis         |    Version:  3.2.x
Resolution:                  |   Keywords:
Comment (by robe):
 AS expected this is also an issue with ST_AsGeoJSON
 WITH object_list AS (
         SELECT id,'a_large_table' AS table_name,
 ST_AsGeoJSON(a_large_table.geom) AS json_data
         FROM a_large_table
         WHERE id::text LIKE '10000'
 SELECT * INTO TEMPORARY TABLE object_list_temp
 FROM object_list;
 triggers the same:
 ERROR:  cannot start commands during a parallel operation
 CONTEXT:  SQL statement "SELECT auth_name||':'||auth_srid FROM
 public.spatial_ref_sys WHERE srid='27700'"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5139#comment:4>
